Status of Known Issues
This post has 30 Replies | 2 Followers
Keith Saunders
Little Ann, Hampshire, United Kingdom
Posts 5,097
Keith Saunders Posted: Wed, Oct 4 2017 10:34 AM
This page will be updated when the status of any of the documented known issues below changes.
Background
Over the last few months (April to September 2017) I have made a large number of changes to the Beoworld web site and forum to fix software bugs particularly in the forum and created new functionality such as the Beoworld Members Portal.
The Beoworld web Site and Forums have been moved to a new and more powerful server running Windows Server 2012 and IIS 8.5. The forums databases have been rebuilt and indexed which has increased the speed by at least 50%. The servers now have a combined disk space of 20TB meaning 20,000 GB
Security remains a major focus and the Beoworld servers are protected by two enterprise firewalls along with a separate DDoS (Distributed Denial of Service) attack protection. Our security protection is formally rated as "A" see below
Known Current Issues
  • Members using Safari (any version) typically on a Mac cannot use the "more" pull down or insert images when writing a new post unless they change the "User Agent" via the "Develop Menu" within Safari. If the member changes the "User Agent" to any other agent everything works correctly. Whilst I have not done an in depth investigation into this problem it appears to be that Safari does not correctly implement the international standards, hence why all other browsers do not have this problem.
  • When the Microsoft Bing bot search engine crawls the Forum it causes several "Unhandled Exceptions" on the forum and the forum restarts. Users do not see these errors and the only impact is that the forum restarts which typically takes 15 seconds. It happens because Bing uses illegal http commands on the forum. Typically happens 2-3 times per 24 hours. Requests to Bing to stop crawling using these commands are ignored. Therefore I may in the future block all Bing access requests.
  • Conversation messages do not put the correct entry in the subject field most of the time.
  • The Beoworld web site does not have a "site.xml" mapping used by Google which allows it's bot to index pages more effectively.
  • The background search task intermittently fails trying to write a NULL character into the database. There should not be any NULL characters in a search. Does not affect users, its just logged as an error.
  • Spammers are trying to access port 3389 (RDP) with thousands of requests per minute. IP addresses being added to firewall as they happen.
If you notice something which is not working correctly, then please do let me know..
Regards Keith....
Fansastic
The Netherlands
Posts 187
Fansastic replied on Mon, Jan 29 2018 6:33 PM
Dear Keith,
Since a few days I encounter problems loading content in the beoworld app. Only the first vew messages load and I cannot post anymore messages.
Is there a problem you are aware of? I use the iOS app on iphone x.
Thanks,
Best regards,
Serge
Keith Saunders
Posts 5,097
The only thing that has recently changed is the "Security Certificate" which is now an "Enhanced Security Certificate" meaning you will note next to theURL in most browsers its green and of course it starts with HTTPS://
I posted this from an IOS PC not an iPhone because I do not own one
Regards Keith....
tobeyone
Posts 85
tobeyone replied on Mon, Jan 29 2018 7:43 PM
It’s the app that is the problem not the website.........
lausvi
Helsinki - Finland
Posts 633
lausvi replied on Mon, Jan 29 2018 8:32 PM
Since about yesterday or so links to the forums (links in forum notification emails, google results to forum threads) don't work anymore but forward to the forum front page.
lausvi
Helsinki - Finland
Posts 633
lausvi replied on Mon, Jan 29 2018 8:33 PM
Also after posting this I was forwarded back to the main forums page, also edit won't work (goes to error page).
Millemissen
Flensborg, Denmark
Posts 10,132
lausvi:
Just tried that - with same result!
Millemissen
Flensborg, Denmark
Posts 10,132
lausvi:
This also just right now.
(I am using Safari on an iPad, latest sw).
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 8:14 AM
same phenomenon here.
I changedall my links from http:// to https:// and all is well again.
   hmmmmm.
hx
Keith Saunders
Posts 5,097
hemenex:
   hmmmmm.
Caused by the automatic redirect which I have corrected, I think,
All web addresses now redirect to an URL starting HTTPS://
Regards Keith....
Millemissen
Flensborg, Denmark
Posts 10,132
Right now ——
clicking a forum in all forums (for example the nordic) brings me to the Home site, the one with all activities (and not to the wanted sub forum).
Tried a couple of times now with the same result.
Kind of odd ;-(
Keith Saunders
Posts 5,097
Millemissen:
Interesting, if I click on Nordic, I get Nordic as expected. I have made a change
Regards Keith....
Keith Saunders
Posts 5,097
Millemissen:
Right now ——
Kind of odd ;-(
Can you please try again. I have made some changes to the automatic redirecting code
Regards Keith....
the_o_master
Posts 762
Silver Member
... and the links to the pics posted in the threads seems to disappeared too  Sad
Vintage Bang & Olufsen
Keith Saunders
Posts 5,097
the_o_master:
I don't see any broken links from pictures posted. Can you please post a link to an example?
Regards Keith....
the_o_master
Posts 762
Silver Member
I looked today to one of my older post and the pictures were gone. Now I looked again and there are visible again. Maybe it was only an issue with my browser... Anyhow, no problem anymore.Thanks Keith!
Millemissen
Flensborg, Denmark
Posts 10,132
Keith Saunders:
Millemissen:
Right now ——
Kind of odd ;-(
Now it works again ;-)
Thanks,
Peter Pan wrote to me this morning and asked, if I also had this issue - so not just me.
I’ll give a feedback later, if it is ok with him now, too.
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 2:11 PM
well, it works - sort of...
I can't edit my post above, it takes me to the "The FORUM, BLOGS, MEDIA & WIKIS are currently unavailable" page.
And let's see where I'm going to land on posting this
  hx
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 2:13 PM
ok, posting went well, landing back here.
editing still the same "unavailable" page
   hx
Keith Saunders
Posts 5,097
hemenex:
   hx
I don't see this as I can edit any page without problems.
Can you please send me or post a screen shot of unavailable page including teh header showing teh URL
Regards Keith....
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 3:02 PM
here it is:
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 3:10 PM
or should have been there Sad
pasted printscreen in here shows in "compose" but disappears in "Preview"
so here uploaded:
Keith Saunders
Posts 5,097
That is the "Catch all" error page not an unavailable page.
What was the URL you were going to when you got the error?
Regards Keith....
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 3:17 PM
Keith Saunders:
clicking on "more" in one of my own posts and selecting "edit" brings me there...
Keith using more then Edit to add this line using Firefox
Keith Saunders
Posts 5,097
hemenex:
When you are on the post you wish to edit can you please press the "Refresh" button on your browser and then try edit again
Regards Keith....
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 3:28 PM
same.
I even logged out and then in again as I remember you sometimes recommend this.
BTW: using Firefox 52.6.0
Nope.
Using Edit
Keith Saunders
Posts 5,097
I have edited two of your posts with Firefox without error. I am using Firefox version shown below..
Can you please try using another browser such as Chrome
Regards Keith....
hemenex
Posts 534
hemenex replied on Tue, Jan 30 2018 4:05 PM
no other browser installed.
Testwise allowed all cookies - no change.
But probably a problem of my XP and/or Vista as it's no longer supported.
Looks like my own problem; just ignore it further; I can live with adding instead of editing Wink
Thanks,
   hx
Ferdinand
Malmö, Sweden
Posts 387
Ferdinand replied on Tue, Jan 30 2018 5:12 PM
Dear all,
I would be of opinion that there still is some sort of issue with both website forum as on app.
Older posts appear as new, H8i & H9i topic dissapeared and on the app the forum topics are listed repeatedly.
On the app I wasn't able to post just now.
I am on FF on my PC but site looks similar on Chrome. On IOS I have 11.1.2 and already twice deleted and reinstalled the app.
All the best with resolving, I wish I could help but I can't :-( that would make thing really worse.
Keith Saunders
Posts 5,097
The Beoworld App was not created by Beoworld, but Phillip, the creator is currently doing an update as he stated in the other thread HERE
Using Firefox on your PC should work without problems, but I will look again at the H8i & H9i topic you highlighted
Regards Keith....
Ferdinand
Malmö, Sweden
Posts 387
Ferdinand replied on Tue, Jan 30 2018 5:35 PM
Thanks Keith,
I am aware that Beoworld App is not Beoworlds, so thanks for pointing me to Philips thread.
Another thing is that older topics have been assigned new dates, or am I talking rubbish now. Tuckers Thread about Beosound 8 problem is now dated January 29, but wasn't that posted long time ago? The whole order of topics just seems a bit odd. Could it be that many (maybe ALL) topics have been assigned new dates?
A final request, in the header (subject) can you add January 2018 please?
Thanks again Keith for all the work done, it is really appreciated.
Page 1 of 1 (31 items) | RSS
