Replacement MLGW by BLGW
Answered (Verified) This post has 1 verified answer | 4 Replies | 2 Followers
Griebel
Griebel posted on Mon, Apr 2 2018 11:28 AM
I intend to replace my MLGW by a BLGW. I guess I will have to do all the programming of the connected devices from scratch. No possibility to save a config file et then upload it inti the BLGW?
Thank you.
beojeff
USA
Silver Member
Verified by Griebel
Sadly, the configuration files are not compatible and you will need to reprogram the BLGW. It's worth the effort, though. You'll find that the programming is quite fast now that you've already put the though into the MLGW programming. Also, the BLGW can quickly find and add trigger sources in most cases with one click.
beojeff
USA
Silver Member
Verified by Griebel
Griebel
Thank you. Clear enough.
mjmedlo
Agreed.
Blgw is much simpler and the ‘capture’ feature
Makes programming a snap.
Feel free to ask any questions.
Where are you located and what products do you intend to connect.
Griebel
Thanks. I’m located in Paris.
Several older but also more recent products will be connected. Will give it a try.
Page 1 of 1 (5 items) | RSS
