how to restore beolab 8000 base ?
Not Answered This post has 0 verified answers | 5 Replies | 0 Followers
olvisab
olvisab posted on Thu, Aug 17 2017 10:21 PM
hello,
I need to restore discolored beolab 8000 bases
Do you have any tip for restoring them ? thanks
beolab 5, beolab 9, beolab 3, beolab 10, beolab 5000, beolab 8000, beolab 3500, IWS 2000, beovision 7 55 mk2,  beotime, beogram 7000 white mmc2, beosound ouverture, beosound essence, beomaster 900 RG de luxe and the collection continues...
Jeff
USA
Silver Member
Jeff replied on Fri, Aug 18 2017 12:39 AM
Discolored in what way? A few years ago mine looked very grungy and gray, turns out they had loads of dust that had accumulated on them and didn't wipe off easily. I took a very damp cloth rag and wiped them down several times, rinsing it out in between, and they cleaned up quickly and nicely. Or do you have a different type of discoloration?
Jeff
Dante
Sao Paulo - Brazil
Dante replied on Fri, Aug 18 2017 1:12 AM
I used a soft brush and lots of water and soap on mine, then I let them dry under sun light.
The original paint is very scratch resistant.
Now they look like new 😁
Zwets
Zwets replied on Fri, Aug 18 2017 11:37 AM
I use a product which is like a shoe polish but especially for iron stoves. Works great and makes them nice and black again.
olvisab
Thanks for your advices.
Due to the damages of the paint and its discoloration, I will directly use the satin black bumper paint that some advised in an older thread found on beoworld.
I will post pictures before/after if I can do it with my ipad.
olvisab
Could you please give me a link on ebay or amazon if it is possible ? Thanks
Page 1 of 1 (6 items) | RSS
