BEOVISION ECLIPSE
This post has 2,397 Replies | 20 Followers
BEOVOX141
Denmark, West
Posts 698
Silver Member
ECLIPSE DTS HD CAPABILITIES
Pure speculation on my part:
The C7 does have the HD codec, and since the back of the B&Oled was pimped, the original marking got lost in the paint shop.
So technically the DTS HD symbol from the TV is now located on the soundbar.
This time I really don't want to be right, because that would be outright sad... Unsure
Incidentally, this is why I asked Emil for a shot of the Panel type label..
Marcello:
Emil Jensen:
As I wrote in another thread, DTS-HD is now supported
I was not aware of that. Even B&O official website does not mention it... crazy.
Marcello
Posts 191
Silver Member
Marcello replied on Thu, Mar 8 2018 10:14 PM
BEOVOX141:
But that’s a B&O label specific to the sound center  not an LG one. I think it’s more likely that they did not update the audio specs on the website from the Beosystem4/Avant4K era.
Millemissen
Flensborg, Denmark
Posts 12,359
ONLINE
Marcello:
Millemissen:
Marcello:
Emil Jensen:
For what would you need this decoding capacity in the SoundCenter?
Many Blu-Ray nowadays are DTS-HD Master Audio (or Dolby TrueHD, still unsupported by B&O).
Any (halfway decent) Bluray player can do that - and has done for years.
BEOVOX141
Denmark, West
Posts 698
Silver Member
BEOVOX141 replied on Thu, Mar 8 2018 10:32 PM
@ Marcello
Remember its a UNIT, ONE type label. As MM says not a TV, but a BV!
My BV7-55 carries the DTS HD logo as well, but it does NOT have the codec!
However, the built-in BR does!
Marcello
Posts 191
Silver Member
Marcello replied on Thu, Mar 8 2018 10:43 PM
BEOVOX141:
@ Marcello
Ok I get what you mean now. But the player behaves in three ways
1) Passes through the DTSHD if supported by the HDMI sink (the Soundcenter)
2) Extracts and passes through the DTS core if DTSHD is not supported
3) Decodes and sends a setereo signal if DTS is not supported (the only reason for a player to have decoding capabilities, for analogue outputs or very old TV sets)
To me, it makes no sense to put it on a sticker if the TV cannot decode it. Ok it’s a unit, but if I had bought an Eclipse I’d be pissed off.
But maybe it’s just me being over sensitive on the issue since discovering and telling  B&O that my BV11 did not decode Dolby Digital Plus because of a wrong EDID information sent to the HDMI source...
BEOVOX141
Denmark, West
Posts 698
Silver Member
BEOVOX141 replied on Thu, Mar 8 2018 11:22 PM
Marcello:
Makes perfect sense since it has been the NO1 complaint for years! And technically the C7 (The Panel) CAN decode it. but to the best of my knowledge, the ARC channel doesn't have the bandwidth to return the stream back to the soundbar.
However, as MM points out, in 95% of the cases the BR source will do the HD decoding and convert it to a PCM stream, which the soundbar can easily handle (a simple demux). For the end user, there is NO difference.
If you like me use HTPC then there could be a difference, since its a lot easier to avoid the decoding in software. If you are using an AV reciver you also get the joy of seeing DTS HD in the displaySmile
Marcello:
That would be one way of putting it Smile
Remember my case is only circumstantial
Marcello
Posts 191
Silver Member
Marcello replied on Fri, Mar 9 2018 10:01 AM
BEOVOX141:
Marcello:
Yes, the quality is the same, whether it's decoded by the TV or it's converted by the player to Multichannel PCM (in my case, Plex on an Intel NUC to a BV11).
I just find it misleading to have DTS-HD marking on a B&O sticker since (if your assumption that only the panel can decode it is correct) it would mean that the Sound Center does not actually support it but still relies on the HDMI source to convert it to PCM. Meaning that the Soundcenter has not evolved in terms of decoding standards since the BS4-based TV Sets.
Millemissen
Flensborg, Denmark
Posts 12,359
ONLINE
Marcello:
That would be one of those 5% of the players, that I would have avoided.
And yes, mostly cheaper ones - those meant for connecting to a regular tv-only.
And those are normally not the ones, that someone who spends thousands of kr/€/$ on a B&O setup, would buy.
Marcello
Posts 191
Silver Member
Marcello replied on Fri, Mar 9 2018 11:20 AM
Millemissen:
Marcello:
I meant that a single player can behave in three ways according to the sink, I was not considering the 5%. In the case of the Eclipse, if only the panel decodes it, it is irrelevant since I suppose most of us would plug stuff in the SS to have PUC support etc.
Anyway I will visit my dealer with a DTSHD file and see for myself the result.
Millemissen
Flensborg, Denmark
Posts 12,359
ONLINE
Marcello:
Oh - there we go....a file, not a disc ;-)
I am pretty sure, that if you play that back directly via the LG’tv-part, you will get a two channel decoded stream (to the SoundCenter).
And if yon play it back via the SoundCenter, it will pick the core DTS signal and play that.
That is, if ‘a DTSHD file is accepted via USB at all!
Marcello
Posts 191
Silver Member
Marcello replied on Fri, Mar 9 2018 11:52 AM
Millemissen:
Marcello:
That’s what I expect. So the sticker basically says “we support DTSHD but we will convert it to stereo” :)
Millemissen
Flensborg, Denmark
Posts 12,359
ONLINE
Marcello:
Yes, because that is what the LG (probably) will do.
The question remains....why put that sticker on the SondCenter, then?
phirstpro
Posts 67
phirstpro replied on Fri, Mar 9 2018 12:02 PM
Millemissen:
Marcello:
I find it hard to believe anything that Bang and Olufsen says these days!
PBSH
BeoET
Posts 73
BeoET replied on Fri, Mar 9 2018 6:04 PM
Since yesterday the Sound part of the Settings menu (part of the 1st row in the Settings menu) has been unavailable . Anyone else who have experienced that? When using the remote I still can shift between the different speaker setups, but it is not possible to adjust the Sound settings in the settings menu. I’ve checked for FW updates - no new ones available.  Sw version: 1.3.20036.213941967
BV Eclipse 65, BV5, BS Core, BL5, BL8000, BS9000, Beolit 12, A1, A2, P2, H8, H9i, H7, E8
Stan
Posts 613
Stan replied on Sat, Mar 10 2018 1:51 AM
I cannot get to sound icon from the first settings menu.  However,  I don't recall ever doing it this way. I just go to the second menu where sound is available.
Mikipidia
Posts 907
Mikipidia replied on Sat, Mar 10 2018 5:18 AM
Mine seems fine, but the tv has to be fully on. So wait until its in place and then try, maybe that’s it.
New: Beolab 50's, Beolab 18's, Beolab 17's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3.
Mikipedi4 on YouTube
https://www.youtube.com/c/mikipedi4
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Fidse
Posts 175
Fidse replied on Sat, Mar 17 2018 9:39 PM
As to my own earlier question about bluetooth connection to headphones the simple answer is; no... there is no bluetooth transmitter to headphones in the Eclipse... I’m stunned, that’s just plain stupid... But now i’ve got myself an external bluetooth transmitter. I’m yet to try it out, but my dealer says it works perfectly. I’ll post about sound quality and connection stability when i’ve had a chance to try it out.
Marcello
Posts 191
Silver Member
Marcello replied on Sat, Mar 17 2018 9:52 PM
Fidse:
Can you tell us the brand and model? I use one made from Telme2 but it’s far from perfect.
Fidse
Posts 175
Fidse replied on Sat, Mar 17 2018 10:17 PM
This is the one. It doesn’t exactly look very “pro” either...
Fidse
Posts 175
Fidse replied on Sat, Mar 17 2018 10:33 PM
I wanted to test them now But my wife said no, you’ll wake the kid!
So now i have the whole night for testing, since i’ll be sleeping on the couch anyway Big Smile
BEOVOX141
Denmark, West
Posts 698
Silver Member
BEOVOX141 replied on Sat, Mar 17 2018 10:37 PM
Fidse:
Heres a novel idea for you. I seem to recall this was for late night listening, not upsetting the rest of the family...
Why not get a Reciever 1 and use the WISA environment. The PL output can easily drive a set of earphones and you won't have to deal with sub-par BT!
Admittedly,- You are stuck with a wire, but the RC1 is small and can be placed anywhere.
Fidse
Posts 175
Fidse replied on Sat, Mar 17 2018 10:51 PM
Mnarh... this is actually mostly for the audio when watching Champions League matches, when the kids are asleep. It does’nt have to be top notch audio, the convenience of the wireless part is more important to me, in this case . But while i have you... how the f*** did you connect yours? I’ve got an rj45 to minijack cable, but when i search for speaker connections, i get nothing? Did i do it wrong?
BEOVOX141:
Fidse
Posts 175
Fidse replied on Sat, Mar 17 2018 10:53 PM
Oh forgot the pic...
Ps. I’ve tried “the back” Line of outputs as well, i think it’s a bit confusing, as to What’s PUC and what’s PL...
BEOVOX141
Denmark, West
Posts 698
Silver Member
BEOVOX141 replied on Sun, Mar 18 2018 11:01 AM
Fidse:
  .......But while i have you... how the f*** did you connect yours?
Sorry, I was way too frugal to consider the Eclipse and opted for the original.
Which is also why I properly can't help you with the service menu  Cool
Millemissen
Flensborg, Denmark
Posts 12,359
ONLINE
Fidse:
It seems to me that you have plugged the cable into a wrong port. (The ports are labeled below, but in your picture these are hidden by the cables there).
Pick the right one in the lower row for PL1...if I remember well.
Go into Sound Settings/Speaker Connections, find the PL1 and configure that (the on-screen menu should tell you more) as ‘Other/Andre’ - I suppose that is the term used for any non-B&O speaker as with the previous BSys4-based systems!?
N.B maybe you’ll have to ‘select SHOW ALL’ first!
Then go create a new Speaker Group adding only this output. Make the settings there.......
Give this Group a name.
When you want the sound from only this group (means without activating the internal speaker, just the output to the BT-transmitter), you will have to choose this group via your BeoRemoteOne.
How well the volume control is going to work, I don’t know!!!
tigerisak
Posts 105
tigerisak replied on Wed, Mar 21 2018 7:33 AM
Im having issues with the ABL on my Beovision Eclipse. And from what I have heard and read from Bang Olufsen it is not possible to disable.
When a white scene that has more than 60% white color, the screen dims drastically. On LG televisions this can be disable through an option called ABL but not on the Eclipse.
Got this answer from Bang Olufsen support: ABL is an LG protection Feature to avoid OLED screen damage.
In some LG TV's settings can be adjusted using a special Service Mode remote control.
At the Eclipse this service mode is not available for customers and unauthorized change of settings may influence warranty.
Only standard Picture settings can be changed.
Please try it out to see if you can find settings that will minimize the dimming effect
I have disabled the Eco settings and turned down the auto contrast to none. Any suggestions?
Sweden
Posts 266
Martin replied on Thu, Mar 22 2018 12:59 PM
I have one PUC-related problem with my Eclipse where I think it is software-related. I have one Apple TV connected to HDMI C and one Oppo bluray connected to HDMI D. I use PUC-codes for both of these devices.
My problem: When I start Apple TV:n then the Oppo-player starts also. When I start Oppo-bluray player the Apple TV starts also (both starts up any way). When I start ordinary TV both Apple Tv and Oppo bluray starts up.
Is there a solution for this?
Best Regards Martin
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
poodleboy
Posts 251
poodleboy replied on Thu, Mar 22 2018 2:51 PM
I used to own an 11-55 with Oppo and Apple. Unless something has changed in PUC in last 2 years, I am sure those PUC will not respond to the same command. IF that is truth, how can one command activate 3 controllers, 2 of whom had the incorrect command? For that reason I would not guess it is software, but firmware or even a failure in the remote controller?
Hiort
Sweden
Posts 2,335
Hiort replied on Thu, Mar 22 2018 3:01 PM
Martin:
Best Regards Martin
Is the problem just that they start up?
You get the right source activated when you press e.g AppleTV?
Sweden
Posts 266
Martin replied on Thu, Mar 22 2018 3:05 PM
Hi, Yes I got the right source. It is just that all PUC-controlled products start up when I choose one of them. Do You have the same problem?
/Martin
Hiort
Sweden
Posts 2,335
Hiort replied on Thu, Mar 22 2018 3:27 PM
Martin:
/Martin
I do not have the Eclipse unfortunately Smile
I just wanted to clarify the problem. On my BV11 that does not happen.
Some of the Eclipse owners must be able to confirm if this is the way it should work.
phirstpro
Posts 67
phirstpro replied on Thu, Mar 22 2018 4:03 PM
Hiort:
Martin:
/Martin
hi  I have an Eclipse 55 and have Blu-ray, Sky Q and Apple 4K  all work independently on their own PUC.  I’ve always assumed that as long as you associate a PUC with a particular HDMI port the port selected will activate the associated PUC.  So selecting Apple TV for instance will not fire up Sky Q or my Blu-ray player.  This is certainly the case with the setup I currently have. I can only assume if it didn’t it would get really confusing if all devices responded to inputs from the remote!
in settings you can see what HDMI port your currently configuring and select the PUC table, socket and device. Under “sources” you would select the device by name (once it has been set up as a source) and go to Device setup  there you would select the PUC table and physical socket your cable is plugged into.
As all devices have different codes only the one you have requested should respond as the PUC table dictates that.
i hope this is helpful and not confusing you more.  Basically provided the device is named and associated with an HDMI and the PUC cable is associated with the device by  selecting the PUC port and it has the correct table downloaded it should work fine!
cheers  Peter
BeoMegaMan
Posts 575
Sounds like what you're experiencing is related to CEC. Go into both the Apple TV and Oppo and turn off CEC or alternatively you can play around with CEC in the Eclipse settings.
Ah, you know... A little B&O here, a little there
Roger
Norway
Posts 416
Roger replied on Thu, Mar 22 2018 5:22 PM
Hei Martin - this is a known issue, and the remedy is improved settings for disabling HDMI CEC with the new software version 1.4.20794: "HDMI Control on/off".
This sw was released on March 14th.
Roger
mr_anders_son
sweden
Posts 1,530
Roger:
Roger
Roger, I can not find this option in the Menu!!
I have the latest SW!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
Roger
Norway
Posts 416
Roger replied on Thu, Mar 22 2018 8:36 PM
Till Anders och Martin:
BeoVision Eclipse supports CEC on all HDMI sockets. CEC allows control of connected equipment without the use of PUC cables as it works via the HDMI connection.
Different vendors have their own understanding and implementation of CEC, and some equipment will not work well with the BeoVision Eclipse. There is often a lot of limitations when using CEC, and we still recommend using PUC when possible.
The CEC will remain active until you configure a PUC control for HDMI. When the PUC is configured, the BeoVision Eclipse will not send CEC control commands, but will only control the connected device via IR PUC.
When using PUC together with a device that supports CEC, it is important that you disable the CEC.
There are different possibilities of disabling CEC:
Method 1 - used if you have a mix of CEC and PUC controlled HDMI sources:
Set "HDMI Control" to "OFF" in the source setup on the HDMI connector in question. This will disable CEC in that one HDMI e.g. HDMI A, and CEC will still work on HDMI B-D.
Some CEC commands cannot be blocked this way. BeoVision Eclipse is still open for certaincommands e.g. source selection, which is why it is recommended to switch off CEC in the source (e.g. Blu-ray player) if possible.
Method 2 - used if all HDMI-connected sources are controlled with PUC:
If no CEC is used on HDMI A-D, we recommend disabling "HDMI Control" on all SoundCenter HDMI's (A, B, C & D) regardless if only one HDMI socket is used.
By disabling "HDMI Control" on all HDMI's, the CEC will be completely ignored by the TV when not in standby.
If this CEC setting/HDMI Control not taken into consideration when installing a TV, the connected devices can send CEC commands to the BeoVision Eclipse which will cause conflict with the PUC control and potentially cause unwanted behaviour like automatic source change or the TV switching on by itself.
poodleboy
Posts 251
poodleboy replied on Fri, Mar 23 2018 12:12 PM
Roger:
"clipped"
Was this in the Manual or was B&O the only TV company that didn't know about CEC? As even I (and every other B&O lover) know, whilst software patches are necessary and appreciated, they often create unintended consequences.
Roger
Norway
Posts 416
Roger replied on Fri, Mar 23 2018 12:29 PM
@Anders - just double checked, the HDMI control with the toggle on/off is under the menu called TV and then HDMI///Roger
Sweden
Posts 266
Martin replied on Fri, Mar 23 2018 12:41 PM
Hi Roger,
I thought that I should go in under "sources" and choose each connected source and in that menu choose to put HDMI-control to "OFF".
I can not find a meny called "TV" on my Eclipse.
/Martin
mr_anders_son
sweden
Posts 1,530
Roger:
Has no ”TV” option in the Menu
Page 49 of 60 (2398 items) « First ... < Previous 47 48 49 50 51 Next > ... Last » | RSS
