Bluetooth verbinding bv 7-55 naar beoplay h8
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
Gerardus54
Silver Member
Gerardus54 posted on Sun, Mar 4 2018 10:03 AM
Goedemorgen
Ik wil een bluetooth verbinding maken van de 7-55 naar bp h8
Mijn vraag is heeft b&o daar een losse zender voor of moet ik er een van een andere leverancier kopen.
Alleyman
Gerardus54:
Goedemorgen
Andere leverancier.
B&O heeft geen losse bluetooth-zender.
Beofrank
Hier gaat het mee lukken
BlitzWolf® BW-BR2 Bluetooth V4.1 aptX Music Receiver Transmitter 3.5mm AUX Audio 2 in 1 Adapter
https://www.banggood.com/BlitzWolf-BW-BR2-Bluetooth-V4_1-aptX-Music-Receiver-Transmitter-3_5mm-AUX-Audio-2-in-1-Adapter-p-1267493.html?rmmds=search&cur_warehouse=CN
Product description:
CSR8670 Bluetooth Chip: The BW-BR2 operates on a CSR8670 Bluetooth chip which provides high-quality sound and
wide compatibility with Bluetooth devices. The CSR8670 chip is compatible with HFP, HSP, A2DP, and AVRCP protocols, also support apt-X CD sound quality decoding(only support on Receiver Mode).
High capacity battery: The Blitzwolf BW-BR2 built-in 180mAh battery provides up to 10 hours of continuous transmission.Fully charging the battery takes around 1.5 hours.
Wide range of uses:
Receiver Mode:
You can use the Blitzwolf BW-BR2 in your car with the 3.5mm connector or the 3.5mm AUX cable provided you have an AUX in mode in your car stereo or home theater speakers.
Transmitter Mode
You can use the Blitzwolf BW-BR2 to your TV to pair your bluetooth headset(up to pair two BT devices meanwhile) which do not disturb the rest of your family to enjoy the movie, the ball game by yourself.
An 18-Month Warranty:
We believe in our products, join BlitzWolf to get what you want.
We back them all with an 18 months warranty and provide friendly and convenient support.
Package includes:
 1* BlitzWolf® BW-BR2 Bluetooth V4.1 Receiver and Transmitter
1* 3.5mm to 3.5mm AUX Audio Cable
1* 3.5mm to 2 RCA Male AUX Audio Cable
1*3.5mm to 3.5mm AUX Adapter
1* Micro USB Charging Cable
1* User manual
1* Warranty Card
Gerardus54
Silver Member
Hallo liefhebbers
Bedankt voor uw reactie,hier kan ik het wel mee doen.
Page 1 of 1 (4 items) | RSS
