Beosound Core
Not Answered This post has 0 verified answers | 48 Replies | 1 Follower
David
UK
David posted on Fri, Aug 18 2017 11:03 PM
picking one up tomorrow morning - lets hope its more stable / reliable than the Essence
Flere
Netherlands
Flere replied on Fri, Dec 1 2017 10:19 AM
seethroughyou:
On my BL90 and Roon you can change volume three ways.
1. Change using IR eye and Essence remote.
2. Change using BL90 app
3. Change in Roon
I use option 1.
You must try Roon - it is beautiful and sophisticated.
Thank you very much for the inspiration and info.
I am seriously considering a Mac+ROON as a source instead of something as a Auralic.
For the price of an Auralic G2 a nice Mac based solution can be envisioned.
- Flere
smile and enjoy the moment
Flere
Netherlands
Flere replied on Sun, Dec 10 2017 11:14 AM
seethroughyou:
This is excellent advice. Thanks you again.
I have now switched from Deezer to Tidal and installed ROON.
I am impressed at the richness of the experience ROON gives next to the audio quality of course.
Music listening via
NAS + Tidal ==> ROON on Mac Mini ==> optical BL50
Given the distance between the Mac mini and the BL50 the optical cable I use is an 8 meters audioquest cinnamon optical cable.
Remote control via
iPad mini with ROON and B&O app for volume and presets
Essence remote in IR mode for BL50 volume control
For Movie or Radio the Avant uses PowerLink toward the BL50
And on the go I have then Tidal on the iPhone and iPad mini.
In this set-up the BeoSound Core is not needed anymore so that will be returned to the Dealer.
- Flere
Millemissen
Flensborg, Denmark
Those, who are interested in the Roon software - and find a Mac Mini a bit to much/overkill - might be interested in these articles from an expert:
http://archimago.blogspot.com/search?q=Roon
Flere
Netherlands
Flere replied on Wed, Dec 13 2017 9:54 PM
seethroughyou:
3. Change in Roon
I use option 1.
If you also have a BeoRemoteOne (IR) then you can configure it easily so you can switch it to BeoSound mode. Then you can control the volume also with the BR1.
I do this. Convenient.
When gong into a music listening session I switch the BR1 to BeoSound mode.
The Avant does not listen then but that is in standby then anyway.
And the light control still works also in BeoSound mode.
- Flere
Page 4 of 4 (49 items) < Previous 1 2 3 4 | RSS
