BeoVision 11 network connection issue
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
JC
West Yorkshire
JC posted on Fri, May 12 2017 1:20 PM
HI all.
    Bit of advice and knowledge needed.
       We have our BV11 connected to the router via LAN and a NL/ML converter also connected. Every time I try to access webmedia  or radio/cd via the converter there is no internet connection and I need to reboot the router.
        Is it a better solution to have the TV connected via wi-fi, I am surprised if so as thought hard wiring the tv to the router would be seamless>
Cheers
 Jonnie
Hiort
Sweden
Hiort replied on Fri, May 12 2017 4:18 PM
JC:
HI all.
Cheers
Jonnie
When I had a NL/ML and a BV11, I connected them wired via a switch to an airport express. The express was configured to extend my router network over wire. Between the express and the router it was a wired connection using Powerline adaptors.
Worked really well.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2  Library: A6, Beocom 6000 Bedroom: M5, Essence remote  Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
Sweden, Skövde
Martin replied on Sat, May 13 2017 9:09 AM
You could try to use fixad IP instead of DHCP to see if you get a more solid connection. It is usually prefered when connection software for DHCP such as b&o' is bad.
Page 1 of 1 (3 items) | RSS
