Issue With BeoSystem 2300 On MasterLink System
Not Answered This post has 0 verified answers | 7 Replies | 0 Followers
striker27
striker27 posted on Thu, Dec 7 2017 7:06 AM
I have wired my 2300 BeoSystem into my Masterlink system.......  I received the cables from Steve yesterday and was anxious to get everything up and running.  I have a Beosound 4000 as a master and a few passive and a Beolab 3500 hooked into my system....
Here goes from what I was told with the proper cables which is a cable from the 2300 Beosystem Aux port to a 1612 plugged into the Powerlink socket.  I should be able to plug the 1612 into my  Masterlink system and be good to go.   I did set the active to option 4 and when I hit A.Aux in my BEO4 remote LIST I get no music????  What am I doing wrong?   I have tried to Link to RADIO.  But no luck with any sound.......   What am I doing wrong????
How do I LINK to RADIO?
AM I correctly setting the 1612 to Option 4??     How do I do this?
Like I said I have a BEO4 remote and am really lost here..
Any help???
Guy
Shropshire
Guy replied on Thu, Dec 7 2017 12:31 PM
The BS2300 connection should be to the AUDIO AUX LINK socket of the 1612.
striker27
Yes I have the unit connected to the Audio Aux Link port on the 1612
striker27
striker27
striker27
Why does that happen to me!!!!
Guy
Shropshire
Guy replied on Fri, Dec 8 2017 9:33 AM
striker27:
If you get frustrated with the speed of response, perhaps you hit the POST button more than once - this often happens!
But back to your question.  Haver you had a read of this post in the archived forum? http://archivedforum.beoworld.org/forums/t/24667.aspx
I think the over-riding problem could be that BC2300 is too old a system to be set up as a 'slave' in a masterlink network.
striker27
I was emailing Steve at Sounds Heavenly he gave a solution to use a B&O active unit. Sadly at present I only have a 1612 not a 1638.  Hope fully I can still get this all set up...
Page 1 of 1 (8 items) | RSS
