BEOVISION ECLIPSE
This post has 2,468 Replies | 20 Followers
Millemissen
Flensborg, Denmark
Posts 14,202
Could you maybe post a picture of the menu, where you (don’t) see it?
Generally speaking Adaptive Mode is what is used, if you haven’tvchanged anything.
Please look in the Sound Info, when you watch different programmes, what is listed there as active mode.
Mikipidia
Posts 1,955
Mikipidia replied on Thu, Jan 30 2020 8:10 PM
AdamS:
Generally, we love it. The picture is superb, the wireless interface with the BL90s and the rest of our stuff is faultless and it performs brilliantly. As an aside, the installation service from our dealer was superb and included hiding the cables inside the wall and re-plastering it. Very impressed!
Adam, please tell me you have the beolab 90’s wired and not in WiSa???
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Dyssegaard
Copenhagen, Denmark
Posts 235
Silver Member
Millemissen:
Adaptive mode is not a valid selection on Eclipse - (confirmed by B&O support):
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Chris Townsend
Badsey, UK
Posts 3,494
Mikipidia:
Adam, please tell me you have the beolab 90’s wired and not in WiSa??? New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally )
https://www.youtube.com/c/Mikipedia
How much of a difference does it make real world?
Beovision 11-55, Beolab 2, Beolab 6000, Beolit 15, Beoplay A2 Active
Aussie Michael
Melbourne, AU
Posts 3,674
Chris Townsend:
How much of a difference does it make real world? Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
Same
I mean it has WISA for a reason. I would use WISA.
Mikipidia
Posts 1,955
Mikipidia replied on Fri, Jan 31 2020 11:40 AM
On the 50’s i recognise it immidiately in soundsignature. Also if you have nice 24bit 196khz files to play, it doesn’t anymore. But most importantly you only sort of AT BEST get half of the room compensation. I convinced Willie, my friend from our podcast to try it as he did the same and now he’ll never go back to wisa for 90’s. The difference imo is subtle but big enough to notice. They become way more refined when wired, even the 50’s do that in an audible way.
Chris Townsend
Badsey, UK
Posts 3,494
Cool thanks. I only ask because we are still so impressed with our 17s using WISA. Different grade of speaker I know.
Aussie Michael
Melbourne, AU
Posts 3,674
Mikipidia:
ok, thanks
What cables are you / Willstar using?  XLR or say PL?
Cheers
Mikipidia
Posts 1,955
We both use Cat7 PL cables, I have no idea about brands on mine as they are generic but they works well.
btw this is what mr G, our speaker god had to say about what and why and how this works:
''In a normal operating mode (meaning, that the speaker is not running its room compensation measurements, for example... You're just sitting and listening to music...):
  1. If the input signal is analogue: The two audio channels are converted to 192/24 PCM by the 2-channel ADC in the Master loudspeaker. These two audio channels are both sent to the DSP in the Master loudspeaker and the DSP in the Slave speaker (via the DPL cable). This means that both audio channels are sent to the inputs of each loudspeaker's DSP.
  2. If the input signal is digital: The two audio channels are re-sampled to 192/24 PCM by the sampling rate converter in the Master loudspeaker. These two audio channels are both sent to the DSP in the Master loudspeaker and the DSP in the Slave speaker (via the DPL cable). This means that both audio channels are sent to the inputs of each loudspeaker's DSP.
  3. If the input signal is WiSA / WPL: Each loudspeaker individually receives a single digital audio channel from the WiSA receiver and sends it to its local DSP. This means that each loudspeaker's DSP receives only one audio channel at its input. There is no inter-speaker communication of the audio signal, even if the DPL cable is connected.
From there, each loudspeaker's DSP does its own signal processing, which includes (but is not exclusive to) (and in no particular order):
  • signal routing (aka Speaker Role)
  • gain (for Speaker Level and Volume)
  • delay (Speaker Distance and internal time alignment)
  • magnitude and phase correction for the individual drivers (equalisation)
  • directivity control
  • room compensation
  • other stuff
Each DSP then outputs one audio channel per driver (7 for the BL50, 18 for the BL90).
This "helicopter view" description is true of the BeoLab 90's and of the BeoLab 50's. There is no difference between the two loudspeaker models within the limitations of what I've described here.
One important thing to note here is the difference between WiSA/WPL and the other inputs. The ARC (Adaptive Room Compensation) algorithm in the BL50/90's uses both audio channels to create a single output channel for each loudspeaker's room compensation signal. In other words, the left loudspeaker is compensating for both the left and the right loudspeakers' interaction with the room. (Ditto for the right loudspeaker.) However, this is only possible if each loudspeaker gets both audio channels at its input - which is true for analogue and wired digital connections, but not for WiSA/WPL (see point #3 above). If you are using a WiSA/WPL connection, then a portion of the room compensation is not working, since each loudspeaker only receives one audio input channel.
So, for example, I have seen some "reviews" or comparisons done by people online where the 50's or 90's are connected to an audio source via the wireless connection. This means that the ARC algorithm is not doing everything it can  - and so the comparison may not be completely fair (assuming that the intention is to do a best-case-to-best-case A/B comparison). Whether or not this will affect the conclusions of the comparison is impossible to predict, since a 1 or 2 dB difference in listening level, or a change in loudspeaker and/or relative listening position will also influence the perceived sound.
Cheers
-geoff ''
Hope this helps, took me for ever to find it to back my claim up :p In my opinion in WiSa mode you loose one of the best things about the 50's and especially the 90's as with the 90's it has an even bigger impact on sound performance imho.
tigerisak
Posts 122
Anybody else that got a new "stand update" yesterday? When I started the TV its says new stand software installed. And after that I can't manage to get any sound . Under sound info it says: Input Dolby Audio 2.0 and on output 0.0.
The remote is also not working all the time and the stand won't go into standby mode.
BestSound
Posts 29
BestSound replied on Wed, Feb 19 2020 4:27 PM
You are not the only one who have experienced problems with no sound after the latest update, I got the same problem, ending up making a factory reset of the sound center.
Afterwards I find out that the problem was related to “Clip Protection” a function which is turned ON by default, but in my case turned OFF because I have recognized it cut off the lower bass to my BL5 speakers.
But after this software update it is no longer possible to disable the function, if doing so it will replace the sound with a high frequency tone, which will not disappear before turning the function back ON again and restart the TV.
I lately also has experienced, several times the remote has lost the communication to the TV and need to be re paired, sometimes it’s necessary to make a factory reset to the Beoremote before it is possible to successfully pair the two.
I already has contacted my B&O dealer and even B&O too, so just hope they very soon will come up with a solution.
BeoVision Eclipse 65....Front: BeoLab 5....Rear: BeoLab 4000....Beosound 9000 Mark lll....BeoRemote One BT....Apple TV 4K....NAS: Synologi DS218j....Disc Player: OPPO BDP-103....Projector: JVC HD-950....Screen: Stewart Film Screen StudioTek 100....HDMI management: HDFury Integral
Sweden
Posts 343
Martin replied on Thu, Feb 20 2020 8:28 AM
I have also a problem with my Eclipse after latest software update (2.7.xxx). The standby-indicator that always lights green when playing a music-source (Deezer or Music DLNA) dont light up at all anymore when playing music source and the screen is black. In the Manual for the Eclipse it says that the standby-indicator always should be green when the screen is off and when a music-source is played.
This software error is not a big thing, but they have done a lot of things with the soundcenter with the new software and I can NOT see any improvements at all. Just negative things with the new software. I hope B&O reads all this comments and make a fix.
The bad thing about B&O and software is that it always take so long time to fix an error in the software compared to other brands. I wonder if B&O ever will be good at software in their products. It is now many years with bad software in different products (Beovision 14, Beolab 50, Beosound Moment etc....).
Best Regards
Martin Ström
SWEDEN
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5, Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. Beoremote HALO (new), 3xBeoplay Charging pad, Beoplay M5 (new)
BestSound
Posts 29
BestSound replied on Thu, Feb 20 2020 8:53 AM
Yes it seems like they have done a lot with the sound center and for what reason and just agreeing, hope really B&O read everything in this tread.
Another thing I experienced after this software update is that a bad sounding noise can appear in the speakers when turning the system off.
Ingo
Da wo die Weser einen großen Bogen macht
Posts 146
Ingo replied on Thu, Feb 20 2020 11:44 AM
We have had some problems with our Eclipse since tonight, too.
When selecting stations from the cable network, the TV picture does not produce any sound; after a short time the message "no signal found" or "invalid service" and "only data" appears.
A short time later there is sound and image, sometimes the message remains, so only switching helps.
This issue runs across almost all channels, no matter if SD or HD.
Sometimes picture and sound are immediately there, but not the next time.
In the LG forum I could not read any information about it.
I restarted the devices, plugged in the antenna cable and plugged it in again, also removed the hard drive and the CI module, no changes.
Only if I disconnect the main cable for couple minutes everything runs fine.
My Dealer and the support is involved, we are waiting for an answer.
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Dyssegaard
Copenhagen, Denmark
Posts 235
Silver Member
Dyssegaard replied on Thu, Feb 20 2020 11:49 AM
I have noticed, that when I play music from my DLNA server on my Eclipse, the shufle and repeat buttons have no effect at all.
If I set the buttons and then closes and reopens the B&O app, the buttons are reset.
Some time ago, the same problem was present on my M5 but a sw update of the M5 fixed it. I have just tested the app on the M5, and here it is still ok.
Does anyone else have the same problem on the Eclipse?
spezializten
Posts 67
Just as an example Eclipse Soundcentre 55" with LG 77" C9 with Bang & olufsen App works perfect
Millemissen
Flensborg, Denmark
Posts 14,202
As writren in the other theead, where you posted this....interesting!
Tell us more, please!
BestSound
Posts 29
New software for Eclipse
2.7.37196
And the problem with “Clip Protection” is finally solved. Hopefully other problems from the previous software update are solved too.
Unfortunately Bang & Olufsen’s support line is very hard headed to communicate with, it’s simply impossible to have a constructive conversation, especially if you have knowledge yourself at technician level. They will never, never admit there possibly has been flaws in one of there software updates, the dialog will turn to pure nonsense if you confront them.
Sweden
Posts 343
Martin replied on Thu, Mar 5 2020 2:04 PM
With the software update yesterday there is still problem with Stand-by indicator when playing music (Deezer, DLNA). With the software 2.5.xxx and earlier, the standbyindicator always had a green light when playing a Music-source. From software 2.7.xxxx the standby-indicator sometimes lights up when starting a Music-source but after 10 minutes it go off (black). I have send this software bug to B&O-support but nothing happens.
It is not a big deal but I agree that it is impossible to make a decent conversion with B&O and their support-team.
Best Regards
Martin Ström
SWEDEN
Seanie_230
UK
Posts 2,218
Seanie_230 replied on Thu, Aug 27 2020 10:13 PM
Evening all
I just spent three hours reading from page 1 to about 20 and gave up.
In short
I JUST BOUGHT AN ECLIPSE 65
I am super excited if not worried that
A it might feel weird going from the Avant 55 loosing the menu structure and this HDMI 2 logo i read about.
B Adjusting to the LG interface on screen compared to the avant might make me sad
C if i like or dislike the silver speaker cover, might change to Piano black
D if he will give me that amazing Bang and Olufsen feeling.
It is going to sit between my Lab5’s with 6000’s in the rear
Only STB will be a Apple TV which I really don’t know if I will need anymore but I kind of like the interface and access to iMovie app.
Well its waiting time now until it arrives and i am excited and concerned at the same time as it was a huge move from the avant 55 MK1.5 to the first LG and B&O collaboration.
Still Mikipedia YouTube video’s shows that two of the lads have them so fingers crossed.
Now I wait in anticipation hoping that my concern will fade.
Happy Thursday
6 days to go
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Mikipidia
Posts 1,955
Mikipidia replied on Fri, Aug 28 2020 12:20 AM
Congrats on the purchase! It’ll be an adjustment for sure but in the end you only look at the menu’s really in the first month of playing around Stick out tongue
In terms of actual performance, both visually or sonically it’ll be a huge improvement over an avant mk1.
Seanie_230
UK
Posts 2,218
Mikipidia:
In terms of actual performance, both visually or sonically it’ll be a huge improvement over an avant mk1. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Thanks mate
I cannot wait!
I have a question or 3
I use the Netflix app for example via the apply TV 4K box, is there any benefit to using it on the TV ? Better resolution or sound compared to the app on ATV?
Also
I see in the LG content store there is the Apple TV+ app is this available? Is it in 4K? And it appears to be missing the wish list which you have natively in the Apple TV when using the imovie app rather than the ATV+ app?
Thanking you
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,218
Also do you have to connect the Soundcetner and the TV to the WIFI or is this done once and the set sorts out the other?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Mikipidia
Posts 1,955
Mikipidia replied on Fri, Aug 28 2020 9:48 AM
Yes wifi will sort it self out as one.
The apple app in the store is 4k, but just ok imho.
I would say the sound and PQ is superior through the aptv, marginally on the c9/CX, but more so on the c7 eclipse.
The apple tv is actually quite nice
Emil Jensen
Denmark
Posts 719
And you can code so that when you press the TV button it will start on Apple TV,
That is what I do, the Apple TV is the best smart TV platform out on the market.
Beovision Harmony 77" 2nd Gen, Beolab 5, Beolab 17, Beosound 1, Beoplay M3, Beoplay H6, Beoplay Earset, Beoliving Intelligence
Seanie_230
UK
Posts 2,218
Seanie_230 replied on Fri, Aug 28 2020 10:47 AM
Emil Jensen:
Beovision Eclipse, Beolab 5, Beolab 17, Beosound 1 Google assist, Beoplay M3, Beoplay H6, Beoplay Earset
Hi there
I agree, the ATV 4K is a great device and its the only platform I use on the avant 55 actually.
It keeps everything in one place and should limit the amount of time i will see the LG screens lol
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Fansastic
The Hague, The Netherlands
Posts 690
ONLINE
Fansastic replied on Fri, Aug 28 2020 2:43 PM
Congratulations with your purchase, I love my Eclipse.
Regarding the Apple TV+ app, it is not available on the LG store. If I remember correctly it is not (yet) available for the C7 panels.
The AppleTV can be installed within the back of the sound center and as already stated the Apple TV gives best picture quality.
I still have to switch my AppleTV from my Horizon to my Eclipse. I’m satisfied with the native Netflix and Prime apps of LG so no hurry (and the Horizon needs the AppleTV).
Serge
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Michael
Sweden
Posts 2,573
Michael replied on Fri, Aug 28 2020 4:31 PM
Seanie_230:
Evening all
In short
Happy Thursday
6 days to go BLGW - Rekindling the love of ML
I would cancel and wait for the update as the panel is three years old and there’s been many updates on the hardware
And software of the monitor itself. Paying full price now is just a bargain for the seller. Use your money for a better hardware in a month.
Seanie_230
UK
Posts 2,218
I got a great deal and for me buying used at this value is my only option really.
My TV’s since my BV3 and BV7 have been used.
I know it’s old but in three years or two years I will do the same again and then catch up :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Stan
Chicago-area USA
Posts 818
Stan replied on Fri, Aug 28 2020 5:16 PM
Congrats.  I hope you'll like it as much as I like mine.
Seanie_230
UK
Posts 2,218
Thanks guys
Does anyone have a picture of the Apple TV fitting in the back of the TV?
Also, I heard the TV power cable is really only a meter is this true?
If so I will need to make a longer cable temporality a extension lead on the floor.
Currently my setup looks like this with a Lindy splitter of two figure of 8 cables one for avant and one ATV.
But I heard the sound centre needs one and tv cable is fixed.
Maybe a female figure 8 connector
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,218
One of these should do it for the TV power perhaps if it’s not too large.
Leaving the Lindy power for the ATV and sound center
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Aussie Michael
Melbourne, AU
Posts 3,674
Seanie_230:
Thanks guys
This will give you an indication Sean
https://www.stbbrackets.co.uk/en-GB/product/apple-tv/Apple-TV-with-Eclipse
There also used to be a bracket available from Apple too, I’m not sure how that would connect with the eclipse.
Mikipidia
Posts 1,955
Mikipidia replied on Sat, Aug 29 2020 12:53 AM
That power extension connector thing will be fine. In no way is the panel going to pull 10 amps as that’s probably close to double what your bl5’s pull on average Stick out tongue
Seanie_230
UK
Posts 2,218
Thanks for you advice
Question is the what’s playing feature still working like it does on the avant?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Fansastic
Posts 690
ONLINE
Fansastic replied on Sat, Aug 29 2020 10:19 AM
No, the screen is just black, no information
Fansastic
Posts 690
ONLINE
Fansastic replied on Sat, Aug 29 2020 10:23 AM
Fansastic:
No, the screen is just black, no information BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Only the green light on the bottom is switched on
Seanie_230
UK
Posts 2,218
Seanie_230 replied on Sat, Aug 29 2020 10:53 AM
Love that stand cover it’s beautiful.
Thanks for the info.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,218
Hello guys
TV is installed and wow it’s huge.
Sounds really different than the avant in fact I need some setup help if anyone can advise.
I have three TV speakers configured as centre
Lab 5 front right and left
Rear 6000 were set as rear but I changed them to surround and I have 5.1 not 7.1
Still it feels like I am missing vocal sound from the centre channel.
I have to turn up the sound higher than normal and I have much more background sounds which is weird.
So much more sound from the back speakers than before.
Also Apple TV detected Dolby vision but when I playback sometimes it says not compatible with this format or doesn’t play quickly.
If o am right the picture on Apple TV is better when using Netflix.
Any thoughts or advice welcome.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Mikipidia
Posts 1,955
If you’re going to have the entire front on(not 100% recommended) you need to set the center 20cm furter than it actually is and set the two sides atleast at minus 2db if not -3db.
Also what sound type do you use? Cinema/drama/sports?
And have you remeasure everything with the distances and also with a db meter(phone app is fine)?
Page 61 of 62 (2469 items) « First ... < Previous 58 59 60 61 62 Next > | RSS
