Any info on this (crt) B&O set ?
Not Answered This post has 0 verified answers | 6 Replies | 0 Followers
mawrick
mawrick posted on Fri, Feb 9 2018 10:05 PM
The owner wasn't sure about model name/specs but maybe someone here is able to shed some light on this set.
I was after a CRT and picking this one up for free tomorrow, so not much of a "chance" to take, but any info about model and spec/quality would be appreciated.
thnx
Millemissen
Flensborg, Denmark
May I ask, for what you are going to use this heavy-weight CTR.
By the way - here you go:
https://www.beoworld.org/prod_details.asp?pid=865
mawrick
Mostly it's gonna be used for classic gaming, had to make a quick call on it as it was on it's way to the skip tomorrow.....(so it was free anyway).....:)
Millemissen
Flensborg, Denmark
Once there you (probably) need two people to move it around.
If it is ok, it should be good for that purpose.
Others pick the MX series - easier to handle Stick out tongue
Millemissen
Flensborg, Denmark
Note!
You can take it apart?
At the backside there are two ‘handles’ for removing the screen part....makes it easier.
mawrick
yea, we will be 2 persons handling it - any idea about the weight on these or ?
Does it compare ok to the mx series in picture quality ?
mawrick
See it states roughly 50 kg on the page you linked so guess it's thereabout :)
Page 1 of 1 (7 items) | RSS
