Wer hat schon ein Beoplay M3 gekauft?
Seit ihr zufrieden mit dem Klang und der Steuerung?
Gibt es eine Timer Funktion in der B&O App für das iPhone?
Danke
Avantcinema:Hallo Tim, Diese App habe ich schon. Gibt es nicht eine X-App? Stefan
Hi
Yes, I have a Beoplay M3 for three weeks now. It's placed in the bedroom (15 m2) and also part of a 3-speaker multiroom setup.
I use it with the latest sw version (1.4.0.11269) of the B&O X-app and did not experience any annoying issue. The same with the wireless connections: Apple Airplay, Chromecast, Beolink Multiroom and Bluetooth.
Soundproduction is quite sufficient for small to medium sized rooms, it's clear and not too much bass at medium soundlevels. Room adaptation is available via the other B&O-app (Beoplay app) and for me 'corner position' was the best choice.
Personally I do not use a Timer function, but noticed however there are timeroptions in the configuration menu of the X-app.
I am happy with the M3 so far, like it's possibilities, sound and minimalistic design.
Success with your decision!
Teletom
I have no Beolink Gateway. My M3 is çontrolled via the B&O app. I assume you can set the timerfunctions with that app.
Thanks for the info.
Were can I get the x-App.
I can not find it in the App Store .
Hallo Tim,
Stefan
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Hi Tim,
Thanks for the answer.
I will buy an M3 for my bedroom.
Have u got an discount for it from your dealer?
That is the standart way of doing timers, that you have on the other devices as well.
