Beocenter 9500 no power to sliding doors Tape/CD
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
hooth67
hooth67 posted on Thu, Aug 17 2017 8:09 PM
I am new into beoworld Smile
I bought an Beocenter 9500 type 2501 and have fully functions on touch glass ....but no movement on both sliding doors.
I have checked sliding mechanism and drive belts that is in good condition.
any tips?
Guy
Buckinghamshire
Guy replied on Fri, Aug 18 2017 8:07 AM
The door motors have been known to fail - can you check that these are getting power with a multimeter?
(Welcome to Beoworld, by the way!)
hooth67
hooth67 replied on Wed, Aug 23 2017 11:42 PM
Thank you and like this serious quality site about "beauty&eyecandy" from Denmark Cool
I will check the motor circuit and feed circuit that the service manual describes.
Ottar.
Dushan
Dushan replied on Fri, Oct 27 2017 10:57 PM
If you hear the motor buzzing, then the belts are worn/cracked. I found rubber bands that fit and replaced the belts. Am still looking for proper O-ring type belts. 1.5mm diameter with 34mm inside diameter.
Dushan
joeyboygolf
Ely, Cambridgeshire, UK
ONLINE
Forum member Dillen will be able to supply the correct belts.
Regards Graham
Page 1 of 1 (6 items) | RSS
