Thanks to Dillen
This post has 42 Replies | 8 Followers
pepps
Kent, UK
Posts 103
pepps Posted: Tue, Sep 4 2012 6:48 PM
General shout out to Dillen for supplying belts for my Beogram 5005 and Beocord 5500 - both fixed up a treat in about an hour. Full instructions provided (a double-up of instructions for Beocenter 9500 and Beocord 6500 but in the end it worked out sweet!).
The Beocord 5500 is such an easy deck to work on compared to the 3500 which I've fixed up before. Sooooo much more simple.
During the repair I noticed the disc clamp for the slider belt was loose - the nut which holds it in place had unscrewed a bit. This was causing a 'scraping' sound each time I used the deck drawer. Tightened that up and the drawer's nice and smooth again.
Tapes play properly now and wind speeds have improved by several seconds.
The Beogram sounds 'lighter' and some classical pieces with sustained notes really do shine now.
Very happy so a big thanks to Dillen!
Peter
Earsdon
Posts 11,956
Peter replied on Tue, Sep 4 2012 10:07 PM
It has to be said that Beoworld would be a much poorer place without Martin. He has so much knowledge and is always happy to help. He is also a really great guy and I am proud to call him a friend.
Peter
elephant
AU
Posts 8,218
Agreed !
Dillen helped me rescue a Beocord 5000 many years ago
BeoNut since '75
ironjaw
Posts 4
ironjaw replied on Wed, Sep 5 2012 12:23 PM
I'm new here, although I don't know Dillen, I agree with all of you.
Dillen
Copenhagen / Denmark
Posts 11,622
Dillen replied on Wed, Sep 5 2012 8:34 PM
Thanks guys.
B&O, collecting, restoring and repairing has been a hobby for me for more than 35 years.
Having such a lovely bunch of Beoworlders to share it with, is just wonderful ! Wink
georganic
Posts 11
georganic replied on Wed, Sep 26 2012 9:31 PM
Hi Martin,
While we're on the subject of Beocord 5500's, I have a question: Mine plays back fine, when hooked to a conventional amp.  You see the previous owner cut the DIN plug off and wired 2 RCA's to the green and blue leads.  I would like to re-install a 7 pin DIN, of which I have one, a solder on type.  The pins are numbered (and I can't read them very well) in an odd fashion.  I could probably solder them on, carefully, if I had a diagram of some sort.  I'm assuming the woven copper surrounding the wire is a ground.
Thanks in advance for your help,
GJS
Beobuddy
Utrecht, The Netherlands
Posts 3,679
ONLINE
Beobuddy replied on Wed, Sep 26 2012 10:00 PM
http://beotech.beoworld.org/mclconn3.htm
Bob
Charente, France
Posts 418
Bob replied on Thu, Sep 27 2012 12:18 AM
I've to say that Martin was the second person on BW I've got the pleasure to deal with you, I'm very thankful for our you help since and to come Wink
You're real gentleman and tru gem of this forum
bob
Dillen:
Thanks guys.
Don't worry - be Happy
georganic
Posts 11
georganic replied on Thu, Sep 27 2012 3:15 AM
Thanks for that, Beobuddy, now I just need a schematic to tell which wires are what color...
Søren Mexico
Mexico City
Posts 6,379
3 Left, 5 right, 2 shield inner wire, 6,7 data, shield outer cable ground on shell, but B&O changed the colors a couple of times, check your schematic for data wires, normally  shorted in the jack and use the pin 2 as ground, left and right you can check connected
Le Rabou
USA
Posts 10
Le Rabou replied on Wed, Feb 12 2014 5:30 PM
Hello Martin,
I own a Bang and Olufsen Beocord 9000 audio cassette deck which does not play, fast forward, rewind tape.
This Beocord 9000 which I bought in 1985 is in excellent condition. Was fully functional but not used for past 6-7 years or so. Wanted to use it again recently but although it powered up OK, display lights, indicators such as tape type, calibration light, levels, etc. worked properly, when pressing "play" it starts but then stops with few centimeters of tape out of the cassette case. Does not FF nor Rewind. I suspect belts are the problem and would need replacement, what do you think? Am not much of a tech person but just love that machine and have extensive collection of tapes I still would like to continue to enjoy. I could not find anyone in the US who would not ask for my first born as payment... I guess I would have to try and do it myself. Are belts available, what would they cost and would you be kind to supply them? I would appreciate your assistance. Best.
Dillen
Posts 11,622
Dillen replied on Wed, Feb 12 2014 6:08 PM
There may be other things in need of attention but fresh belts would be the place to start.
You have a PM.
Le Rabou
USA
Posts 10
Le Rabou replied on Wed, Feb 12 2014 7:12 PM
Tks for your quick answer. Forgive my ignorance: what do you mean by PM? Can you supply the belts and if so, wd you accept payements via PayPal?
Dillen
Posts 11,622
Dillen replied on Wed, Feb 12 2014 7:25 PM
Yes and yes.
PM = Personal Message. Check your messages in the top right corner of this webpage!
Andrew Fleming
Tasmania
Posts 1
Hi Dillen, I have a Beocord 4004 that needs a belt I think. It is slipping badly and will not rewind tapes any more. Can you help?
Regards Andrew
chartz
Burgundy, France
Posts 3,922
chartz replied on Tue, Apr 15 2014 2:45 PM
Yes thanks Martin for sharing  your time and knowledge as well as supplying the odd part when we need it.
I think I need belts for my second Beocord 5000 4715... Will order soon! No PM needed!
Cheers!
Jacques
Dillen
Posts 11,622
Dillen replied on Tue, Apr 15 2014 3:49 PM
Andrew,
If we can agree that this is a Beocord 8004 (rather than 4004, which doesn't exist), I can supply a set of belts and
mounting instructions if needed.
You have email.
Thanks, Jacques. Smile
vikinger
Vestri Kirkjubyr, UK
Posts 5,390
Silver Member
vikinger replied on Sun, Dec 14 2014 9:29 PM
Peter:
So, is Beoworld now a poorer place?
Martin has not posted for a month, and his avatar has gone.
Graham
Chris Townsend
Badsey, UK
Posts 3,370
Add Moxxey to that list.
Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
Paul W
London
Posts 1,810
Paul W replied on Sun, Dec 14 2014 11:37 PM
I was only thinking that the other week Chris, It's very unusual for Moxxey not to post. I do hope that he's OK, maybe he's discovered the outdoor world or something nice!
vikinger
Posts 5,390
Silver Member
vikinger replied on Mon, Dec 15 2014 8:16 AM
And Peter has not posted since 3rd Nov, although a forum glitch incorrectly shows, if you click on his name, a last post of March 2012!
A lot of regulars have faded away this year. Does it tell us something about B&O ?
Graham
chartz
Burgundy, France
Posts 3,922
chartz replied on Mon, Dec 15 2014 8:24 AM
vikinger:
Nothing about vintage B&O!
I have never read a single post about newer B&O stuff anyway Big Smile
Jacques
olvisab
Posts 1,362
Silver Member
olvisab replied on Mon, Dec 15 2014 9:10 AM
Chris Townsend:
Add Moxxey to that list. Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 8000, Beoplay A9, Beoplay 2, Beocom 2, Beotime, H6, Form 2.
I have contacted him for advice by pm before he disappears.
I asked him his opinion about a famous secondhand b&o seller, within minutes he received my message he contacted the seller in order to tell him I was searching information about him.
And never answered to me.
When you behave like this with a beoworlder who kindly ask your help, I think it is time to go.
RIP
PS: sad for Peter, I miss him
beolab 5, beolab 9, beolab 3, beolab 10, beolab 5000, beolab 8000, beolab 3500, IWS 2000, beovision 7 55 mk2,  beotime, beogram 7000 white mmc2, beosound ouverture, beosound essence, beomaster 900 RG de luxe and the collection continues...
chartz
Burgundy, France
Posts 3,922
chartz replied on Mon, Dec 15 2014 9:22 AM
olvisab:
RIP
Seriously? Super Angry
Jacques
Ben_S
UK
Posts 629
Ben_S replied on Mon, Dec 15 2014 9:29 AM
Fairly sure Peter posted this weekend in fact!
I wouldn't look too far into it to be honest, people come and go on forums!
olvisab
Posts 1,362
Silver Member
olvisab replied on Mon, Dec 15 2014 9:32 AM
chartz:
Seriously?
Jacques
He'd better staying away, if you prefer.
vikinger
Posts 5,390
Silver Member
vikinger replied on Mon, Dec 15 2014 9:57 AM
Ben:
He did indeed!
Forum counters and post listings are haywire!
Graham
chartz
Burgundy, France
Posts 3,922
chartz replied on Mon, Dec 15 2014 10:31 AM
Yes he did!
Anyway, thank you Martin Smile and Peter Smile et al...
Jacques
the_o_master
Posts 830
vikinger:
Graham
Definitely, yes, it is poorer place without Martin, specially for us, vintage B&O fans!
2 weeks ago I noticed and wrote in other thread that the Martin is unusual "quiet" and I never saw him not posting so long. I don't know if it has something with his last discussion with Leslie (that was last post by martin) but I hope not.
Of course most of us here are very different personalities, coming from different countries, traditions and cultures but sharing one common thing: B&O-virus! In my opinion Beoworld is a great place to share this interests and discuss lot of issues and questions. As on every other forum, that means of course that there are other opinions and we cannot always agree.
Martin helped me and other members lot of times with his hints, advices and spare parts and he gave us plenty of times invaluable information about all that old and rare B&O devices.
I appreciate everything he done for me and for this forum and I hope he will be back soon. And if not, I am sure he has his reasons...
Same applies of course to Peter too but as somebody said, I think I saw him posting last week and I hope he is still with us...
Vintage Bang & Olufsen
9 LEE
Eastbourne, UK
Posts 7,108
9 LEE replied on Mon, Dec 15 2014 7:45 PM
Martin is too much of a gentleman to escalate arguments.  He's been prodded and poked by a certain member one time too often it seems, and he appears to have taken a break from the site.  I do hope it's not permanent...
Lee
Lee
Newcastle upon Tyne UK
Posts 702
Silver Member
Lee replied on Mon, Dec 15 2014 7:58 PM
I hope Martin sticks around, he's an absolute asset to the vintage B&O community. He's helped me out on numerous occasions.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Dec 15 2014 9:02 PM
9 LEE:
Lee
That's what happened to me before and I kept silence for a while. Good thing.
Brengen & Ophalen
Lee
Posts 702
Silver Member
Lee replied on Mon, Dec 15 2014 10:13 PM
I think Leslie has got it right... he's probably just having a break... fingers crossed.
Bogo
Posts 2
Bogo replied on Wed, May 6 2015 7:47 AM
Hej Martin,
Jeg er ny i forum, og denne måde at kontakte dig på var den eneste jeg umiddelbart kunne finde.
Jeg kan se, at du er den absolutte kapacitet på B&O, og derfor dette spørgsmål: Jeg er i gang med at reparere på et Beocenter 1600 hvis venstre kanals udgangstrin har været udsat for overophedning. Det eneste man hører fra den er brum. Højre kanal fungerer. Alle svedne komponenter er nu udskiftet men udgangstransistorerne eller IC´erne, jeg er ikke helt klar over hvad det er for nogle, kan jeg ikke finde nogensteder. De er påtrykt et "M" det ligner Motorola, og betegnelsen TE1088 og TE1089. De har været skiftet før sikkert grundet det potmeter (kaput) der regulerer arbejdspunktet. Jeg har kontakt med en amerikaner der beder om et JEDEC nummer. Men hvis du har adgang til komponenterne, er det jo lettest at købe dem i DK.
Vh.
AvidMarxist
Posts 1
Hi all
I just purchased (today!) a Beogram 4002 5513. For the $150 I paid I think it's in great shape but I would love to:
1) replace the drive belt
2) know what things to look out for. Should I run through a standard lubrication/upkeep?
3) the tonearm is set to 1gram, which is correct for the MMC4000, but I've read a few places on this site saying it may need to be a bit higher
4) I am getting some distortion; it's not 100% but it's annoying - seems at the high end. It played fine when I demoed it today, and during the day at home. I have noticed the platter isn't 100% level with the back of the metal base, so I have a feeling I may need to level it
5) eventually I would like to fully refurb and clean this thing up. I'm posting in this forum as I read I should reach out to Dillen for ordering everything I need. May I ask if anyone can help me get in touch?
Thanks!
freddyisaac
Posts 1
Hi Dillen,
I am looking for tape belts for a beocenter 9300 - do you still do this. Can't find PM on the site - probably just need to hunt around some more
Any chance ?
cheers
Dillen
Posts 11,622
Dillen replied on Wed, Feb 14 2018 6:48 AM
Welcome to Beoworld!
Yes, I can still supply belts and many other parts.
PMs are called conversations here.
Click on my name out to the left, and send me an email or start a conversation.
pietsaba
Posts 2
Silver Member
pietsaba replied on Wed, Apr 11 2018 4:59 PM
Hello ,
i am quite new in this forum , I am repairing a beomaster 1900 replacing already capacitor , I found a problem on the left amplifier . Changing all the transistor and diode .
I was searching now suppliers for the lamps , the potentiometer in the output amplifier and  the
transistor MPS h54 ( apart from the eBay site at # 1 € each )
could you help me ?
thank you
best regards
Søren Mexico
Mexico City
Posts 6,379
go here https://forum.beoworld.org/members/Dillen/default.aspx and send him a message or a mail
RonFlack2
Posts 1
RonFlack2 replied on Tue, Aug 13 2019 1:43 PM
Hi Dillen, can you supply drive belts for Beocenter 2200 tapedeck and instructions for fitting
Ron
Page 1 of 2 (43 items) 1 2 Next > | RSS
