NL/ML converter discontinued?
Not Answered This post has 0 verified answers | 45 Replies | 4 Followers
PhilLondon
London
PhilLondon posted on Tue, Dec 12 2017 4:44 PM
Hi all,
I heard the NL/ML converter was being discontinued. Is that true?
Philippe
Beoworld app with direct photo upload and emoticons. Other apps: ConsltThe Story Mouse
frog
Camberley UK
frog replied on Sat, Dec 16 2017 1:24 PM
Steve,
thanks for the info. Very useful. I’d be a bit concerned that the remote control buttons wouldn’t necessarily match the sources correctly (although I really haven’t looked into this) and maybe the default safest position is to have a MLC anyway.
Im still struggling to understand though why you would need more than one ML/NL converter in a system if the MLC was just bridging two networks, yet I see that some layouts have more than one.
Sweden
Martin replied on Sat, Dec 16 2017 2:49 PM
Hi Steve, I have BV Eclipse Beolab 5and Beosound 5 in mainroom.in two linkrooms I have Beolab 3500. What I know is that to still be able to use my linkrooms I need an audiomaster which is Beosound 5. I have my beolab 5 connected directly to the Eclipse with a Almando powelinkswitch with powerlink from Tv to input 1and powerlink from Beosound 5 to input 2 (in the switch). Then I have ML from Beosound 5to the linkrooms. What I can see there is not a better solution than this. What do you think Steve?
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Frog,
Yes, one issue from using a direct cable connection instead of the NL/ML Converter is that the source buttons may not always match the actual soruce being used.  However, I would personally see the c. £600 saving as being a worthwhile trade-off - this could potentially cover the cost of a pre-owned pair of Beolab speakers for a link room.....
Hi Martin,
I haven't tried the Almando switch myself so I can't comment on this.  However, if this works well and suits your needs then this is probably best left in place.  If you hadn't already purchased this then I would probably have suggested linking the Beomaster 5 digital output to the speakers and the Eclipse RJ45 output to the Powerlink input of the speakers, which should mean that the Almando switch may not be needed.  This will still give you music from the Beomaster 5 to the link rooms and both music and TV sound in the main room.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Ola Hansen
Sweden
Steve is the man!
Go Steve go!
Sweden
Martin replied on Sat, Dec 16 2017 10:56 PM
Hi Steve, All TVs after Beosystem 3 (bv avant, bv14, bv eclipse) will not forward the cd-command to the labs 5 which should open up the digital IN. Thats why I must use the beomaster5 cd-command data (thru powerlink cable directly from bm5) to the labs 5 in order to use the digital feed from bm5 to the labs5.
Thanks Martin,
That is an interesting point.  I had thought that setting the speakers to Option 1 (for a non-B&O audio system and a B&O TV in the same room) would resolve this....  I will do some testing and see how the speakers behave.
Steve.
Beer_Baron
Australia
Silver Member
I remember reading the manual where it said in option 1 it will automatically take coax input over analogue. Didn't realise you could still feed in Powerlink as well. Will the volume control still be via PL in option 1?
BV6-26, BV7-40, BL7.4, BL3, BL5, BS9000, BC1, ES1, Beo4, BeoPort
Sweden
Martin replied on Mon, Dec 18 2017 5:38 AM
Hi Beer Baron,
You can not feed labs5 with powerlink signal when they are in option 1. Powerlink only work in option 0. Thats why an Powerlinkswitch can be useful.
best regards
Thanks Martin,
The Beolab 5s seem to be able to take S/PDIF and Line inputs when in Option 1, so potentially the TV signal could be fed to the Line input instead of Powerlink.  Not ideal, but workable.  The other option could be the Powerlink switch, using the speakers in Option 0.
Steve.
petermc
Australia
Does anyone know if a NL/ML converter will pass Spotify Connect from an Essence and push it to a Masterlink network.
From what I read I don’t think it will but thought I’d check.
Peter
Stan
Stan replied on Wed, Dec 20 2017 4:56 PM
Spotify can only be passed to other licensed Spotify products.  Since the NL/ML converter isn't licensed for Spotify, you cannot push Spotify to it.
You can go in the other direction - if you have a Spotify streamer (e.g. Chromecast) connected to the AUX input of your ML audio / video master, this can be distributed into your NL network by the NL/ML converter since it is just "audio" - no one knows if it is coming from Spotify or not.
Stan
petermc
Australia
Hi Stan,
Thanks for the detailed response which is a great help.
Peter
beolion
Hi all
I assume that the delay box is also discontinued?
Also, I remember there was a thread some time ago explaining that there was an echo when playing the same source on both NL and ML at the same time, but I cannot find that thread.
Can someone please shortly explain the downside(s) or limitation when integrating NL with ML?
Before I go out and buy a NL/ML converter and a delay box.
Thanks.
Leo
koning
holland
koning replied on Sat, Dec 23 2017 8:11 AM
I have one for sale
Millemissen
Flensborg, Denmark
beolion:
Is it this one, that you mean?
http://forum.beoworld.org/forums/p/6073/135722.aspx#135722
Page 3 of 4 (46 items) < Previous 1 2 3 4 Next > | RSS
