Bang & Olufsen app update
Not Answered This post has 0 verified answers | 92 Replies | 3 Followers
MrAndersen
MrAndersen posted on Mon, Jan 15 2018 10:02 AM
Hello all
This weekend we released a new beta version of the app with native support for sound settings and alarms. Additionally the support part of the app has been revamped to provide more in context help.
Whats new
Sounds settings (M3 and M5 not supported yet. ToneTouch in development)
  • Bass and treble
  • Max volume
  • Default volume
  • Loudness
Alarms
  • Creating, editing and deleting product alarms
Support
  • In context help
  • Better ticket creation
Let me know what you think.
Best regards
Thomas Andersen, Bang & Olufsen
mczac
mczac replied on Mon, Jan 15 2018 10:15 AM
Thomas, could you please also implement a vacation mode, I believe it is more down to the firmware. All alarms suspended, but not deleted until the end of the holidays.
elephant
AU
elephant replied on Mon, Jan 15 2018 11:45 AM
Hi
I reported a bu last night using the App
I hope you got it !
Should I expect to see email acknowledgments ?
BeoNut since '75
Fansastic
The Netherlands
Dear Thomas,
For which models are the sound and alarm setting? I did not find the mentioned settings.
Best regards,
Serge
Teletom
Teletom replied on Mon, Jan 15 2018 12:11 PM
Hello Thomas, I Have tried this morning to control bass and treble om my Beoplay M3 with the new beta app. However I do not notice any differences.
Could it be that a M3 firmware-update is on its way?
Johan
beojeff
USA
ONLINE
beojeff replied on Mon, Jan 15 2018 12:20 PM
Could you provide a setting to compensate for the volume of TuneIn? TuneIn is horribly loud compared to other sources. I'm constantly needing to grab for my remote to reduce the volume.
MrAndersen
@mczac: Suspend all not yet implemented but coming
@elephant: I will take a look
@Fansastic: Alarms is supported on M3, M5, BS1, BS2, A6, A9, Essence MK2, BeoSound Core, BeoSound Shape, BS35
@Teletom: Sorry, the M3 and M5 both have ToneTouch. This is not yet done but coming soon. Bass/Treble will be hidden for these
Millemissen
Flensborg, Denmark
What is the version number of the app by now?
i am on 1.4.0.11269.
You are talking about a version not available for ‘the public’, right?
When will that be released for everyone?
Please clarify - I thought that these settings all were part of the firm-/software of each device.
E.g. I see no problem in creating timers on my Essence or make sound settings.
This has been possible for a while now.
Am I missing something???
jimcaj
Denmark
jimcaj replied on Mon, Jan 15 2018 1:49 PM
MrAndersen:
  • Bass and treble
Bass/Treble will be hidden for these.
Please. Can you confirm that 'real' bass and treble settings will be available on M5?
"Bass/Treble will be hidden for these". What does that mean? That you can toggle the settings on/off, or?
I've heard this rumored since spring 2017.
liviu_o
Hi!
can I get the beta version pls?
Soren
Denmark
Soren replied on Mon, Jan 15 2018 3:23 PM
Hi Thomas
The timer function works really well, but it would be nice if you could add a “once only timer” Otherwise you have to delete the timer if you don’t want it to start same time next week.
I can see that you removed the “configuration” function for NL/ML converter!!! Is that gone for good?
@millemissen, it is version 1.5.0.11550
Søren
MrAndersen
@Millimissen: This is currently only on testflight. Yes this has been possible from the web settings but now it is available natively in the app.
@jimcaj: Yes I can confirm this is coming.
MrAndersen
@Soren: I would love to add "once only" but the products do not support it :(. Yes BLC configuration was removed since the web page was almost unusable on a mobile device.
@liviu_o: Please send me a direct message and I can add you
Soren
Denmark
Soren replied on Mon, Jan 15 2018 5:09 PM
I know you can do the configuration on the webpage, but I think the mobile version worked quite well on an iPad with the old BeoSetup app, it makes me a little worried about the future When development is going quite slow and funkktions is remove within the same month a product is discontinued.
when operating my Beovision 11 I still use the BeoRemote app more often than the Bang & Olufsen app, so i still have to use multiple apps to control my system😔
mbee
Paris, France
mbee replied on Mon, Jan 15 2018 5:29 PM
I tried to use the alarm function but the “alarm type” cannot be modified (standby by default) on my app, for all products (A9 and Essence). I reported this bug via the app.
the NL/ml configuration link is gone.
and I suggest an ergonomic improvement : I think the app would be considerably easier to use in multi room if we could directly switch from one product to the other just by swiping left or right on the product “now playing” screen (the screen with the volume wheel) instead of having to go back to home and change product every time.
Page 1 of 7 (93 items) 1 2 3 4 5 Next > ... Last » | RSS
