BeoSound 2 - MP3 Player 2001
Not Answered This post has 0 verified answers | 7 Replies | 3 Followers
Mr 10Percent
So West, Its Now East
Mr 10Percent posted on Sun, Dec 10 2017 11:31 AM
I've just found my old Beosound 2 MP3 Player and dock.
After a quick Dremmel polish it looks literally brand new.
However, I seem to have lost the power adapter. IIRC, this was a plug (UK G-Type) with a 5 or 6V DC conversion and an RJ11 output to the BS2.
1. Does anyone know the full specification of this type of power adapter (and where I could get one)
2. Does anyone know the wiring of the docking station so I could simply cut the RJ11 connector off and (hopefully) replace it with a USB connector?
Regards
lausvi
Helsinki - Finland
see attached photo Smile
Looking at my original cable, the two wires going to the RJ11 are white and red, red being the positive.
Ralf
Hamburg Germany
Ralf replied on Mon, Dec 11 2017 12:30 PM
I am still using the Beosound 2
The internal battery could be replaced with a cheap LiIon from a Samsung telephone in case it is down and your dealer has no replacement.
Mr 10Percent
Thanks for the insight. Your respective information helps a lot.
10
petermc
Australia
I think I have a travel adapter for this which is basically the power supply and a clip which you can have.
Will check tonight and see if I can find it
Peter
petermc
Australia
Found the box - with nothing in it!
Will have a better look this weekend after the work Christmas parties are over.
TWG
TWG replied on Thu, Dec 14 2017 7:55 AM
Ralf:
Would you mind telling us which battery exactly can be used with the Beosound 2?
Mr 10Percent
Peter,
Thanks for the consideration. I probably have my own here somewhere in one of dozens of loft boxes. I think the simple solution is to wire a USB cable in lieu of the RJ11. I surmise the BS2 was built around USB1.0 and thus needed separate connects for power and date. In a world of USB2 and 3, power over USB is common now.
Thank you all the same.
10
Page 1 of 1 (8 items) | RSS
