Connecting Beolab Penta III to a Beosystem 5500
Not Answered This post has 0 verified answers | 5 Replies | 3 Followers
Bob
Tilburg
Bob posted on Tue, Jan 2 2018 11:11 PM
For the short question skip to the bold part below.
I have an almost new Beosystem 5500 en I have a set of mint Beovox Penta connected to them. I also bought a set of Beolab Penta III just because I needed to have them (The brochures I had under my pillow as a youngster). They were in a less that perfect condition (optically 100%, technically 70%). I stored them upstairs until the guy at B&O told me these speakers were superior to the passive Penta's. So I repaired them to be like new and connected them to my Beosystem 9300 upstairs. Think the guy at B&O was correct. The amps make the speakers superior.
BLong story short: can i connect my active Penta;s to my 5500 amp? I cannot connect them through Powerlink (5500 amp hasn't got the connections) and i fear that the Speakerlink connection won't fully use the built in active amp's of the Penta's. Would a Neosound core solve the problems? Or do I need to look for a fully functioning Beosystem 7000?
Downstairs: Beolab 9 / Ouverture / LG 55 inch Oled
Upstairs: Beosystem 6500 (Beomaster, Beocord, Beogram, Beogram CD) / Beovox RL 140 / Boevox Cona
Not using: Beocenter 9300 / Beovox RL 6000
kallasr
Germany
ONLINE
If Beomaster 5500 has speakerlink output and Beolab Pentas have speakerlink input why shouldn't it work?
Powerlink carries the same signal (plus a little more Information (trigger on off/two audio channels and data Information).
Get some cables from soundsheavenly.com - one of the site's sponsors - and give it a try.
Ralf
Bob
Tilburg
Bob replied on Wed, Jan 3 2018 1:45 PM
That is what the dealer told me. The 5500 amp won't be shut off completely. But from your answer I get that the displays in the speakers won't work with Speakerlink?
kallasr
Germany
ONLINE
Sorry, but I am not sure. I think they will work...
Peter
Earsdon
Peter replied on Wed, Jan 3 2018 6:47 PM
They will work - the extra contacts carry the display info.
Peter
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Ralf,
Thanks for the mention!  Yes, you can use Speakerlink cables and the speakers will work fully (using their own amps) and the displays will operate correctly.  I can build these cables in any length required:-
https://www.soundsheavenly.com/speakerlink-4-pin-din-cables/19-speakerlink-compatible-4-pin-din-cables-for-older-bo-speakers-sold-as-a-pair.html
Kind regards, Steve.
Steve.
Page 1 of 1 (6 items) | RSS
