Playmaker refuses to connect to TimeCapsule
Not Answered This post has 0 verified answers | 5 Replies | 2 Followers
Mico
Finland
Mico posted on Fri, Aug 24 2012 8:03 PM
Hello all Apple gurus,
I'm experiencing a connection problem with Playmaker. Somehow it does not connect to my TimeCapsule based wifi-network. Connection to another wifi router works quite fine and at least the configuration went as supposed. I´ve tried it several times and the result is always blinking orange.
I´ve tried both easy setup and advanced configuration with the Playmaker setup app, without any success.
What should I do next? I´ve never experienced any connectivity problems with the TimeCapsule.
b/r Mikko
DoubleU
DoubleU replied on Fri, Aug 24 2012 10:08 PM
Magnus
Norway
Magnus replied on Fri, Aug 24 2012 10:45 PM
Have you tried turning off the security/encryption, just to test?
jk1002
jk1002 replied on Sat, Aug 25 2012 1:57 AM
this might be encryption related.
This may have changed in recent years but back when I was running both windows and macs Apple devices could connect with a simple password, however non apple sometimes need the full key to connect. Back then, you could get that form the admin software of the time capsule if I am not mistaken.
Cheers
JK
Mico
Finland
Mico replied on Sat, Aug 25 2012 11:11 AM
Thank you fellows,
Tried the encryption with no success. The answer was deeper in the Time Capsule settings (probably affects all other same generation Apple base stations as well). I needed to deselect 802.11n 2.4 GHz only and select 802 b/g compatibility instead. Why? No idea but now it works!
I'm not using the TC as a media server, only as a WiFi base station.
Christophe
Cape Town
Blame it on PlayMaker: it doesn't work with 802n! Stick out tongue
Page 1 of 1 (6 items) | RSS
