Beosound 35 - Hard Reset
Not Answered This post has 0 verified answers | 9 Replies | 1 Follower
MircoHH
Germany
MircoHH posted on Tue, Apr 18 2017 12:45 PM
I have bought a Beosound 35 on eBay and I am not able to do a complete factory reset. The Beosound 35 always remember the TuneIn User Account of the old owner. When I do a rest with the menu, the account is still there.
Is there the possibility to perform a complete reset of the Beosound 35 to delete all (Accounts, protocols, etc.)
Thank you for your help.
Mirco
BeoHut
BeoHut replied on Tue, Apr 18 2017 1:51 PM
Did you logout on the accounts (Deezer and TuneIn)?
Try this in the BeoSetup app or BeoMusic app (Product Settings) and log in with your own account.
MircoHH
Germany
Yes, I have tried this. But the old account is back, after an complete Power OFF / ON.
paolomariano
I am not at home at the moment but I remember it is possible to reset it.
I will let you know tonight when I am home.
MircoHH
Germany
Thanks.
I have tried it with the menu but this doesn't work.
Keith Saunders
Little Ann, Hampshire, United Kingdom
ONLINE
It is possible to do a "Factory Reset" by:-
  • Go to Setup menu. To access the Setup menu, tap GO and use < or > to navigate in menus. When Setup appears, tap GO to open the menu.
  • Select Reset and confirm that you want to reset BeoSound 35. All Bluetooth pairings and network profiles are deleted and all settings made in BeoSetup App are reset to default.
User credentials for music services (e.g. TuneIn, Deezer and Spotify) will only be reset if the product is connected to the internet
Regards Keith....
MircoHH
Germany
Thanks, but this is what I have tried.
CB
> You are Here <
ONLINE
CB replied on Wed, Apr 19 2017 6:32 AM
Keith Saunders:
This means that you have to enter YOUR settings for network first (if connected via WIFI, for your BS35 to be able to access the internet), and then to run the reset process.
It should not be necessary if connected via Ethernet.
Anyway, this process sounds odd to my ears (a factory reset is generaly used because of problems, and it may work whatever you do....)
There's also a reset function on the X app. Did you try it too?
Andrew
Frinton, UK
Silver Member
Andrew replied on Wed, Apr 19 2017 2:41 PM
Does the previous user not have to remove the device from their device lists in their Tunein account? Not sure if it is the same as a Digital Radio
MircoHH
Germany
Hmm, I tried the above things, but there was no change.
I always gets this error:
  • 18. 4. 2017 23:02:55
    Cannot change TuneIn account, unknown error
Page 1 of 1 (10 items) | RSS
