BV7-40, BEOLAB 5s and SPDIF Input
Not Answered This post has 0 verified answers | 1 Reply | 2 Followers
nigelreece
nigelreece posted on Mon, Oct 8 2012 8:36 PM
My previous set up for playing lossless files from my MAC through my Beolab 5's was through a V-LINK 192 with my overture playing any random CD.  In Option 0 the Beolab 5s recognised the CD output, saw a digital input and defaulted to the SPDIF from my V-LINK 192 (sounded awesome).
I have recently moved house and moved my overture to a different room.  My Beolab 5's are now connected to a BV7-40.  I was hoping to utilise the DVD player on the BV7-40 to generate a CD output and therefore be able to use my V-LINK192 in a similar way.  However, it does not seem to work and even with a SPDIF input the Beolab 5s play the CD in the BV7-40 (not the music sent to the SPDIF input.
Is there a way of using the BV7-40 to generate a 'CD' output signal to the Beolabs - or do I need to connect my overture up from a different room by masterlink?
Thoughts/solutions would be much appreciated.
NR
kimchr
only CD as source will trigger the spdif signal in your bl5. I think you would play a CD in your bv7 by activating the DVD source. so I guess you need your overture.
how do you cope with the auto standby on the overture?
Page 1 of 1 (2 items) | RSS
