H8 and E8 disconnect from Skype
Answered (Not Verified) This post has 0 verified answers | 24 Replies | 1 Follower
ianpugh
ianpugh posted on Tue, Jan 9 2018 1:02 PM
Hello,
I have tried using my E8's and H8's with Skype for Business on my Windows laptop. Every single time they disconnect after a certain time. This happens even when I am speaking so it not because there is no activity.
There aren't any power-saving settings that I can find. Does anyone have any ideas?
Kind regards,
Ian
ChrisTan
Hi All. i'm "glad" to find that i'm not alone ... has there been any progress on the fix for this problem?
i'll check the software updates again.
ChrisTan
glad to find i'm not alone, and it's not a fault with my individual hardware.
i've gone in an updated my H8 software ... latest version is v1.0.5 ... hope the problem goes away now.
will update if this fixed the issue. otherwise assume the unit is still disconnecting from Skype by itself.
richu
Switzerland
richu replied on Tue, Aug 13 2019 1:41 PM
I just updated the sw of my E6 and now have stable connection on microsoft teams (over 1 hour) and my last skype call more than 35 min
seems to fix it
did the Update via BO App
morphium
For me it ia still not working with the B&O E8 with Softwareversion 5.6.0. Everytime after 15 minutes when I talk mit MS Teams or Skype the B&O E8 will disconnect after 15 minutes which is really annoying because that way I can't use them when working for talking.
morphium
morphium
morphium
morphium
morphium
morten2001
Earle:
Not hijacking the thread, but I also experience this with WebEx on my work computer. Seems to only happen when audio is switched to Headset (BeoPlay H8 Hands Free) and not when it's Headphones (BeoPlay H8 Stereo)
Although, I will say, that when I have Spotify playing at low level in the background, it resolves the disconnect issue.
This trick also works for BeoPlay H9 (1. gen)  in MS Teams.
In MS Teams you cannot chose BeoPlay H9 Stereo as speaker and BeoPlay H9 Hands Free as mike - some strange reason... If you do there is no sound in the speakers...
My solution is setting BeoPlay H9 Stereo as speaker and then use my logitech webcam with build-in mic as microphone.
Page 2 of 2 (25 items) < Previous 1 2 | RSS
