M5. Play from standby?
Answered (Verified) This post has 1 verified answer | 4 Replies | 1 Follower
jimcaj
Denmark
jimcaj posted on Wed, May 31 2017 6:52 PM
Hi
M5. My first B&O product.
Cannot re-start radio *on-device* after standby:
X app. Tunein are set up.
Play radio. Works.
Put M5 on standby.
I decide to start listening again.
I press M5 top to pick up where it left. To no avail. Cannot get it to play.
Working as designed?
/ mike
mbolo01
Annecy - France
Verified by jimcaj
Please check the order of your local sources using the BeoSetup or a web browser pointing to http://<M5 IP address>
Go to: Your content / sources / in local list and make sure only your active sources are up and put Tunein first in the list
BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
mbolo01
Annecy - France
Verified by jimcaj
jimcaj
Denmark
jimcaj replied on Wed, May 31 2017 7:58 PM
Yes, that was it. I used the browser. Works fine now.
Thanks a lot mbolo01.
mbolo01
Annecy - France
You are welcome, and if you don't know the tip already, by turning while pressing the wheel you navigate through your preferred TuneIn stations.
jimcaj
Denmark
jimcaj replied on Wed, May 31 2017 8:49 PM
Yes, I did know. But, thanks anyway.
I hope that future firmware will allow for further reducing the bass. I've set it to corner.
Page 1 of 1 (5 items) | RSS
