BLGW Go Update
This post has 61 Replies | 2 Followers
Seanie_230
UK
Posts 1,974
Seanie_230 Posted: Tue, Mar 7 2017 9:01 AM
Hello Beoteam
BLGW update is out.
Excited for you all
BLGW - Rekindling the love of ML
kuyttendaele
Posts 460
Could you elaborate?
Karel.
Seanie_230
UK
Posts 1,974
Hello
Sorry the new firmware for the BLGW has been released.
kuyttendaele
Posts 460
I guessed that part... but what's to be excited about? What's news? What changed?
Karel.
Seanie_230
UK
Posts 1,974
Whoops
  • Detachment of drivers from Firmware
  • Custom driver editor
  • Support for H.264 / RTSP camera's with new Beolink2 App
  • Detailed monitoring by clicking device at the bottom
  • some new and some updated drivers for existing devices
  • Drives stored in an online repository making it easier for finding more drivers
The driver editor is what excites me the most as we move away from custom strings, those people who can write a driver could share them and we could have drivers for loads of things.
DocLeisure
Posts 79
I just did the Update but now I have a green light flashing quickly, which means critical error...
Taking the gateway of the mains did not help - resetting did not help...
Any ideas?
Best regards
Doc Leisure
Millemissen
Flensborg, Denmark
Posts 12,206
What is:
'new Beolink2 App'
mentioned above?
Seanie_230
UK
Posts 1,974
Can you still reach the BLGW via web browser?
The update should not be interrupted with a power outage
DocLeisure
Posts 79
the gateway is not reachable (anymore) via webinterface. But the update went well until the gateway said "rebooting"... (I did not interrupt the update process)
... now it is dead - still flashing fast green...
Regards
Doc Leisure
mjmedlo
Posts 921
mjmedlo replied on Tue, Mar 7 2017 1:19 PM
Do a factory reset then re-attempt.
He update takes several minutes. Be sure not to disturb during that time.
Seanie_230
UK
Posts 1,974
Very strange
Perhaps you need your dealer to flash it directly or reboot again.
Has it moved to another IP?
Have not seen it crash with updates
DocLeisure
Posts 79
I already tried a factory reset - did not solve the Problem... (maybe that is what is ment by "critical error" ;-(
The Gateway had at least half an hour time to do the update and the last word it said was "rebooting"...
... now it does not boot anymore. So I do not have an IP-adress and therefore it does not shop up in my rooter.
My dealer is informed and the Gateway is still under garanty.
Regards
Doc Leisure
mjmedlo
Posts 921
mjmedlo replied on Tue, Mar 7 2017 2:17 PM
Best of luck.
So you don't get it st the bonjour site either?
Blgw.local?
Do you have 'fing'. You could just make sure it's not on the network somewhere else?
DocLeisure
Posts 79
unfortunately not, no luck with "blgw.local". I think, it first has to boot up, to find it in the local network.
For me it is not the best time with B&O - last week one of my BeoLab5 died - no repair before end of this month... now the BLGW...
...waiting for the things to come...
Regards
Doc Leisure
Sweden
Posts 257
Martin replied on Tue, Mar 7 2017 2:34 PM
Have anyone else made the update without any problem? I am thinking of NOT doing the update if it crashes the BLGW.
Best Regards
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Sweden
Posts 257
Best Regards
Sweden
Posts 257
Best Regards
Sweden
Posts 257
Best Regards
Sweden
Posts 257
Martin replied on Tue, Mar 7 2017 2:35 PM
Has anyone else done the update?. I am thinking of NOT doing the update if it crashes the BLGW.
Regards
Seanie_230
UK
Posts 1,974
I spoke to a chap today who has done it and it went well.
So 50/50 so far
boskonay
Posts 72
BLGW is flashing, please wait...
Seanie_230
UK
Posts 1,974
Hello DocLesure
Please contact Bang and Olufsen via http://beointegration.com/ contact page
Please provide previous software version and serial number.
Please do this as they will wait for your email.
Sean
mr_anders_son
sweden
Posts 1,529
Millemissen:
What is:
'new Beolink2 App'
mentioned above?
There is a new BL2 "beta" app in the appstore now!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
boskonay
Posts 72
v1.5.0.1434
Flashed, rebooted, connected. Seamless.
Now off to play!
Seanie_230
UK
Posts 1,974
Update to Beolink App released just now
Seanie_230
UK
Posts 1,974
Not here just yet but I am sure you will love the new BeoLink2 app it is amazing and the UI is great.
Seanie_230
UK
Posts 1,974
So who is going to develop drivers :)
I think the online repository is going to be great now it's detached from FW.
Can you imagine in a years time the amount of devices we can connect to.
The BLGW in my opinion can now be a home automation system rather than an interface to one
DocLeisure
Posts 79
Hi Sean,
thanks for your support - I just emailed beointegration.
Keep you posted...
Best regards
Doc Leisure
Seanie_230
UK
Posts 1,974
No problem it's a great update good luck
Carolpa
Posts 830
Carolpa replied on Tue, Mar 7 2017 6:53 PM
started downloading - reaches 100% - update stopped
several repeats with the same outcome.
made a backup - unplugged the BLGW - re-plugged
started downloading - reaches 100% - the BLGW updates Smile
beoandy
sissi not kangaroo
Posts 295
beoandy replied on Tue, Mar 7 2017 6:55 PM
BeoLink Gateway | Release Notes
Changes in BLGW 1.5.0 since previous BLGW SW version 1.4.1:
New features
  • Detachment of BLGW drivers from the firmware. Some drivers are now stored in the cloud and can be added/updated without a firmware update to BeoLink Gateway. Find more drivers under Tools > Advanced > Install external drivers.
  • Cut, Copy & Paste in macro programming tab
  • Convert commands to Lua code using the [Convert to code] button. This way it is possible to edit them in text view instead which is useful in some cases when there is a lot of the same type of commands.
  • Support for H.264 / RTSP cameras. This only works in the new BeoLink App 2 and it is still required to add a path for a JPG still image for the web panel on the TV.
  • By clicking the system in the bottom of the BLGW configuration page detailed connection status messages are shown.
  • Monitor have been updated with more information and if you have macros running over a long time / looping they are shown in the right side of the monitor and they can also be stopped from there.
  • Custom driver editor - makes it possible to write your own driver on the gateway itself and test it as you go along. A driver development guide as available on beointegration.com.
  • Indication to users if a device or system is offline.
  • Support for the new Android TV platform.
New drivers
  • Doorbird doorstation
  • Global Cache iTach Flex
  • amBX Lighting system
  • Custom HTTP - Used for integrating with REST/JSON interface systems and services
  • Open Weather - Trigger macros based on the weather conditions
  • Ecobee Thermostat
  • DigitalSTROM
Updated drivers
  • KNX - Support for KNX thermostats (1 Setpoint, 2 Setpoint)
  • Philips Hue - Possibility to Raise/Lower a lamp
  • Nest - Numerous improvements to the Nest driver in order to achieve the [Works with Nest] certification
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
beoandy
sissi not kangaroo
Posts 295
beoandy replied on Tue, Mar 7 2017 8:13 PM
after updating the firmeware (and the blgw app) the hue driver has a problem. there is no update of the slider in the beolink app. if you control the light with a hue switch or a hue motion sensor the slider in the beolink app do not update the level of the light. (and no colour update) but you can control the hue light wicht the slider of the beolink app.
beoandy
sissi not kangaroo
Posts 295
beoandy replied on Tue, Mar 7 2017 11:00 PM
beoandy:
but the update in the webpanel still works!
Seanie_230
UK
Posts 1,974
The BeoLink2 app is now released.
It runs alongside the current app
I hope you all love it the same as I do
Big SmileBig Smile
Seanie_230
UK
Posts 1,974
Beoandy try the new app it should hopefully give you back your missing functions
Just in case you miss it you can go into the zones or just tap on the icons on the page below
beoandy
sissi not kangaroo
Posts 295
beoandy replied on Wed, Mar 8 2017 12:30 PM
Hi seanie!
Okay, i have update the old beolink app. on the beolink1 app there is still no update of the status from the hue bridge.
On the new beolink2 app the update works fine.
But: first look on the new beolink2 app
- light and scene are different icons in the app. I control my light with custom strings an so all my light buttons are in the scene section. But the hue light are in the light-section. I can not define the custom strings to be a light switch or a shade.
- all my buttons with feedback status led are now buttons without status led in the new beolink2 app.
96 Normal 0 21 false false false DE X-NONE X-NONE
- Spotify integration from beosound 5 in the beolink2 app would be great but I think only a never fulfilled desire ;-) (I know multiroom deezer is the b&o future)
Seanie_230
UK
Posts 1,974
Hello
I have the same issue with my Global Cache device for my curtains it ends up in scenes and not shades which is a shame becuase on the BLGW its seen as a device not a shade.
I will ask the question if it would be possible to designate a device as a type.
I will also mention the feedback button as I am missing this also.
Sean
Seanie_230
UK
Posts 1,974
The other option would be to drive a driver to replace your custom strings perhaps
bigdeniz
Posts 40
bigdeniz replied on Wed, Mar 8 2017 12:54 PM
Can i use the MLGW with the BeoLink2 App?
Seanie_230
UK
Posts 1,974
bigdeniz:
No idea but if you download it and try it won't hurt as it's a separate app.
Page 1 of 2 (62 items) 1 2 Next > | RSS
