BeoRemote one BT does not work with Apple TV generation 3
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
KnudBL
KnudBL posted on Sun, Aug 20 2017 5:02 PM
I hav a new B&O Horizon and an Apple TV (generetation3), however everything is connected through HDMI 1 and PUC one with the IR-cable. I can see whats on Apple TV and use my Apple remote but the Beoremote does not recognize Apple TV, I can not control it with the B&O remote. The PUC-table is downloaded. Any solution suggested? Shall anything special be pressed om the remote, I have tried everything
Millemissen
Flensborg, Denmark
Did you coose the right ATV-PUC from the list, when you set it up?
Are you sure, that the right cable is used - some have support for two ir emitters.
jans
Belgium
jans replied on Sun, Aug 20 2017 8:04 PM
I don't remember the details but in the Apple TV menu's you need to unpair the ATV remote. I had a similar problem
KnudBL
KnudBL replied on Mon, Aug 21 2017 12:03 PM
Yes I choosed corrct PUC Connection for the HDMI Connected apple TV-, and downloaded correct PUCtable, BUT the IR-cable I`ve got from B&O is a cable With A and B IR-sensors, is that incorrect?
KnudBL
KnudBL replied on Mon, Aug 21 2017 12:05 PM
That I did not know, I `ll try that tonight. I did try to learn the ATV to understand the Beoremote but ATV said it could read any signals
Page 1 of 1 (5 items) | RSS
