Making Avant appear cable free
This post has 28 Replies | 2 Followers
Seanie_230
UK
Posts 1,979
Seanie_230 Posted: Sun, Jan 21 2018 6:27 PM
Hello you lot
I have my Avant currently on its floor stand and am going to buy a SkyQ Wall mount behind the TV on the wall, I will also Wall mount the PS4.
The below shows you where the socket it and I am thinking of moving it up.
Would you put in three double sockets or a single double socket and a wall mount extension lead ?
Going to plug in two lab9’s, SkyQ, PS4 and the Avant all behind the TV.
Would you move the double higher up or put in three double higher up on the ring main.
I will also remove the Ariel socket and put in a single back box with a brushed face plate for sky cables to come in.
Thoughts?
BLGW - Rekindling the love of ML
Aussie Michael
Melbourne, AU
Posts 3,427
Why dont you mount them on the rear of the TV instead of the wall? Then just run the cable as you have now ?
Just a thought
trackbeo
Posts 311
trackbeo replied on Mon, Jan 22 2018 3:40 PM
Because whether or not he mounts the gadgets on the back of the TV, moving the existing cable connection higher on the wall means it will be suspended in mid-air, completely hidden behind the Avant, both when parked and when rotated out. (This is the huge stupidity of the Avant stand: visible cable tail dragging left and right across the base circle. B&O could have made the cables hidden and un-kinked, but that would have meant a larger diameter stalk (with a hollow core) and a taller base cylinder section (with a 160-degree cable track bender).) Is there anything like an Arlington Products "TVBox" TVBU505 approved for code in the UK? It would have the Mains and low voltage divider and the cables could penetrate from multiple directions with either a scoop or a brush poke-thru (or even a Leviton Decora insert, here in the US). Then you could hide the whole mess with the Sky box, mounted on a keyhole stand-off, i.e. twisted so its front panel is pointed up and the top of the box is acting as the visible surface (shield of the recessed box and ugliness behind it).
w5bno123
London
Posts 578
w5bno123 replied on Mon, Jan 22 2018 4:00 PM
I would purchase two brackets from IndigoLime. You are able to mount a 4 gang power strip easily to one of the brackets bring Power close to the source. The brackets mount parallel to one another so they cosmetically look nice and the clamps slide up nice and tight on to the source. Can you not run the speaker cable in D line trunking and stick it to the top of the skirting, it will look less obvious than the cable sock.
https://indigolime.uk/
egges
germoney
Posts 303
egges replied on Mon, Jan 22 2018 6:12 PM
just my 5o cents: i was annoyed by the vibrations the AppleTV and the harddisk produced sometimes when they were mounted to the Avant. even when the Avant was off the harddisk caused noises and vibration.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Seanie_230
UK
Posts 1,979
Hello
You are right it would be Cleaner mounted on the TV and I looked at the bracket on STB backets website but they are very expensive.
It would have less chance of seeing the STB if I used the proper ones from them.
Maybe the socket could stay where it is if I bolt a extension lead to the back of the TB bracket
Perhaps I will keep a close eye on eBay
Aussie Michael
Melbourne, AU
Posts 3,427
Seanie_230:
Hello
Perhaps I will keep a close eye on eBay BLGW - Rekindling the love of ML
You could buy just the PS4/Xbox cradle and those and potentially wall mount them instead of on the “clamper”
Good luck, but i also agree that i was in a similar situation as well trying to hide the inevitable
Dion
Perth, Australia
Posts 34
Dion replied on Wed, Jan 24 2018 4:45 AM
Hi Seanie,
Your post has prompted me to post some pictures of my Avant setup (i've been meaning to do this for a while).
I'm not sure how applicable it is to your question, but I have developed a way to better integrate the cables of Avant. I didn't want to hijack your thread so I have started a new one here -
http://forum.beoworld.org/forums/t/29394.aspx
It may provide some ideas...
Regards,
Dion.
BeoVision Avant55 Mk1; Theatre with BeoSystem4; BeoSound2; BeoPlayA9; BeoPlayA6; BeoPlayM5; BeoPlayE6; BeoPlayH3 ANC
..and it all started 15 years ago with a pair of B&O A8 Earphones...
Seanie_230
UK
Posts 1,979
Few weeks of searching
STB c3 bracket found on eBay half price
PS4 bracket and a3 arm located cheap at a dealer.
Had to order another arm and decoder box from STB brackets today.
Aluminium pole for the back like Dion has been ordered from eBay.
Nearly there and it will be amazing in a few days with no cables on display.
Going to more than likely get another beolab receiver 1 than try and bury a PL cable in the right to a rear speaker.
Going to drill a hole in the pole to run the power cable from the socket up to the extension lead on the back of the PS4, the pole will also have the SkyQ cables inside it too.
Fidse
Posts 175
Fidse replied on Wed, Feb 28 2018 8:02 PM
I have my ps4 mounted i a “bracket” like this :
https://www.floatinggrip.com/vaegbeslag-til-playstation-og-xbox/
It’s more or less just two strings and one screw, meaning that it takes up the space of the ps4 and nothing more.
It fits just nicely in the space behind my wallmounted Eclipse, leaving my setup completely cablefree Smile
Seanie_230
UK
Posts 1,979
Looks amazing
Few more days and my setup will be cable free apart from the power and Pl to my lab9’s which I can live with.
Exciting
Millemissen
Flensborg, Denmark
Posts 13,050
ONLINE
A wallmounted tv gives you no option to ‘hide’ the gear behind the tv!
When it is not possible or wanted to use the space behind the wall, you will need some kind of furniture.
At least when you have a lot of gear and - like me - prefer cabled solutions.
Also, I wanted to have easy access to my bluray player.
So I kept the bench, that I had used for my previous BV8-40.
In my case I also had no option for drilling holes, hiding cables for the speakers etc.
So - I had to do my best....
....which is a hard job, when it starts like this:
Millemissen
Flensborg, Denmark
Posts 13,050
ONLINE
Fidse:
OK, I’ll have to correct myself.
Hiding something behind a wallmounted tv is possible........when you have a paperthin OLED tv ;-))
Seanie_230
UK
Posts 1,979
Wow that is where I started I think. I might run a cat6/7 cable outside around the bay and back into a wall mount back box for the lab 6000 meaning no attempting to put PL under the carpet.
elephant
AU
Posts 8,218
Millemissen:
I feel for you MM
I am in the same boat
And SWMBO has decreed no new BV without a new floor or carpet, and not without accompanying new wall furniture ...
That makes it a long project !
Cunning isn’t she Big Smile
BeoNut since '75
Fidse
Posts 175
Fidse replied on Thu, Mar 1 2018 7:03 AM
I love the Eclipse Big Smile
Millemissen:
Seanie_230
UK
Posts 1,979
Hello all
So Avant is nearly cable free just waiting for the final stb brackets for the SkyQ box damn snow.
So I have a beolab 6000 pair as rears one is using a receiver 1 which works but clicks on and off multiple times when the TV is turned on, I hear there is some issues when using it when SkyQ is in use.
I have just bought a new wireless ap to use which will add more 5ghz wireless to my house and it’s always SkyQ which ends up worse off.
So all in all I am thinking about running a cable on the outside of the wall that carries rear left and right signal and back in the other side of the bay window. This seems a better way than trying really small trunking above the skirting.
So I can run a Powerlink cable out round and back in again if I can do it properly and just terminate it with exactly enough length.
Or I could terminate it into a Powerlink Wall socket that could be smart too.
You can see the current PL cable trailing across the floor
Seanie_230
UK
Posts 1,979
Or I could buy a cable that I can take the end off one end RJ45 and other Powerlink, remove one end to get the cable round and then solder or crimp the end back on.
How difficult will this be? I have a Rj45 crimp for cat5e but have never crimped cat6/7
Fidse
Posts 175
Fidse replied on Sat, Mar 3 2018 10:14 PM
Another option could be to add a WISA receiver to your rears. That way you’ll just need a cable from the power outlet, and won’t have to run cables from the tv to the speakers.
Seanie_230:
Seanie_230
UK
Posts 1,979
Ta-Da
Thanks Dion for the inspiration.
Just need to get some of the rubber B&O power and PL speaker sleeping next time I am near a dealer.
What an amazing Tv and setup.
Bought a £5 pole from eBay and polished it up.
Few brackets from the STB brackets people and it looks amazing.
Seanie_230
UK
Posts 1,979
Dion
Perth, Australia
Posts 34
Dion replied on Mon, Mar 19 2018 3:03 PM
Looks freaking awesome Seanie! Well done.
Dion.
Dion
Perth, Australia
Posts 34
Dion.
poodleboy
Posts 274
poodleboy replied on Mon, Mar 19 2018 3:21 PM
Seanie_230:
If all goes according to plan, I will have copied your fireplace surround and wall covering 100% within 30 days. I already have wall color and black marble. Beautiful and COOL!
Seanie_230
UK
Posts 1,979
poodleboy:
BS9000, Essence, BeoLit12, MX4200, BL3000, BV11-55
That’s OK I copied Dion setup :)
If something works I am stealing the idea :)
Aussie Michael
Melbourne, AU
Posts 3,427
Looks nice Sean.
I nearly tried that setup. The power board attached to the back. Or the other way around.
To stop the fraying of your cable sock you can use a lighter on the ends. But looks like it should hold.
Dion
Perth, Australia
Posts 34
Dion replied on Thu, Mar 22 2018 2:57 AM
Seanie_230:
...and that is one of the best things about this forum and community... we get to share (steal Big Smile) ideas from each other!
Dion.
Jeff
USA
Posts 3,716
Silver Member
Jeff replied on Fri, Mar 23 2018 1:48 AM
Seanie_230:
poodleboy:
I consider it recycling instead of stealing. Big Smile
Jeff
Aussie Michael
Melbourne, AU
Posts 3,427
Jeff:
Jeff
Beovirus victim, it's gotten to be too much to list!
Page 1 of 1 (29 items) | RSS
