What' s this for? the rear of the floor stand for Beovision 7-55
Not Answered This post has 0 verified answers | 5 Replies | 0 Followers
danielshen
Dear, Can anybody know what is this black steel in the rear of the beovision 7-55 floor stand? What' s the purpose for this? Please check the picture:
Mikipidia
If it’s similar to the stand i have, then there would be a sort of upright metal bit attached to it to which you could attach and route your cables nicely downwards while giving it enough slack so the cables on the floor don’t move when turning/rotating the tv. If that makes sense
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia
Sal
California, USA
Sal replied on Wed, Jan 17 2018 5:57 AM
Mikipedia:
It looks very similar to the metal bit on the back of the original Avant rotating stand which was in the base of the TV where the socket panel was located. It was meant, as I was told, and used it for, to zip tie cables to. I didn't know the 7-55 had a vertical "post" like the more modern television stands do.
SHEFFIELD
It should be positioned at the rear most position and is for cable tidying with tie wraps - no pole is attached here.
Mikipidia
I didn’t know that, but this is what the combined knowledge of this forum will give you Big Smile
Page 1 of 1 (6 items) | RSS
