BEOVISION ECLIPSE
This post has 2,418 Replies | 21 Followers
Millemissen
Flensborg, Denmark
Posts 13,041
Could you maybe post a picture of the menu, where you (don’t) see it?
Generally speaking Adaptive Mode is what is used, if you haven’tvchanged anything.
Please look in the Sound Info, when you watch different programmes, what is listed there as active mode.
Mikipidia
Posts 1,234
ONLINE
Mikipidia replied on Thu, Jan 30 2020 8:10 PM
AdamS:
Generally, we love it. The picture is superb, the wireless interface with the BL90s and the rest of our stuff is faultless and it performs brilliantly. As an aside, the installation service from our dealer was superb and included hiding the cables inside the wall and re-plastering it. Very impressed!
Adam, please tell me you have the beolab 90’s wired and not in WiSa???
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Dyssegaard
Copenhagen, Denmark
Posts 187
Millemissen:
Adaptive mode is not a valid selection on Eclipse - (confirmed by B&O support):
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40, AppleTV 4. Home office: Beolit 12, Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Chris Townsend
Badsey, UK
Posts 3,370
Mikipidia:
Adam, please tell me you have the beolab 90’s wired and not in WiSa??? New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally )
How much of a difference does it make real world?
Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
Aussie Michael
Melbourne, AU
Posts 3,427
Chris Townsend:
How much of a difference does it make real world? Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
Same
I mean it has WISA for a reason. I would use WISA.
Mikipidia
Posts 1,234
ONLINE
Mikipidia replied on Fri, Jan 31 2020 11:40 AM
On the 50’s i recognise it immidiately in soundsignature. Also if you have nice 24bit 196khz files to play, it doesn’t anymore. But most importantly you only sort of AT BEST get half of the room compensation. I convinced Willie, my friend from our podcast to try it as he did the same and now he’ll never go back to wisa for 90’s. The difference imo is subtle but big enough to notice. They become way more refined when wired, even the 50’s do that in an audible way.
Chris Townsend
Badsey, UK
Posts 3,370
Cool thanks. I only ask because we are still so impressed with our 17s using WISA. Different grade of speaker I know.
Aussie Michael
Melbourne, AU
Posts 3,427
Mikipidia:
ok, thanks
What cables are you / Willstar using?  XLR or say PL?
Cheers
Mikipidia
Posts 1,234
ONLINE
We both use Cat7 PL cables, I have no idea about brands on mine as they are generic but they works well.
btw this is what mr G, our speaker god had to say about what and why and how this works:
''In a normal operating mode (meaning, that the speaker is not running its room compensation measurements, for example... You're just sitting and listening to music...):
  1. If the input signal is analogue: The two audio channels are converted to 192/24 PCM by the 2-channel ADC in the Master loudspeaker. These two audio channels are both sent to the DSP in the Master loudspeaker and the DSP in the Slave speaker (via the DPL cable). This means that both audio channels are sent to the inputs of each loudspeaker's DSP.
  2. If the input signal is digital: The two audio channels are re-sampled to 192/24 PCM by the sampling rate converter in the Master loudspeaker. These two audio channels are both sent to the DSP in the Master loudspeaker and the DSP in the Slave speaker (via the DPL cable). This means that both audio channels are sent to the inputs of each loudspeaker's DSP.
  3. If the input signal is WiSA / WPL: Each loudspeaker individually receives a single digital audio channel from the WiSA receiver and sends it to its local DSP. This means that each loudspeaker's DSP receives only one audio channel at its input. There is no inter-speaker communication of the audio signal, even if the DPL cable is connected.
From there, each loudspeaker's DSP does its own signal processing, which includes (but is not exclusive to) (and in no particular order):
  • signal routing (aka Speaker Role)
  • gain (for Speaker Level and Volume)
  • delay (Speaker Distance and internal time alignment)
  • magnitude and phase correction for the individual drivers (equalisation)
  • directivity control
  • room compensation
  • other stuff
Each DSP then outputs one audio channel per driver (7 for the BL50, 18 for the BL90).
This "helicopter view" description is true of the BeoLab 90's and of the BeoLab 50's. There is no difference between the two loudspeaker models within the limitations of what I've described here.
One important thing to note here is the difference between WiSA/WPL and the other inputs. The ARC (Adaptive Room Compensation) algorithm in the BL50/90's uses both audio channels to create a single output channel for each loudspeaker's room compensation signal. In other words, the left loudspeaker is compensating for both the left and the right loudspeakers' interaction with the room. (Ditto for the right loudspeaker.) However, this is only possible if each loudspeaker gets both audio channels at its input - which is true for analogue and wired digital connections, but not for WiSA/WPL (see point #3 above). If you are using a WiSA/WPL connection, then a portion of the room compensation is not working, since each loudspeaker only receives one audio input channel.
So, for example, I have seen some "reviews" or comparisons done by people online where the 50's or 90's are connected to an audio source via the wireless connection. This means that the ARC algorithm is not doing everything it can  - and so the comparison may not be completely fair (assuming that the intention is to do a best-case-to-best-case A/B comparison). Whether or not this will affect the conclusions of the comparison is impossible to predict, since a 1 or 2 dB difference in listening level, or a change in loudspeaker and/or relative listening position will also influence the perceived sound.
Cheers
-geoff ''
Hope this helps, took me for ever to find it to back my claim up :p In my opinion in WiSa mode you loose one of the best things about the 50's and especially the 90's as with the 90's it has an even bigger impact on sound performance imho.
tigerisak
Posts 120
Anybody else that got a new "stand update" yesterday? When I started the TV its says new stand software installed. And after that I can't manage to get any sound . Under sound info it says: Input Dolby Audio 2.0 and on output 0.0.
The remote is also not working all the time and the stand won't go into standby mode.
BestSound
Posts 28
BestSound replied on Wed, Feb 19 2020 4:27 PM
You are not the only one who have experienced problems with no sound after the latest update, I got the same problem, ending up making a factory reset of the sound center.
Afterwards I find out that the problem was related to “Clip Protection” a function which is turned ON by default, but in my case turned OFF because I have recognized it cut off the lower bass to my BL5 speakers.
But after this software update it is no longer possible to disable the function, if doing so it will replace the sound with a high frequency tone, which will not disappear before turning the function back ON again and restart the TV.
I lately also has experienced, several times the remote has lost the communication to the TV and need to be re paired, sometimes it’s necessary to make a factory reset to the Beoremote before it is possible to successfully pair the two.
I already has contacted my B&O dealer and even B&O too, so just hope they very soon will come up with a solution.
BeoVision Eclipse 65....Front: BeoLab 5....Rear: BeoLab 4000....Beosound 9000 Mark lll....BeoRemote One BT....Apple TV 4K....NAS: Synologi DS218j....Disc Player: OPPO BDP-103....Projector: JVC HD-950....Screen: Stewart Film Screen StudioTek 100....HDMI management: HDFury Integral
Sweden
Posts 281
Martin replied on Thu, Feb 20 2020 8:28 AM
I have also a problem with my Eclipse after latest software update (2.7.xxx). The standby-indicator that always lights green when playing a music-source (Deezer or Music DLNA) dont light up at all anymore when playing music source and the screen is black. In the Manual for the Eclipse it says that the standby-indicator always should be green when the screen is off and when a music-source is played.
This software error is not a big thing, but they have done a lot of things with the soundcenter with the new software and I can NOT see any improvements at all. Just negative things with the new software. I hope B&O reads all this comments and make a fix.
The bad thing about B&O and software is that it always take so long time to fix an error in the software compared to other brands. I wonder if B&O ever will be good at software in their products. It is now many years with bad software in different products (Beovision 14, Beolab 50, Beosound Moment etc....).
Best Regards
Martin Ström
SWEDEN
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. AURALIC Aries G1 (new)
BestSound
Posts 28
BestSound replied on Thu, Feb 20 2020 8:53 AM
Yes it seems like they have done a lot with the sound center and for what reason and just agreeing, hope really B&O read everything in this tread.
Another thing I experienced after this software update is that a bad sounding noise can appear in the speakers when turning the system off.
Ingo
Da wo die Weser einen großen Bogen macht
Posts 138
Ingo replied on Thu, Feb 20 2020 11:44 AM
We have had some problems with our Eclipse since tonight, too.
When selecting stations from the cable network, the TV picture does not produce any sound; after a short time the message "no signal found" or "invalid service" and "only data" appears.
A short time later there is sound and image, sometimes the message remains, so only switching helps.
This issue runs across almost all channels, no matter if SD or HD.
Sometimes picture and sound are immediately there, but not the next time.
In the LG forum I could not read any information about it.
I restarted the devices, plugged in the antenna cable and plugged it in again, also removed the hard drive and the CI module, no changes.
Only if I disconnect the main cable for couple minutes everything runs fine.
My Dealer and the support is involved, we are waiting for an answer.
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Dyssegaard
Copenhagen, Denmark
Posts 187
Dyssegaard replied on Thu, Feb 20 2020 11:49 AM
I have noticed, that when I play music from my DLNA server on my Eclipse, the shufle and repeat buttons have no effect at all.
If I set the buttons and then closes and reopens the B&O app, the buttons are reset.
Some time ago, the same problem was present on my M5 but a sw update of the M5 fixed it. I have just tested the app on the M5, and here it is still ok.
Does anyone else have the same problem on the Eclipse?
spezializten
Posts 67
Just as an example Eclipse Soundcentre 55" with LG 77" C9 with Bang & olufsen App works perfect
Millemissen
Flensborg, Denmark
Posts 13,041
As writren in the other theead, where you posted this....interesting!
Tell us more, please!
BestSound
Posts 28
New software for Eclipse
2.7.37196
And the problem with “Clip Protection” is finally solved. Hopefully other problems from the previous software update are solved too.
Unfortunately Bang & Olufsen’s support line is very hard headed to communicate with, it’s simply impossible to have a constructive conversation, especially if you have knowledge yourself at technician level. They will never, never admit there possibly has been flaws in one of there software updates, the dialog will turn to pure nonsense if you confront them.
Sweden
Posts 281
Martin replied on Thu, Mar 5 2020 2:04 PM
With the software update yesterday there is still problem with Stand-by indicator when playing music (Deezer, DLNA). With the software 2.5.xxx and earlier, the standbyindicator always had a green light when playing a Music-source. From software 2.7.xxxx the standby-indicator sometimes lights up when starting a Music-source but after 10 minutes it go off (black). I have send this software bug to B&O-support but nothing happens.
It is not a big deal but I agree that it is impossible to make a decent conversion with B&O and their support-team.
Best Regards
Martin Ström
SWEDEN
Page 61 of 61 (2419 items) « First ... < Previous 57 58 59 60 61 | RSS
