Parts for BG 6002/6006/8000/8002/TX and for 4002
This post has 3 Replies | 0 Followers
ipaul
Posts 422
ipaul Posted: Wed, Nov 8 2017 6:15 AM
Hello all, for the BG6006 and similar i am looking for:
-the small transparent slider button for the stylus pressure on the tone-arm
-a working IR sensor unit based at the end of the transport axis, (counting turns).
For a BG4002:
-the perpex lid
-complete audio output cable with the DIN connector for the newer version BG, that is with the rectangular black connector (inside the BG).
ipaul
Posts 422
ipaul replied on Thu, Nov 9 2017 2:58 PM
Sorry, the IR sensor is not placed in the TX or 6002 i just noticed in the doc..so BG6096/8000/8002 then.
Dillen
Copenhagen / Denmark
Posts 12,321
ONLINE
Dillen replied on Thu, Nov 9 2017 6:25 PM
The opto - it's usually the sender LED that burns out.
If that's the case, you can fit a OP240A instead.
At some point Frede (Classic) had some new BG400x dustcovers made. Perhaps he can still provide one - worth asking him.
ipaul
Posts 422
ipaul replied on Tue, Nov 14 2017 9:15 PM
Thanks Martin, indeed it seems the sender diode, will check the type you mention.
Page 1 of 1 (4 items) | RSS
