Beovision 11 streaming issue
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
BenSA
Durban, South Africa
BenSA posted on Tue, Dec 5 2017 8:04 AM
Hi
I have been able to stream movies, photo's etc from my phone directly to the BV using the Allcast app. Now it longer works, I have tried different apps, none of them pick up the BV anymore. I suspect its from the last software update. The BV connects to the WiFi and webmedia works.
Any clues?
Thank
Dyssegaard
I’m having the same problem with the Glider app. It worked before the last bv11 sw update, but now I cannot select the bv11 as output device. I have tried to disable the dmr function on the bv11 and the enabling it again, but no luck.
Best regards - Dyssegaard
Living room: Beovision 11-40, Beolab 8000 (front), Beolab 3 (back), Beolab 2 (sub), Apple TV 4, Chromecast. Dining room: Beoplay M5. Home office & garden: Beolit 12. Travel: Beoplay H8, Beoplay A1.
BenSA
BenSA replied on Fri, Dec 8 2017 7:11 AM
Yes, I've tried everything, no luck. Since I am not the only one with an issue, then its definitely a software issue. I did e-mail B&O, hopefully they get back to me.
Page 1 of 1 (3 items) | RSS
