Beoplay M3
Answered (Verified) This post has 1 verified answer | 10 Replies | 1 Follower
Avantcinema
Avantcinema posted on Thu, Jan 4 2018 2:20 PM
Wer hat schon ein Beoplay M3 gekauft?
Seit ihr zufrieden mit dem Klang und der Steuerung?
Gibt es eine Timer Funktion in der B&O App für das iPhone?
Danke
ngnear
Verified by Avantcinema
Avantcinema:
Hallo Tim,
Diese App habe ich schon.
Gibt es nicht eine X-App?
Stefan
I have an M5 but I assume the M3 behaves similarly.
Click on the product name in the main menu to highlight it, then again to bring up the details.
- Konfigurieren
- Uhr und Timer
- Alarme
Gruss
Tim
Teletom
Hi
Yes, I have a Beoplay M3 for three weeks now. It's placed in the bedroom (15 m2) and also part of a 3-speaker multiroom setup.
I use it with the latest sw version (1.4.0.11269) of the B&O X-app and did not experience any annoying issue. The same with the wireless connections: Apple Airplay, Chromecast, Beolink Multiroom and Bluetooth.
Soundproduction is quite sufficient for small to medium sized rooms, it's clear and not too much bass at medium soundlevels. Room adaptation is available via the other B&O-app (Beoplay app) and for me 'corner position' was the best choice.
Personally I do not use a Timer function, but noticed however there are timeroptions in the configuration menu of the X-app.
I am happy with the M3 so far, like it's possibilities, sound and minimalistic design.
Success with your decision!
Teletom
Avantcinema
Hi Teletom,
Have u a Beolink Gateway Tod Control the M3?
Can i set the timer with the B&O App?
Stefan
Teletom
I have no Beolink Gateway. My M3 is çontrolled via the B&O app. I assume you can set the timerfunctions with that app.
Teletom
Avantcinema
Thanks for the info.
Were can I get the x-App.
I can not find it in the App Store .
ngnear
Hier wirst Du fundig...
https://itunes.apple.com/de/app/bang-olufsen/id1203736217?mt=8
Tim
Avantcinema
Hallo Tim,
Stefan
Fansastic
The Netherlands
This is the newest app, at introduction referred to as X app
ngnear
Avantcinema:
Hallo Tim,
Stefan
- Konfigurieren
- Uhr und Timer
- Alarme
Gruss
Tim
Avantcinema
Hi Tim,
Thanks for the answer.
I will buy an M3 for my bedroom.
Have u got an discount for it from your dealer?
Stefan
Millemissen
Flensborg, Denmark
ONLINE
That is the standart way of doing timers, that you have on the other devices as well.
Page 1 of 1 (11 items) | RSS
