Beovision 8-32 MasterLink Module.
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
Tucker
Ponte Vedra Beach, FL, USA
Tucker posted on Sun, Oct 22 2017 9:21 PM
Soooo... I just got my first BV.  I was told by the seller that it had a MasterLink connection, however when I got it there was no MasterLink.  I think the seller saw where it said "MasterLink" on the back and assumed it had it.  I had planned on using this in my guest room linked with my BS9000 and a pair of BL4000.  Is it possible, and or easy to add a MasterLink module to the BV8-32?  Any idea where I can find one of so?  Maybe there is an easier solution for linking it all together?
Thanks in advance for any help!!!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Tucker
Tucker replied on Mon, Oct 23 2017 7:03 PM
So just out of curiosity, I unscrewed the blank plate where the Masterlink connection should be and pulled out the "tray".  From the looks of it I could probably get a masterlink unit and slide it in?  Does anyone know if it would be "plug and play"?  I think the hardest part is going to be finding the correct part...
Thanks for any help!
-Tucker
Beobuddy
Utrecht, The Netherlands
The BV8-32 needs to be flashed after placing a ML module. It doesn't work out of the box.
Tucker
Tucker replied on Mon, Oct 23 2017 7:50 PM
Beobuddy:
Thanks for the info! Is this something that must be done by B&O service or is it something I could potentially do?
I really appreciate the help!
-Tucker
Page 1 of 1 (4 items) | RSS
