Beogram CDX CDX2 CD 3300 gear for lid broken
Not Answered This post has 0 verified answers | 54 Replies | 7 Followers
ethuijs
ethuijs posted on Sun, Oct 15 2017 8:59 PM
I.am repairing a Beogram CD 3300 for a friend. The lid won't open. Only by hand. I already  have a new belt but when I opened the CD 3300 I discovered that also the yellow gear is broken (See the yellow gear on picture, CDX or CDX2 has the same part). Does anyone have such a part or knows where to get it?
Beobuddy
Utrecht, The Netherlands
Printed with 0.25 nozzle with Nylon an 0.4 nozzle for PVA support (solvable in water) with very nice surfaces and details.
Nylon should be better resistant for forces and more durable.
It's rather difficult to take (iPhone) pictures from small and transparant parts.
Evan
USA
Evan replied on Mon, Jul 15 2019 10:28 AM
Nice nylon parts! What printer are you using?
I have a roll of PVA sitting around for support but wouldn't you know it, my 2nd extruder has given up the ghost. Need to fix that first.
Beo4 'til I die!
Beobuddy
Beobuddy replied on Sat, Jul 20 2019 11:40 AM
I have an Ultimaker 3 with 2 extruders.
Next to that I have placed a Printdry filament dryer. Nylon and PVA require a dry filament as these absorbs moisture.
Muzzwell
Would you be prepared to share the file or print and supply the part at a charge of course. I am pretty stuck and have been searching but no luck.
Beobuddy
I can supply the part.
PM me for information.
Jayone
Jayone replied on Sun, Dec 22 2019 1:43 PM
Hello
have you still gear as mine is broken ? Regards
Jayone
Hello
Cora2
Cora2 replied on Sun, Jan 12 2020 4:48 PM
I have the same part broken on my CDX-2.
Found the part on ebay and ordered it.Although the title does not list the CDX2, the description does.
https://www.ebay.de/itm/Tray-gear-GRUNDIG-CD7550-PHILIPS-CD104-CD304-MARANTZ-CD-34-BO-Beogram/254444939206?hash=item3b3e19a7c6:g:qWYAAOSwdZJcW9fH
Coen
Beobuddy
Beobuddy replied on Wed, Jan 15 2020 11:35 AM
Yes, I can supply the gearwheel. (I don;t sell on ebay).
Map27
Map27 replied on Wed, Feb 12 2020 4:45 PM
Hello I need one for my beogram  cd3300
how can de do ?
thanks
Map27
Map27 replied on Wed, Feb 12 2020 4:49 PM
I need also the end contactor Well I don’t know the name in English This is the component connected.
Do you know where I can find it ?
PerWedel
Are you able to support me how to remove the yellow gear?
The white gear blocks the way and I don't know how to remove the white gear.
PerWedel
Are you able explain me how to remove the yellow wheel?
ZweiKappa
Hi Beobuddy
I have just joined Beoworld and browsing through the archive I came across your post from last year.
I am currently trying to rehabilitate my old Beogram CDX and discovered the lid drive gear is stripped and needs replacing.
So I would like to know if you are still in the business of 3D printing this gear and what would you charge for it.  I am in Australia so you should also allow for slow overseas postage.
Thanks in advance
Pindsen
Denmark
See:
https://beolover.blogspot.com/2019/12/beogram-cd-x-restoring-door-motor.html
/Pindsen
Page 2 of 4 (55 items) < Previous 1 2 3 4 Next > | RSS
