Anyone still using Linkplayer? Having issues with Playlist and latest iTunes version
Not Answered This post has 0 verified answers | 16 Replies | 0 Followers
stampfki
stampfki posted on Thu, Jun 1 2017 2:55 AM
Hi all,
Anyone?
elephant
AU
Not I Sad
And I was a stalwart Sad
And the latest Mac OSes (now a year old) first crippled LinkPlayer 2 beta Sad
And LinkPlayer 1 Sad
The last time I tested it BMLink still worked.
I now use the new (X) App "Bang & Olufsen Music" to access via DLNA my Plex which points to my iTunes Library to play my music Indifferent
Although to be honest [:\'(] I am using the (X) App to play from Deezer ...
BeoNut since '75
RobN
RobN replied on Thu, Jul 27 2017 8:42 AM
Hi Elephant,
Please can you give a bit more detail on how you now source music on you Mac and play it on the B&O system? It would be really helpful to have both the hardware and software connections outlined, many thanks?
I'm still using BMlink on MacOS Sierra connected via a DACmagic (optical digital to RCA analogue) to a old BeoLink PC2 to my masterlink network. Control is via Apple Remote App on iPad on wifi controlling iTunes on the Mac. It still works well, but I know it's only a matter of time before BMlink stops working, so understanding your set-up would be really helpful, thanks.
Best,
Rob
elephant
AU
Hi Rob
My primary use is streaming from Apple Music although do also have all my tracks archived in iCloud Music (annoyingly that's two separate monthly fees) with Family sharing turned on even though my wife rarely uses that.
My secondary use is what you would interested.
My media is on a MacMini and it's WD USB connected hard drive (including the iTunes library i.e. It is not on the mini's hard drive).
I access it via DLNA on my hand held devices talking to a PLEX server on the MacMini and which is pointed at the iTunes library on the external disk.
I access the PLEX movies and TV shows via the PLEX app on the Apple TV.
Which brings us to the third use: Apple TV accessing Apple Music OR the iTunes music in my hard drive.
I can distribute this music across my ML network and even my NL. Although I find casting/air playing from hand devices easier.
And finally I can also use the PLEX ATV APP to access the iTunes library via the PLEX server path !
I hope that helps.
Happy to provide screenshots of the different interfaces, configurations, and a connection diagram.
BeoNut since '75
RobN
RobN replied on Sat, Jul 29 2017 10:49 PM
Hi Elephant,
Many thanks, an impressive set-up with a lot of versatility. Your offer of some diagrams would be really helpful, thanks.
best,
Rob
RobN
RobN replied on Sat, Jul 29 2017 10:50 PM
Hi Elephant,
best,
Rob
RobN
Hi Elephant,
best,
Rob
RobN
Hi Elephant,
best,
Rob
elephant
AU
elephant replied on Sun, Jul 30 2017 12:35 AM
Here is the overview
Let me know where you want me to zoom in for details (or redraw)
BeoNut since '75
Pestria
Are you able to distribute the apple tv (music) around the ML network,  eg access it from a B&O product in another room?
Alan
Stefan E
Sweden
I have my setup like that and it´s possible to stream from the ATV and control it in from all link rooms.
So I have old beovisions that are able to use the ATV easily this way, not the best picture but good enough at least for me.
Just make shore that the videomaster get the signal as CVBS (standard video signal) via the SCART or Video in, if you only have HDMI connection you can´t transfer the video via the RF-link connection. Of cause you need to have areal cable from the mainTV to all link room TV´s.
So if you does not want to loose resolution on the main beovision you better use a HDMI splitter and then add a HDMI to SCART converter to the extra hdmi connection you got via the splitter. Then you have full resolution on the main TV and can still distribute the signal via the RF link.
 Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
Stefan E
Sweden
Alan, just realized that I missed that it was just the music you was intrested in.
elephant
AU
elephant replied on Fri, Mar 23 2018 10:27 AM
Pestria:
Alan
In my case yes.
It is not related to linkplayer.
My ATV is associated to DVD as a source and so in a link room I select DVD and I get that audio.
What I can’t easily do is control the ATV ... you really have to be in the room with the ATV and it’s BV.
Obviously (perhaps not) you can’t have the BV doing something else at the time ... it also has to be playing the “DVD” although you can mute it Big Smile
BeoNut since '75
Pestria
Is that connecting via the hdmi connection into the video master?
I think I had my ATV connected as v.MEM (or similar) via HDMI to bv 8-40 - but couldnt seem to link it around the house, so instead I connected an Airport Express to aux-in on the beosound 9000 which works fine.
I have another use for the Airport Express so wouldn't mind being able to use an Apple TV instead via the video master.
elephant
AU
elephant replied on Sat, Mar 24 2018 10:58 AM
Yes my ATV is connected to my BV8-40 via HDMI.
Give yours a go !
BeoNut since '75
Page 1 of 2 (17 items) 1 2 Next > | RSS
