Deezer HiFi
This post has 107 Replies | 8 Followers
Liverpoolpete
Posts 11
I have a moment with BL20s.and Beogram 9000
I purchased a line in cable to connect the iPad direct to the moment.
When I play from the Deezer app it shows HQ in the album artwork, not flac as has been reported elsewhere.
I haven’t seen any change in the B&O app.
I prefer to use the line in for my Beogram.
The line in sensitivity adjustment on the moment seemed to make no difference to the volume setting. Beogram 9000 is fine, iPad connection from the headphone socket is very low.
Has anyone else seen this?
I haven’t heard a massive difference between HQ from Deezer and playing through the B&O app, but with the messing around with connectors, and input sensitivity settings , I have not given it a proper test. However, when I get the opportunity to have a good listen , if I don’t get a difference I will downgrade my Deezer subscription,
Still waiting for firmware 2.2 🎶
B&O fan since 77.
Flere
Netherlands
Posts 345
Flere replied on Mon, Nov 20 2017 6:35 PM
Liverpoolpete:
When you have DeezerHiFi then on the iPad or iPhone you will not get FLAC but only the HQ.
As far as I know HiFi is only supported on selected Audio equipment. Luckily B&O is among those since a few days. Lets have a Party !!!
So if you use your iPad as source then you will get HQ not FLAC.
- Flere
smile and enjoy the moment
Flere
Netherlands
Posts 345
Flere replied on Mon, Nov 20 2017 6:39 PM
Check out Deezer support page.
https://support.deezer.com/hc/en-gb/articles/115004588345-Deezer-HiFi
- Flere
mbolo01
Louannec - France
Posts 1,972
mbolo01 replied on Mon, Nov 20 2017 9:51 PM
Deezer HiFi + ECM Catalogue on Deezer, what else?
Flere
Netherlands
Posts 345
Flere replied on Tue, Nov 21 2017 3:20 AM
mbolo01:
Is there an easy way to browse the ECM catalogue on Deezer?
- Flere
mbolo01
Louannec - France
Posts 1,972
mbolo01 replied on Tue, Nov 21 2017 8:35 AM
Flere:
Not that I’m aware of. I have tried to search for ECM and a couple of playlist came up but not very helpful.
I guess we will have to rely on knowledgeable users to build some playlists and it is a suggestion I’ll make to Deezer, i.e. label search capability
Hiort
Sweden
Posts 2,816
Hiort replied on Tue, Nov 21 2017 9:53 AM
Flere:
I guess you have to pick record by record.
Maybe this link can help.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2  Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote  Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 26 2017 4:39 AM
Playing Gigi FLAC on the Essence joined with a BLC nl/ml ... sadly the FLAC does not come through ... if I am to believe the UI
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 26 2017 4:52 AM
elephant:
Playing HiFi FLAC on the Essence joined with a BLC nl/ml ... sadly the FLAC does not come through ... if I am to believe the UI
BeoNut since '75
BeoNut since '75
Maniax
Singapore
Posts 21
Maniax replied on Fri, Dec 1 2017 11:35 PM
I’ve got a Beosound Moment, and there still isn’t an official update to allow Deezer Hifi (flac) to be played.
Does anyone know when this update will be available?
Thanks.
Beolab 5 Final Edition, Beosound Moment
Normann
Posts 276
Normann replied on Thu, Dec 7 2017 12:43 PM
Hello.
Does anyone have a tip on seaching for Hifi in Deezer?
badgersurf
Posts 538
Maniax:
Thanks.
The B&O website says that the moment is compatible with Deezer Hifi. Guess we just need the 2.2 software to make this happen, lets hope it is not too long away
jimcaj
Denmark
Posts 126
jimcaj replied on Thu, Dec 7 2017 1:55 PM
Normann:
There are some cool playlists, if you search for hifi
Normann
Posts 276
Normann replied on Thu, Dec 7 2017 2:39 PM
jimcaj:
Normann:
Thanks Yes - thumbs up
Normann
Posts 276
Normann replied on Thu, Dec 7 2017 4:37 PM
Do i need to play music on Deezer on the Bang Olufsen app, Beolink 2 app to play with HIFI quality? Or does it work to play it on the Deezer app, and cast/airplay it to a speaker/system.. ?
jimcaj
Denmark
Posts 126
jimcaj replied on Thu, Dec 7 2017 6:16 PM
Normann:
Do i need to play music on Deezer on the Bang Olufsen app to play with HIFI quality?
Yes and a HiFi subscription.
MexExec
Posts 4
MexExec replied on Sat, Dec 9 2017 5:41 PM
Does your BS Essence MKII is still working with FLAC?
I have the 1.15.17 software version an can not make it work.
It only works on my A9
MexExec
Posts 4
I am sorry the question got posted 3 times and don't know how to delete them
MexExec
Posts 4
Sorry Duplicated can't erase
MexExec
Posts 4
Apologies
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 11 2017 7:15 AM
MexExec:
I had my Essence working with FLAC
BeoNut since '75
Liverpoolpete
Posts 11
All I want for Christmas is Beosound Moment v2.2 with flac!
Come on B&O
Fan since 77
mbolo01
Louannec - France
Posts 1,972
mbolo01 replied on Wed, Dec 13 2017 6:12 PM
Flere:
Deezer just released an ECM Essentials playlist
Millemissen
Flensborg, Denmark
Posts 14,393
The entire recording catalogue of ECM Records Is now available on the streaming services.
Justin
The Netherlands
Posts 32
Justin replied on Thu, Mar 15 2018 2:59 PM
I am going around in circles.
Switched the Deezer account to Hifi. But how would I know if I am actually playin Flac on the moment?
The screenshots of the app in this thread seem to be different (old version?) as the screenshot notes.
I asked the Deezer support as I expected my account was wrong but their reply was even more confusing;
Quote:
For the B&O speakers, you need to play via the B&O app and set the quality to enhanced on your Deezer. That would automatically give you FLAC.
I tried the deezer windows beta app and that seem to play flac
Any tips how I can confirm flac on the Moment?
mbolo01
Louannec - France
Posts 1,972
mbolo01 replied on Thu, Mar 15 2018 3:19 PM
Justin:
For now, only the 2.2 beta version can handle Deezer HiFi.
When playing hifi, the FLAC word follows the Deezer logo on in the JukeBox interface
Justin
The Netherlands
Posts 32
Justin replied on Fri, Mar 16 2018 2:49 AM
mbolo01:
When playing hifi, the FLAC word follows the Deezer logo on in the JukeBox interface BS Moment, BL 18, BL 19, A6, M5, A1, H5
Got it, thanks!
leosgonewild
Helsinki, Finland
Posts 2,296
Silver Member
It should be easy to confirm if it is playing in higher quality. You should HEAR the difference.
I can't hear the difference on my speakers.
I can't hear the difference between Tidal HiFi and Tidal studio using H6 mk1 and mk2 with a headphone DAC.
So I just started to enjoy actually listening to music again instead of fiddling around with audio equipment and on-paper quality.
Not saying others can't hear the difference.
Page 3 of 3 (108 items) < Previous 1 2 3 | RSS
