Beovision 10 speaker upgrade -> Beolab 4, Beolab 4000 or Beolab 14 4.1?
Not Answered This post has 0 verified answers | 16 Replies | 1 Follower
Aabo
Aabo posted on Thu, Jan 18 2018 8:46 PM
I want to upgrade my BV10 to a more decent stereo setup (potentially surround) but I'm not sure what compact speaker to choose.
Sound sources will mainly be: spotify through chromecast, SACD through my NAS, and vinyls through my Rega p9
My choices are these:
BL 4000: A true classic compact speaker
BL 4: Are these good without sub? - or best for a rear speaker?
BL 14 - Im not sure about the design, sorry I think they look a bit cheap
Happy to get your input, most important for me is the sound, I would love to avoid a subwoofer
Kristoffer
kallasr
Germany
Beolab 4000, s/n >1433xxxx to avoid issues with foam inside.
Great value for money and lots of option for wall mounting/table/stands.
Ralf
bramble
Aabo,
I have a bv 7 40 with 4 beolab 4's and a linn sub...(5.1) no issues great speakers and compactSmile
What they are like without a sub unsure.......
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Aabo
Aabo replied on Thu, Jan 18 2018 9:19 PM
Thanks! - does the SN refer to MK2?
Kristoffer
kallasr
Germany
No, just the foam.
marexy
marexy replied on Fri, Jan 19 2018 11:03 AM
Beolab 4000 any day ... top spekar for the money.
Aabo
Aabo replied on Fri, Jan 19 2018 1:04 PM
Guys, thanks for the replies. Spot on..! gonna go with two BL4000. Perhaps 2 more if I want the surround...
thanks again
K
elephant
AU
It will be great setup. Especially if you get 4 !
BeoNut since '75
PK
PK replied on Sun, Jan 21 2018 1:52 AM
I use my BL4 as rear speaker. The bass is quite weak so I would not use them for front main speaker unless with a subwoofer. They look really good, specially in blue.
BL4000 has lot more bass and can be used without a subwoofer depending on taste. I use them as front speakers without a subwoofer. Very good value for money ! Good sound and they are a true B&O classic.
I have not had a chance to listen to the BL14 but if you don’t like the look of them I would go for four BL4000 instead.
Aabo
Aabo replied on Sun, Jan 21 2018 12:23 PM
Hi, I just went for a 4xBL4000 with the right Sn numbers (thanks!). This setup is perfect, they are so flexible if you want to move them a bit a round..
Thanks again
Kristoffer
Duels
England
Duels replied on Sun, Jan 21 2018 2:11 PM
Aabo:
Thanks again
Kristoffer
Awesome. Enjoy them!
How about a picture?
Aabo
Aabo replied on Thu, Jan 25 2018 11:07 AM
Picture is coming! :) need to get them up, I have one more question. I've heard you can connect them in 'series' which would save some cables to your beovision.
I understand that you can do that from speaker to speaker, but how does the BV10 know which speaker it is (Front back L/R?) I have 4 DIN's in my beolab10..
Does this make sense?
Kristoffer
kallasr
Germany
kallasr replied on Thu, Jan 25 2018 11:27 AM
Yes, the TV will know - as soon as you set it up in the Speaker set-up.
I have done the same with Beosystem 3.
Ralf
Beosince98
Aabo:
Kristoffer
You can not connect more than two speakers in series! Powerlink carries only left/right speaker!
Hiort
Sweden
Hiort replied on Thu, Jan 25 2018 1:28 PM
kallasr:
Ralf
Well, you have to put the powerlink connector into the corresponding sockets.
There are two sockets for Front and two sockets for Rear.
You can pull one powerlink lead to e.g first front speaker and then continue to the second front. On the speakers you need to set a switch to either "right" or "left".
Page 1 of 2 (17 items) 1 2 Next > | RSS
