BEOVISION ECLIPSE
This post has 2,418 Replies | 21 Followers
trackbeo
Posts 349
Sandyb:
But for multi-room music, NL is not strictly necessary anymore for some people.  And multi-room AP2 audio can be very easy and intuitive using Airplay - adjustments can be made from the control panel on the iPhone home screen, without needing to go into the B&O app.  Agree though that NL covers more use cases than AP2 - whether that will be the case in 5 years time remains to be seen though.
The one NL feature that most everybody uses is that the *destination* can add itself to current NL playing -- Tap-to-Join or whatever it is called.  Because AirPlay supports (source) computer-wide audio & video output, not just for non-essential music playing, tap-to-join would be considered a security hole.  I don't know enough to understand if AP2 protocol supports security levels per-stream, but if not, this is a feature that AirPlay intentionally will not support.  It could be added, surely, but... does somebody else know if this anybody-can-listen feature is built into the current protocol?
Sandyb
Posts 1,714
Sandyb replied on Fri, Mar 1 2019 5:22 PM
I don't know whether it would be considered a security hole - maybe, maybe not.
Yes, Airplay speakers are unlikely to get the Tap to Join function - i.e. the physical tap. But they can be added / tap to join v quickly on an iPhone etc.
I can perhaps see Apple's own speakers (i.e. the HomePod) gaining a similar function - but getting that to work across different hardware brands, thats not a road I see Apple going down. There are Airplay enabled speakers with built in sources, and those without  -  spread across different brands, hmmm.....Apple likes to ensure a smooth customer experience, so that just won't happen.
NL is great, I use it all the time - but from what I understand, not that many customers use it.
And there are other popular multi-room / streaming protocols now - the overlap is big enough now, that one day B&O may just rely on these and move beyond NL.......that's just logic, though I don't think we need to worry for a while yet.
Millemissen
Flensborg, Denmark
Posts 13,169
I don’t care for AP2 in my setup - I can easily redistribute the airplayed stream e.g. from my Essence to my Avant (either through the Join command on my Beo remote or with the Bang & Olufsen app....which I use for controlling the Netradio, playing content from my NAS, Spotify Connect... anyway).
Besides - I am not using AirPlay that much, because I hate it when content on a website - that I visit on the sending device - often takes over the stream. When just playing to one device, I prefer using ChromeCasting.
From my point of view using AP2 instead of BeoLink is about it being much easier to explain and demomstrate for the dealers....and maybe to understand for most costumers in the first instance.
Millemissen
Flensborg, Denmark
Posts 13,169
Sandyb:
In my case my two tv’s have an added ATV4 each.
In order to add these to an AP2 session on e.g. my Essence I would have to perform several pushes on my remote.
Not only to turn on the ATV and the tv (thanks to PUC 😉), but also to change the default speaker group (which is made for video content) to a music related speaker group....and to push the P.Mute button in order to not have the screen on all the time.
......and what if my wife wants to add a device and hasn’t got access to my iDevice 😏
When I use the good old BeoLink redistribution, all I have to do is to push ‘Join’.....and I don’t have to grab (or maybe find) my iDevice!
These things are often forgotten, when dealers are demonstration their stuff in the shops.
Howver, if you are someone with a mixed bag of ‘only AirPlay speakers’ (the newer ones, which support AP2) and you have your iPhone always at hand, the AP2 way of doing things might be the right one.
Note 1: With the new update for BeoRemote One controlling of the B&O devices there is even less need for an iDevice.
Note! 2: Volume controlling with the iDevice is clumsy, especially when you have tried the fine steps of controlling with a BeoRemote.
Sandyb
Posts 1,714
Sandyb replied on Fri, Mar 1 2019 6:24 PM
Indeed, and no need to explain - my preferences and use cases are very similar to yours.
i.e. start some sources using Airplay (to something) and NL to expand.
We may well be pretty close to a post BV world though - and a bunch of new models from other brands have Airplay built in. So the two step process with an Apple TV / Tv combo will be less relevant going forwards.
Anyway, NL is here for a while yet.
*Side note, I was just at my sisters house. Her new Panasonic OLED + Apple TV 4K - the Panasonic TV remote controlled the Apple TV in very much the same way, through CEC, as my PUC driven setup at home.......
Millemissen
Flensborg, Denmark
Posts 13,169
Sandyb:
So...you predict a ‘post BV worlld’ alread - not knowing what might come from B&O.
Maybe I am just a bit more optimistic than you?
That said - B&O might renounce beolink multiroom for the sake of higher sales and thus focus on AP2 and Google integration.
The imo would be a ‘post B&O world’ for me, though.
Sandyb
Posts 1,714
Sandyb replied on Fri, Mar 1 2019 9:18 PM
I agree, I'd absolutely not want to lose NL - like you, I use it a lot.
And I don't think i'ts going anywhere very soon, it will still be around for a while.
Less sure about 5 years hence though.
As I say, by then many TV's may be AP2 capable, rather than the handful being released this year.
In a world of retrenchment, they'll come to a point where they ask themselves " do we really need to build in NL to our devices" - and the answer will probably be no.
Millemissen
Flensborg, Denmark
Posts 13,169
......and the Bang & Olufsen app will by then just be a setup app.
tigerisak
Posts 120
tigerisak replied on Mon, Apr 8 2019 12:29 PM
So the new Beovision Harmony will be on WebOs 4.5. Hoping to see that in the Eclipse as well.
Millemissen
Flensborg, Denmark
Posts 13,169
You should not expect that - only when they keep the design and upgrade to a newer tv part.
tigerisak
Posts 120
tigerisak replied on Mon, Apr 8 2019 12:40 PM
Millemissen:
Just think its weird that its been on the market a long time and havent been updated at all when it comes to the WebOs.
Mikipidia
Posts 1,351
ONLINE
Mikipidia replied on Mon, Apr 8 2019 12:44 PM
Lg does that all the time, one way of making you buy a new tv every two-three years
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
moxxey
South West, UK
Posts 5,033
moxxey replied on Mon, Apr 8 2019 2:33 PM
tigerisak:
Roger has stated the Eclipse is now EOL, so that's not happening now. Incredible.
Emil Jensen
Denmark
Posts 523
tigerisak:
Millemissen:
That is how it is,
LG do not update the WebOs, and have never done it,
So no surprise here.
What are you missing?
Beovision Eclipse, Beolab 5, Beolab 17, Beosound 1 Google assist, Beoplay M3, Beoplay H6, Beoplay Earset
Millemissen
Flensborg, Denmark
Posts 13,169
moxxey:
tigerisak:
Well, it could be, that the current Eclipse is EOL.
No tv below 77” - seems a bit curious.
There might be room for a 2019 Eclipse - although I am not so sure, that it will happen.
Or maybe something else will replace it?
moxxey
South West, UK
Posts 5,033
moxxey replied on Mon, Apr 8 2019 4:36 PM
Millemissen:
Maybe. I think that's overly positive - you don't EOL something with nothing in the short-term pipeline and no need to EOL the Eclipse, either. Besides, Roger did say that, at least for now, B&O is effectively exiting the TV market.
We'll see, but if anything is clear, it's nothing right now is very clear.
Sandyb
Posts 1,714
Sandyb replied on Mon, Apr 8 2019 4:41 PM
Talk to a sensible dealer, he will explain why there will be no more BV's.
Clue - new EU energy ratings.....seems to have forced the Eclipse into EOL status.....
Duels
England
Posts 2,398
Duels replied on Mon, Apr 8 2019 4:42 PM
Sandyb:
Maybe Britain should leave the EU then.......
Sandyb
Posts 1,714
Sandyb replied on Mon, Apr 8 2019 4:43 PM
Apparently this Friday!
Wouldn't help a Danish manufacturer though....
Millemissen
Flensborg, Denmark
Posts 13,169
Sandyb:
They could make their own Bang & Olufsen, then!
Sandyb
Posts 1,714
Sandyb replied on Mon, Apr 8 2019 4:48 PM
Millemissen:
Sandyb:
Who? The Brits?
Lord no....that would be a scary prospect indeed...
tigerisak
Posts 120
Emil Jensen:
tigerisak:
Millemissen:
That is how it is,
Technicolor and better TM.
tigerisak
Posts 120
For all of you with failing WIFI-cards. LG and BO has released a SW update. It requires a technical to come out.
TEL
Taunton, Somerset UK
Posts 48
TEL replied on Mon, May 13 2019 10:48 PM
Would anyone recommend swapping my Avant 55 NG Mk 1 - for an Eclipse 55 with 4K and UHD?
being offered a part ex and £5k cost to change - worth doing?
TEL
Aussie Michael
Melbourne, AU
Posts 3,462
ONLINE
TEL:
TEL
I’d be interested to read peoples responses too
Mr 10Percent
So West, Its Now East
Posts 467
TEL:
being offered a part ex and £5k cost to change - worth doing? TEL
I upgraded last year from an Avant 55 Mk1 to an Eclipse 65.
Worth doing? Like always.......it depends on what you want?
If you want a compact TV with a simpler easier interface that integrates all you BeoLab and NL products, then the MK1 is it. I enjoyed that TV for that alone.
If you want a stand-alone TV with vastly better picture and Sound over the MK1, the Eclipse wins hands down. However, the user interface (LG) still drives me nuts and to this day it does weird non-intuitive things that you would never see on even the poorest buggiest B&O pure product.
Lastly, you are throwing another £5k at a TV. TVs which are going extinct in the B&O line-up. Keep a Classic or buy-up to the last (EoL) TV and hope to stay functional until something better comes along.
All-in-all, for me, I think in retrospect, the MK1 still has it on balance for me.
Sweden
Posts 282
Martin replied on Tue, May 14 2019 10:19 AM
I have also an Eclipse 65. I am very satisfied with it without any software bugs. I would say that the Eclipse is 99% perfect regarding software bugs. I can not see any drawback to buy the Eclipse.
You will get a much more modern TV regarding picture-quality and 4K formats (HDR and Dolby Vision) that you dont have in an Avant Mk1. You also have Deezer inbuilt in the soundbar and can play Deezer HIFI (FLAC-files) thru the B&O-app which sounds very good. You can not do this with the Avant MK1. So, I would say: Go for the Eclipse.
Best Regards
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. AURALIC Aries G1 (new)
TEL
Posts 48
TEL replied on Tue, May 14 2019 11:27 PM
Mr 10percent and Martin
Many thanks, two answers and two views, I'll have a think about it.
In the showroom the 65 looks impressive and I wonder if it will be too big for our lounge - mind you that's nearer £8k to change.
TEL
mawheele
Posts 245
My Eclipse received new Firmware yesterday. Just says it addresses bugs with no other detail.
AdamS
Posts 296
AdamS replied on Tue, Jun 4 2019 1:01 PM
Martin:
Best Regards
Relieved to read this - Mrs S. and I bought a 65" Eclipse at the weekend. Delivery and installation Monday week - can't wait!!
We also bought a Beosound Core for the dining room, so our Beolab 6000s can finally come back out of the loft.
TEL
Posts 48
TEL replied on Tue, Jun 4 2019 9:30 PM
I stayed with my Avant Mk 1
TEL
TEL
Posts 48
TEL replied on Thu, Oct 3 2019 9:41 PM
AdamsS
How's the 65 inch Eclipse?
I've today ordered a 55 inch Eclipse
TEL
Sweden
Posts 282
Martin replied on Fri, Oct 4 2019 1:52 PM
I have an Eclipse 65 and are very happy with it. I have not found any shortcommings at all with this TV.
The software is very stable!. You vill enjoy Your 55-inch Eclipse very much.
Good luck!
Best Regards
davvaer
Posts 5
davvaer replied on Fri, Oct 11 2019 7:51 PM
My friend and i installed my new eclipse 55 Bronze today. Pretty happy with it :)
Mikipidia
Posts 1,351
ONLINE
Mikipidia replied on Fri, Oct 11 2019 8:24 PM
I love your ceiling and room in general, looks really nice!
Hiort
Sweden
Posts 2,495
Hiort replied on Fri, Oct 11 2019 10:48 PM
davvaer:
Awesome install. No cables Yes - thumbs up
davvaer
Posts 5
davvaer replied on Tue, Oct 15 2019 9:17 PM
Thank you guys.
I have some problems controling my TV STB.
When i installed the Apple tv 4k i just choosed the apple tv 4th gen and it worked directly without any puc cables.
My STB Is a Motorola/Arris VIP 4302 from Telia. and its also Bluethoot controlled. Was thinking maybe it can also control ther STB thru BT but that seems not the case.
Got a Puc cable from my dealer today, My STB was not in the PUC list but played around and tried several Motorola VIP codes incuding generic.
None working. Anyone have any idea what to do?
AdamS
Posts 296
AdamS replied on Wed, Oct 16 2019 1:06 PM
TEL:
AdamsS
Generally, we love it. The picture is superb, the wireless interface with the BL90s and the rest of our stuff is faultless and it performs brilliantly. As an aside, the installation service from our dealer was superb and included hiding the cables inside the wall and re-plastering it. Very impressed!
Normal 0 false false false EN-GB X-NONE X-NONE
However, it has one weird issue that we, our B&O dealer and B&O Technical are struggling with - basically, sometimes it just won't switch off!
What happens when you press power off on the BeoRemote One is that the speakers all switch off, the picture shuts off and the Eclipse starts to fold back against the wall. However, when it gets about halfway, the ‘Bang & Olufsen’ logo appears on the screen for ten seconds or so, then goes away. Then, when the unit is flush to the wall, the logo appears once again for another fifteen seconds or so, and then whatever we were last watching reappears – if it was Live TV, the channel we were previously viewing comes back, or if it was our Humax box, then the “No Signal “ message is displayed, as the Eclipse has obviously switched the Humax box off. There is no sound, the speakers do not switch on, it does not respond to the Beoremote One or the app, and the app says that the Eclipse is in standby, but the picture is there and nothing can be done about it.
As a result, I'd been having to switch the set off at the plug every night and this, in turn, made it keep losing settings and generally behaving badly sometimes when re-started!
After some investigation, B&O Technical suggested it might be due to the internet connection and, if I pull out the lead to our home hub, it does indeed switch off properly. However, about two weeks ago in the middle of all this, we were sent a new hub by our broadband supplier and, with this installed, the Eclipse now does mostly swtch off correctly, but it still shows the 'Bang & Olufsen' logo as it shuts down, which it apparently shouldn't do.
I need to go back to the dealer again as I said I'd run it with the new hub for a couple of weeks to see how it behaved and, as it's a known issue (albeit a rare one), hopefully they'll be able to sort it once and for all.
Dyssegaard
Copenhagen, Denmark
Posts 193
Silver Member
I got a new Eclipse 55 last week and I’m working on the sound settings right now.
On my BV11-40 I can select “Adaptive” sound mode so that sound mode changes based on meta data in the TV channel.
However I cannot see this option on the Eclipse. Only “static” sound modes like “film”, “music” etc. can be selected.
Am I missing something or is “Adaptive” sound mode not present (yet) ?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40, AppleTV 4. Home office: Beolit 12, Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Dyssegaard
Copenhagen, Denmark
Posts 193
Silver Member
Dyssegaard replied on Thu, Jan 30 2020 12:46 PM
On my request to B&O support regarding adaptive sound mode, I have received the following reply (in danish):
“Denne funktion er desværre ikke mulig længere. Vi var nødt til at ændre på hvordan vi laver vores tv så de blev lettere og mere standardiseret at bruge. det har så betydet at vi ikke har helt så meget kontrol over softwaren der bliver brugt. Vi vil selvfølgelig give dit ønske videre til vores hovedkontor. Hvis vi formår at få funktionen tilbage vil vi selvfølgelig informere således”
In short: This function is no longer possible due to the way we produce our tvs now. We do not have so much control over the sw any more. We have forwarded you request to our headquarter, and we will inform you, if we are able to get this functionality back ...
Page 60 of 61 (2419 items) « First ... < Previous 57 58 59 60 61 Next > | RSS
