Beogram 1600 arm cueing problem
Not Answered This post has 0 verified answers | 13 Replies | 1 Follower
Armbored
Silver Member
Armbored posted on Thu, Mar 9 2017 11:29 AM
Hello all,
Just looking at a 1600 for a friend and finding a problem with the arm cueing.  Functions as follows:
Press 33, the platter turns.
The arm swings over the record to the first track but does not lower.
The arm swings back to the start position.
Platter continues spinning.
Press Stop and the platter stops spinning.
I cannot find a manual for this item anywhere, can someone please help guide me as to the problem here?
Thanks in advance,
Mike
Dillen
Copenhagen / Denmark
ONLINE
The lowering or not lowering of the tonearm depends on the weight of the cartridge
Is there a pickup cartridge on the tonearm?
Has the tracking force been set correctly?
Armbored
Silver Member
Armbored replied on Thu, Mar 16 2017 10:44 PM
Hello Martin,
Yes there was a cartridge on the tonearm.  During the cleaning process, I removed the counterweight as the whole turntable was very dirty.  I had not replaced it properly in the arm and I think this was the problem as when I did my checks over everything to try to source the fault, I noticed this and then the problem cleared.
Many thanks for your reply though.
Regards
Michael
Armbored
Silver Member
Hello Martin,
Regards
Michael
Dillen
ONLINE
Dillen replied on Fri, Mar 17 2017 6:20 AM
Make sure you got it 100% correct.
Use a tracking force gauge.
A few grams (or even tenths of grams) off may not seem like a lot, but it could easily shorten cartridge life considerably.
Armbored
Silver Member
Armbored replied on Sat, Mar 18 2017 10:31 PM
Hello Martin,
I've just had a close look at what's happening.  When the arm comes across over the record, it lowers but does not make actual contact with the vinyl.  The anti skate then brings the arm back to the rest position.  Is it possible to adjust the set down  height of the arm?
I understand what you're saying about the tracking weight, I set it to 1.2g with a digital scales as per cartridge spec. (MMC20EN)  However, I am not sure what the screw at the rear of the counterweight is for, is it a calibration for the tracking weight scale?  I see there is a cut-out in the tonearm plastic for accessing this screw.
Thanks in advance,
Michael
Armbored
Silver Member
Armbored replied on Sat, Mar 18 2017 10:35 PM
Hello Martin,
I've just had a close look at what's happening.  When the arm comes across over the record, it lowers but does not make contact with the vinyl.  The anti skate then brings the arm back to the rest position.  Is it possible to adjust the set down height of the arm? (playing height)
Kind regards,
Michael
Armbored
Silver Member
Armbored replied on Sun, Mar 19 2017 10:20 PM
I worked out the tonearm is the same as on the Beogram 2200, so downloaded that manual.  There, I found out that the above mentioned screw is for balancing the tonearm.  So I balanced the tonearm and set the tracking weight properly and the arm plays correctly now.
However, sometimes when I press 33/Play, the platter rotates very quickly (about 70rpm) and I don't know why?  Can anyone please help with this?
Thanks in advance,
Mike
Dillen
ONLINE
Dillen replied on Mon, Mar 20 2017 6:41 AM
Armbored:
...t the screw at the rear of the counterweight is for, is it a calibration for the tracking weight scale?
Yes.
And there's also an adjustment for the tonearm height, the tiny pin that lifts the tonearm is adjustable from inside the counterweight house.
It's all in the servicemanual.
Armbored
Silver Member
Thanks Martin,
Any thoughts on the high speed rotation?  70rpm at times, an intermittent problem.
Michael
Dillen
ONLINE
Dillen replied on Mon, Mar 20 2017 9:03 AM
Armbored:
Thanks Martin,
Michael
Yes, the belt is slipping, allowing the motor to accellerate too fast and the electronics to sync on the double speed.
Replace the belt.
Armbored
Silver Member
Armbored replied on Mon, Mar 20 2017 11:53 AM
Thanks Martin,
Do you supply parts?  I seem to remember this from some time ago.
Regards
Michael
Dillen
ONLINE
Dillen replied on Mon, Mar 20 2017 3:37 PM
Yes, I can supply drivebelts for most Beocord, Beocenter and Beogram models and also many other parts.
PM / Email me.
Armbored
Silver Member
Armbored replied on Thu, Mar 30 2017 11:44 AM
Hi Martin,
Did you get my email from last week about the belt?  I've not heard from you.
My email is michael.hendry1@gmail.com
Thanks in advance,
Mike
Page 1 of 1 (14 items) | RSS
