Playmaker Vs Google Audio Chromecast
This post has 13 Replies | 1 Follower
h1npw
West Bridgford, Nottingham.
Posts 1,125
h1npw Posted: Fri, Dec 15 2017 10:08 AM
Hi
I'd like to start a discussion on the pros and cons of each device. I use Chromecast in several different systems, and I'm very happy with how it performs. Would a Playmaker offer me anything more?
Cheers
Nigel
Guy
Buckinghamshire
Posts 2,236
ONLINE
Guy replied on Fri, Dec 15 2017 10:49 AM
It depends on the application in question, of course.
But Playmaker offers:
  • AirPlay (as well as DLNA)
  • IR control from B&O remote
  • Powerlink output (that will switch on connected Beolabs)
  • Variable level output (if operated in that mode)
  • Additional separate analogue input.
  • User interface (touch sensitive front panel for volume and mute)
Guy
Buckinghamshire
Posts 2,236
ONLINE
Guy replied on Fri, Dec 15 2017 11:08 AM
I forgot a couple of other Playmaker advantages:
  • Ability to hard wire network through RJ45 (EDIT: Without need for an adaptor Wink)
  • Standard 'figure-of-eight' power connection - no need for adaptors or separate power supplies.
  • Stylish looks Big Smile
Zwets
Posts 111
Zwets replied on Fri, Dec 15 2017 12:53 PM
The Chromecast can also be connected to a wired network with optional adapter.
Guy
Buckinghamshire
Posts 2,236
ONLINE
Guy replied on Fri, Dec 15 2017 1:05 PM
Zwets:
Oh yes, I didn't know that.  I see that you can purchase a separate ethernet adaptor that enables the Chromecast's micro-usb port to double up as both power and Ethernet.
Millemissen
Flensborg, Denmark
Posts 13,913
How about a Playmaker with a Chromecast Audio connected to the line-in!
The line-in of the Playmaker has autosense - means the playback via a Chromecast Audio will start automatically.
Aussie Michael
Melbourne, AU
Posts 3,577
h1npw:
Hi
Cheers
Nigel
Only if you’re connecting “traditional” B&O speakers through the RJ45 to RJ45/powerlink cables.
Marc75018
Posts 2
Marc75018 replied on Wed, Apr 7 2021 12:49 PM
Hello to all of you,
Please excuse my question if it has been already answered to but I did not find the reply.... I Have a pair of BEOLAB 18 with a Transmitter 1. I use for the moment a Chromecast Audio linked via optical port to the Transmitter 1. I also have an old Playmaker 1 but I bought the Chromecast because a Bang & Olufsen dealer told me it streamed better quality music...and I use QOBUZ...but I miss the possibility to skip songs as well as to adjust the volume and to mute it whether it is on the Playmaker 1 or my old Beolink 1000...
Could anybody tell me if the information I was given is correct that is to say that the sound quality is not as good with the Playmaker than with the Chromecast because I have read that DNLA could be comparable to it ? And please tell me in that case what should I do ?
Thank you
Marc
mbolo01
Louannec - France
Posts 1,886
ONLINE
mbolo01 replied on Wed, Apr 7 2021 2:10 PM
Assuming QOBUZ streaming (up to 192 kHz / 24 bits) is your only source, i.e. no DLNA server in your setup, no Airplay, I would keep the CC Audio that, if not too old, can handle high-resolution audio up to 96 KHz / 24 bits and you'll keep the volume/track control from your QOBUZ app.
I don't know the exact specs of the Playmaker, but if you prefer to stream Airplay to it from a QOBUZ device, e.g a phone, a tablet or anything else, then expect 48 KHz /  24 bits, which is under the CC Audio HiRes specs.
That said, it's worth to note that according to Beolab 18 specs, when wired the speakers are supporting sample rate 32k, 44.1k, 48k, 96k/PCM16-24 bit, and when using wireless connectivity, the supported sample rates are for Wireless Power Link (24 bit / 48 kHz) and WiSA (24 bit / 96 kHz). I guess the TR1 uses WPL.
In summary, if you want to get the best of your BL 18 / QOBUZ, and if your ears can make the difference, then a high-end QOBUZ compatible DAC / Streamer with each BL 18 wired to it would be the best technical solution, I guess. Otherwise, what you have is good IMHO, unless someone else in this forum has another opinion to share.
Svenni
Berlin, Germany
Posts 40
Svenni replied on Wed, Apr 7 2021 6:14 PM
When I first got my Beoplay S8, I connected it to my LG E9 with TOSLINK and streamed through the Spotify app on the TV while I was searching for a used Chromecast Audio, because having the TV on just for music isn't ideal. When I finally got one and connected it to the second TOSLINK input on the Connection Hub, I noticed a difference in the audio quality (using Spotify), it sounded more flat which was pretty disappointing and I've never used it since. I read on avforums that streaming Spotify to Chromecast Audio is for some reason limited to 256kbps AAC, not 320kbps OGG Vorbis.
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
Millemissen
Flensborg, Denmark
Posts 13,913
That is correct!
However, more important - and not something that everyone knows - you have to turn Full Dynamic Range on in the audio settings of the CCA device.
This makes a noticable difference with better speakers.
mbolo01
Louannec - France
Posts 1,886
ONLINE
mbolo01 replied on Wed, Apr 7 2021 9:40 PM
Millemissen:
Indeed, tks Millemissen
Svenni
Berlin, Germany
Posts 40
Svenni replied on Fri, Apr 9 2021 1:07 PM
Yes, but the option is only for the analog output, it makes a huge difference but it's still noticeably worse than a Spotify Connect player.
There is however a workaround (I haven't tried myself) using Logitech Media Server streaming to the CCA that enables the full 320kbps.
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox RL 6000
mbolo01
Louannec - France
Posts 1,886
ONLINE
mbolo01 replied on Fri, Apr 9 2021 1:16 PM
Svenni:
If it is the case, then the CCA analog port can be used to connect to the TR 1 RCA In.
We are talking QOBUZ here, not Spotify.
Page 1 of 1 (14 items) | RSS
