BEOVISION ECLIPSE
This post has 2,390 Replies | 20 Followers
Emil Jensen
Denmark
Posts 399
I turned off the the tv, now everything is working.
Have just tried Uncharted 4 in HDR for some minuts, no problems. So yea I have not played for hours yet, but your problem might be the HDMI cable?
Are going to buy a Apple TV sunday for more testing.
Beovision Eclipse, Beolab 20, Beosound 1 Google assist, Beoplay M3, Beoplay H6
Fidse
Posts 175
Fidse replied on Fri, Feb 16 2018 9:36 PM
I don’t know, could be an update since i tried, that was about 3 weeks ago.
It can’t be the cable, it worked fine on my old LG B7, and there are also no problems when i plug it straight into the panel.
I’ll try and flip it back into the soundcenter one of the following days. I would love it to work, so that the tv changed input automatically, when i turn on my PS. Other than that, no problems.
Emil Jensen
Denmark
Posts 399
Hi Fidse, how do you experience the drop outs on PS4Pro?
I think I also have them, the picture disappears, but the sound is there?
Emil Jensen
Denmark
Posts 399
I tired to turn off HDR, no difference,
I then forced it to 1080P, that seems to have help.
Hmm then I rather keep my PS4 Slim...
Emil Jensen
Denmark
Posts 399
Okay played 30min. with 2160p - YUV420,
I played GTA V so no HDR, but it works so far.
So try it out.
Fidse
Posts 175
Fidse replied on Sat, Feb 17 2018 9:55 AM
Emil Jensen:
So try it out.
Beolab 20, Beolab 17, Transmitter 1
My dropouts are exactly as you describe them, sound but no picture. If it does’nt work with HDR, I’m just gonna keep it in the tv panel. HDR was the main reason for me to buy the Pro. I actually only use my PS for playing FIFA, litteraly nothing else. So what i can, and can not do besides playing FIFA in 4k HDR, does’nt really matter to me Big Smile
BEOVOX141
Denmark, West
Posts 569
Silver Member
BEOVOX141 replied on Sat, Feb 17 2018 10:53 AM
Fidse:
@ Fidse
What is your experience with the Viasat CA module ? Both with the LG and your previous TV.
Fidse
Posts 175
Fidse replied on Sat, Feb 17 2018 11:02 AM
BEOVOX141:
@ Fidse
It works fine. It’s exactly the same with my old B6 and the Eclipse.
Every now and then it switches from “Viasat mode” to “normal satellite mode” meaning that my channels switch places, so i have to manually change it back. But it only takes a few seconds to change and it does’nt happen very often, so all in all I’m very pleased with it. I’m just glad i don’t need an extra box Smile
BeoGreg
South of France
Posts 1,412
BeoGreg replied on Sat, Feb 17 2018 11:33 AM
We need a pic of your new toy Emil !
Beovision7
Derby
Posts 9
Silver Member
I love the OLED picture but I also love the B&O sound, wanted an eclipse but couldn't stretch to the price, so made my own version and I think it looks better than the eclipse now :-)
I just need B&O to bring out a Beosystem 5
Aussie Michael
Melbourne, AU
Posts 3,295
Beovision7:
What does the build your own version look like / contain?
Emil Jensen
Denmark
Posts 399
Fidse:
Thanx fu21.
That’s just not good enough! I would have connected it to the tv then, But then the cables won’t fit since i’ve already place my ps4 there as well, since that won’t work through the soundcenter either No - thumbs down
That they’ve got to get fixed. Having a fully equiped OLED screen and not being able to play Dolby Vision is just plain stupid....
I have got the Apple Tv to work now.
If you set it to SDR 4K as standard but set it to adjust to source automatic, it will work.
I have seen 6 episodes Altered Carbon in Dolby Vision 4K without problems.
Also I got the PS4 Pro to work. Though I must turn the Tv to the source before turning the PS4 on. Also the HDMI is set to output YUV420.
Emil Jensen
Denmark
Posts 399
Do anyone know if it is possible to adjust the list in "List" so you have stand as first pick and so on?
Also if it is possible to hide a source, as Netflix, as I use the Apple Tv.
Fidse
Posts 175
Fidse replied on Fri, Feb 23 2018 10:29 PM
Emil Jensen:
I don’t think you can hide the built-in sources. I’ve just pushed the ones i don’t use all the way to the bottom, that way i don’t notice them.
Fidse
Posts 175
Fidse replied on Fri, Feb 23 2018 10:44 PM
Emil Jensen:
Seems strange about the Appletv, but i’ll try it out.
On the PS, that sounds like a great solution. I found a thread on flatpanels.dk describing the issue, could be the one you’ve read yourself? Smile
Where they conclude that for HDR games you should have it set to YUV420 anyways. And since i only play one game, wich is HDR, for me at least it’s a fine solution.
Stan
Posts 606
Stan replied on Fri, Feb 23 2018 11:55 PM
Emil Jensen:
I don't think you can delete anything, and I haven't found a way to change the order of "list". However, you can re-order the "TV" list by going in to  "settings", then "sound & beolink" then "sources".  This gives you the list of sources and if you hit "edit" you can re-order them, and this new order is reflected in the remote.
Stan
BEOVOX141
Denmark, West
Posts 569
Silver Member
BEOVOX141 replied on Sat, Feb 24 2018 12:03 PM
@ Fidse
Viasat Cam modulet....
På dansk så tråden bliver forstyrret mindst...
Kan du ikke lige dele data på TV2 HD jeg kan simplelt hen ikke finde den!
Viasat siger 11,345mHz men den er der ikke, og på Lyngsat.com kan jeg heller ikke finde noget.
Beofan67
NETHERLANDS
Posts 49
Beofan67 replied on Sat, Feb 24 2018 2:21 PM
So far it is not possible to reorder the items behind LIST I was told by my dealer. However from my opinion this is one of the top3 issues for the Eclipse to solve. Another one is to add some Eclipse functionality in the App (i.e. stand, sound, speakers).
Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11
Fidse
Posts 175
Fidse replied on Sat, Feb 24 2018 3:55 PM
BEOVOX141:
@ Fidse
Jeg havde samme problem med flere kanaler.
Du skal gå i
indstillinger - billede & programmer - kanaler - kanalindstillinger
og så vælge VIASAT under programtilstand.
Så burde de alle være der.
BEOVOX141
Denmark, West
Posts 569
Silver Member
BEOVOX141 replied on Sat, Feb 24 2018 5:26 PM
@ Fidse og andre der anvender Viasat?
Husk jeg har et helt andet chassis (7-55).. Den kender ikke viasat! Men finder 400 andre kanaler.
Det er meget underligt for TV2 HD er den eneste kanal der umiddelbart mangler.
Og hvad er endnu mere underligt er TV2 HD IKKE kan findes på lyngsats kanalliste, et eller andet sted må den vel være!
Derfor leder jeg med lys og lygte efter frekvens/symbolrate/polarisering for TV2 HD
Fidse:
BEOVOX141:
@ Fidse
Du skal gå i
kuyttendaele
Posts 440
Ik kan anders ook wel de lekkere Brusselse wafels aanraden! Echt wel de moeite!
BEOVOX141:
Fidse:
BEOVOX141:
@ Fidse
Du skal gå i
Millemissen
Flensborg, Denmark
Posts 12,112
Not sure they eat belgian waffles in Denmark - they are more into smørrebrød.
Fidse
Posts 175
Fidse replied on Sun, Feb 25 2018 12:54 PM
BEOVOX141
You should probably start a thread with the question in the nordic section, if you want to do it in danish ;)
I can’t help you right now as i’m in Jylland. I’ll be home next weekend, i can see if i can help you there, if you haven’t figured it out by then.
kuyttendaele:
Mikipidia
Posts 805
Mikipidia replied on Sun, Feb 25 2018 1:36 PM
Brusselse wafels met vers fruit, heerlijk! Bij le gand place zitten een aantal goede in de buurt, dan heb je ook gelijk een mooi uitzicht!Stick out tongue
You’ve made me hungry now Big Smile
New: Beolab 50's, Beolab 18's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3.
Mikipedi4 on YouTube
https://www.youtube.com/c/mikipedi4
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Beoberg
Odense, Denmark
Posts 311
Beoberg replied on Fri, Mar 2 2018 6:52 AM
Just ordered an Eclipse 55" with Oak cover and wall bracket. It will replace my beloved 11-55. My BeoLab 9's have to go aswell. Boy have I enjoyed those! But times have changed and we need something lighter in our livingroom. I am very curious about the difference in sound between 5.1 from BV11+BL9+S8 and now Eclipse+S8 only. Delivery within 14 days. I have not bought brand new BeoVision since BV 8-40. I can't wait! Lets have a Party !!!
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay M5 (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 3 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Fidse
Posts 175
Fidse replied on Fri, Mar 2 2018 9:02 AM
My Eclipse speaker accompanied by a BL19, replaced an LG OLED and a pair of System Audio Rangers driven by a Densen b250cast and a 240w Densen power amp.
I’m not saying the Eclipse is as good sounding, but when you include all the other things, such as user friendliness and the extra space i’ve got from getting rid of the floorstanding speakers, i don’t miss them one bit!
The Eclipse sounds fantastic! But in my case, i “needed” the subwoofer.
Beoberg:
BeoVision 11-55 MKI (primary), BeoLab 9 (front), BeoPlay S8 (sub+rears), BeoLab 3500 (dining room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 1 old (leisure room), BeoSound 3 (workshop), 2x BeoPlay S3 (PC), BeoLit 12 (kitchen), BeoPlay A1, BeoPlay P2 (everywhere), BeoPlay H2/H3 (on the go)
Beoberg
Odense, Denmark
Posts 311
Beoberg replied on Fri, Mar 2 2018 9:07 AM
Hi Fidse. Thank you for your respons. I am also quite sure that I will not regret my decision. I do have a sub in the form of the S8 main unit Wink
ErikVonAgnar
Posts 193
Great to hear you bought yourself a new Eclipse and with the new oak cover.
If you would like something "light" in regards to speakers, have you tried Beolab 3? or even wall hanging Beolab 17?
The Soundcentre has plenty of sound for the TV alone. I had the Avant before my Eclipse and it needed a subwoofer, not so sure of a subwoofer is necessary at first. I mean if you want a full experience then go for a subwoofer but if you want something light in the living room.
//EA
Beo in white is my thingBig Smile
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
Fidse
Posts 175
Fidse replied on Fri, Mar 2 2018 9:18 AM
The 17’s are quite an overseen little gem. Absolutely fantastic sounding speakers considering price and also size. Other than that, i believe they pack much of the same speakertech as the Eclipse, so sonicaly they will be a great match. I’m getting a pair for surrounds with my Eclipse.
ErikVonAgnar:
Great to hear you bought yourself a new Eclipse and with the new oak cover. If you would like something "light" in regards to speakers, have you tried Beolab 3? or even wall hanging Beolab 17? The Soundcentre has plenty of sound for the TV alone. I had the Avant before my Eclipse and it needed a subwoofer, not so sure of a subwoofer is necessary at first. I mean if you want a full experience then go for a subwoofer but if you want something light in the living room.
//EA
Beoberg
Odense, Denmark
Posts 311
Beoberg replied on Fri, Mar 2 2018 9:55 AM
Hi Eric
I have had the BeoLab 3's along with a BL11 when I had the BV 8-40. Nice speakers! As I wrote earlier I have the S8 2.1 set so I will still have 5.1 as the Eclipse will serve right, left and centre and the S8 will be rears and sub.
Best regards,
Frederik
ErikVonAgnar:
//EA
Hiort
Sweden
Posts 2,288
Hiort replied on Fri, Mar 2 2018 2:53 PM
Fun to see that so many forum members have embraced the Eclipse after all  Smile
Beofan67
NETHERLANDS
Posts 49
Hiort:
Once you've seen (and hear) the Eclipse live you are sold Smile
Hiort
Sweden
Posts 2,288
Hiort replied on Fri, Mar 2 2018 3:10 PM
Beofan67:
Hiort:
Thats the experience I had :)   Don´t have the funds available for an upgrade currently. And Eclipse cannot integrate to Moment like the BV11 I have.
Sweden
Posts 254
Martin replied on Fri, Mar 2 2018 3:18 PM
I have had my Eclipse 65 for a month now. I am very satisfied with it. I had before a Beovision 7-55 Mark II and was "afraid" that the PQ on the Eclipse not was on par with 7-55 MkII. But I was wrong. I can say that all parameters regarding PQ is at least on par with 7-55 mkII (when looking at 720 p, 1080i and 1080P) and there is of course 4K movies which is outstanding in PQ.
I have put a lot of efforts in calibrating the PQ. There is a lot of possibilities in the Eclipse. Now I am very pleased. But I recommend NOT to use the eclipse with the "ECO" mode which is standard for the Eclipse.
I was also afraid that there was some software-bugs in the Eclipse that I have read on this forum. But after a lot of SW-updates I can say that the Eclipse is free of SW-problems now and works like charm. It is as good as my old BV 7-55 Mk2 which also was free from SW-problems.
Finally: I am very pleased totally with NO complaints at all. I have also two Beoplay A6 as multiroomspeakers (in two other rooms) and the multiroom-system works perfect with the B&O-app.
So if anyone is worried about software problems as other earlier Beovisions had (BV14 and Avant NG), there is NO such things in the Eclipse and the Beoplay A6 if combined together in a multioom setup. The Beoplay A6 got a new softwareupdate a couple of days ago which makes the A6 very stable and the Cast-functions works perfect.
Have a nice weekend!
Best Regards
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Beofan67
NETHERLANDS
Posts 49
Hi Martin
Agree fully. But from my point of view some functionalities in the remote one like mybutton functionality and change order behind the LIST menu should be fixed and added. And in the App the option to change BV stand or speaker settings would be nice. But this will come I rely on.
phirstpro
Posts 67
Hello to all you Eclipse owners.
‘Now that the Oak speaker grill (Lamella) has officially been released, how many are going to rush out and buy one?
Maarten
Germany
Posts 8
Maarten replied on Fri, Mar 2 2018 10:12 PM
Yep, and for the 18s
KMA
Posts 569
KMA replied on Sat, Mar 3 2018 1:09 AM
Martin:
Indeed – and oh lord no – not the ECO setting that LG's C7 also has as default. If the Eclipse already has the Technicolor preset available (should be via software update), set it for every source!
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
Beofan67
NETHERLANDS
Posts 49
phirstpro:
No not for me. I like the Eclipse fully black.
I wonder how the panel would match with the Beolab wooden panels. Looking from the picture the full wooden front is not built up with single panels like it is for the BL and the BV14 for instance.
But maybe in live it is amazing - like the Eclipse is Big Smile.
Emil Jensen
Denmark
Posts 399
A center view
Page 47 of 60 (2391 items) « First ... < Previous 45 46 47 48 49 Next > ... Last » | RSS
