BV7 MK3 Red light
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
quader
quader posted on Wed, Feb 14 2018 12:37 PM
Hello Beoworlders
my BV7 MK3 is not switching on anymore
the RED standby light appears but nothing else
i have used different commands on the BEO4 and disc tray bit nothing happens
I have unpluged it from mains and that does not work did not even ask for a PIN code
any ideas would be appreciated
BEOVOX141
Denmark, West
Start by checking the obvious, -the BEO4
If its sending codes, you should be able to see the two IR diodes as two small purple dots with a digital camera.
Volume up/down will send codes continuously as long as the key is pressed.
Page 1 of 1 (2 items) | RSS
