BeoVision 4-50 Stuck on Language choice menu at power on
Not Answered This post has 0 verified answers | 1 Reply | 2 Followers
rtww2k
rtww2k posted on Mon, Mar 5 2012 4:03 PM
We just got a BeoVision 4-50.  It was recently deinstalled from a large setup, and was connected to a BeoSystem 1.   So at this point the Beovision 4-50 is not connected to anything, only power.  I powered it on  to see if it is working.  It shows the initial menu of language selection (English/etc/etc).  Pushing any of the front panel buttons on the unit changes NOTHING.  Using the remote control changes NOTHING.
Question - is this normal behaviour, or is there a problem here?
I am familiar with (non B&O) plasma screens,but I do not know much about B&O systems. Normally you can browse through menu/etc using a remote or the front buttons even with no hookups, but this unit refuses to repsond to either.  Do I have to have this connected to a full B&O system to test the display and verify it is working OK?
Any feedback/input would be helpful, thanks!
kallasr
Germany
If you just have the screen you would need the original panasonic remote and remove the brezel from the panel so that the ir reciever can recieve the signal....
So, best would be to hook up the beosystem 1 (with vga? and rs-232? cable) with an ir eye connected to the beosystem - then the beo 4 remote will work.
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
Page 1 of 1 (2 items) | RSS
