BC1200
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
Aad Jansse
Rotterdam (Neth)
Silver Member
Aad Jansse posted on Thu, Mar 29 2018 8:35 AM
Erroneously I posted some time ago about a problem with my BC1200 ( belts)  that I was happy enough to be able to fix with new belts from Dillen. The error consisted of linking this problem to my 1200, whereas it actually was my BC1600.
Now I have a problem with my BC1200, actually;
When I rewind a full reel  from left to right, it starts spinning as it is supposed to  do, but gradually it slows down to eventually a full stop once the right reel is filling up to more than 50%. Playback no problem.
Is this  also a belt problem?
Aad
Dillen
Copenhagen / Denmark
Dillen replied on Thu, Mar 29 2018 9:27 AM
Sounds more like a clutch or brake problem.
Is the torque lost in slipping clutch wheels?
Or does the motor actually grind to a halt?
Aad Jansse
Rotterdam (Neth)
Silver Member
These days I am off the machine, i will check things out after the weekend
regards,
Aad
bidstonhall
Thailand 5560 miles from Struer
Hi, I had the same issue, turned out to be brake adjustment, at the front of the machine, it's working fine now
Aad Jansse
Rotterdam (Neth)
Silver Member
Although it is a long time ago that I got your comment on my problem ( I had to spend my time on many other projects, not only B&O ) I still appreciate your lead to a possible solution of the FF problem of my BC1200.
I recently turned my attention again to this item, so I have to ask for some more detailed advice as to what you did when  you did the brake adjustment:
it is not quite clear to me.
Aad Jansse
Rotterdam (Neth)
Silver Member
After my Chritmas vacation I will also check Dillen's clutch suggestion
thanks
Aad Jansse
Rotterdam (Neth)
Silver Member
Finally, after checking several possibilities I noticed that the belt that runs through the plastic cup was weak ; awaiting a new belt to be supplied by Martin I took off the old one , cut out about 1 cm and glued the 2 ends together (ethylcyanoacrylaat by  Pattex). (I also filled some cracks in the belt with this glue to avoid breaking later on.)
After eliminating some rattling sounds ( one from having replaced wrong washers behind the clutch and the other from the tape counter) my old baby runs like on his day of birth.
Aadi
Page 1 of 1 (7 items) | RSS
