Lobster:Do you have this also?
Thanks, I will try this weekend these options and see what will happen. And I will inform you and B&O what my experience are with the expert mode.
How do you guys join the Moment beta program?
Im sick of listening to mp3 quality songs on my beolab 5 when my Beosound 2 is streaming flac.
the public version 2.2 seems like ite never coming out.
Beolab 5 Final Edition, Beosound Moment
Hiort:I’m on the beta track
Hi Hiort - Can you move forward/backward in a Deezer track witout issues?
Maniax: How do you guys join the Moment beta program? Im sick of listening to mp3 quality songs on my beolab 5 when my Beosound 2 is streaming flac. the public version 2.2 seems like ite never coming out.
Kyle emailed me: write to beta@bang-olufsen.dk if you are interested in joining the beta programme.
mbolo01: Hiort:I’m on the beta track Hi Hiort - Can you move forward/backward in a Deezer track witout issues?
There are problems with in particular going back to 0 seconds in songs. Both my Moment and A6 are having this issue.
/Jacob
Since the last update (Fri 15) I've experienced dropped connection from soundboard where I've had to reboot it in order to get control again, anyone else experienced the same?
BTW, I love deezer Hifi!
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Hi mbolo01,
I've still problems to get the artist tiles in the expertmode to work. It worked once after a system reset, but when I put more new tiles in the BEOARTISTS map and after the rescanning of the system all of the "homemade" artist tiles are disappeared and never came back. Also with a total reset of the system. When it worked it was with the softwareversion before the softwareupdate from last friday.
I send B&O also a message about it, but I was curious if it still works with you're system. And maybe you have any clue...?? 😉
Lobster:Hi mbolo01, I've still problems to get the artist tiles in the expertmode to work. It worked once after a system reset, but when I put more new tiles in the BEOARTISTS map and after the rescanning of the system all of the "homemade" artist tiles are disappeared and never came back. Also with a total reset of the system. When it worked it was with the softwareversion before the softwareupdate from last friday. I send B&O also a message about it, but I was curious if it still works with you're system. And maybe you have any clue...?? 😉
Hi Beroli,
Thanks for your reply.
I have tried many things to get my selfmade artist tiles back, but with several collection updates and the reconfigures from the DLNA menu the artist tiles still doesn't reappear. Even with the reconfigure and system reset from the Reset menu.
I have sent B&O already a e-mail about this. I hope they will fix this asap.
Lobster:I have tried many things to get my selfmade artist tiles back
This is weird ....
I just tried the following:
To replace a managed artist image by another oneTo replace a Gracenote artist image by a managed oneTo add a missing artist image
It took only one Manual Refresh cycle to get all the above applied.
I don't know what to say as you did what had to be done as discussed previously.
andy_js:This expert mode hardly seems like it’s worth the effort.
It worked perfect in the previous beta and believe me it looks great, if every tile is filled with the right artis image and there are no permanent scans, because it uses all the tags in your dlna-collection. I like it.
Beroli:because it uses all the tags in your dlna-collection. I like it.
Hi Beroli - Talking about tags, how are your DLNA albums sorted when opening an artist tile? (pls remind me your current DLNA server)
mbolo01:Hi Beroli - Talking about tags, how are your DLNA albums sorted when opening an artist tile? (pls remind me your current DLNA server) BS Moment, BL 18, BL 19, A6, M5, A1, H5
Beroli:Currently testing Latest Beta on TwonkyServer
I discovered that Twonky does not always expose the correct date set in the Tags.
With the new Twonky "By Date" UI view introduced in 8.5 version, I found several exceptions. Looking closer at some albums that obviously were not placed in the correct era, I could find that their release year was correct in iTunes, same in Metadatics (OSX Tag editor) but when using another DLNA controller that takes care of date exposed by the DLNA server, album release year is completely different, e.g. 2033 v.s. 1992 in iTunes.
Next, expecting the sorting performed by the Moment to be the same than the DLNA renderer app, assuming the Moment reads and leverage the year tag, I have differences and inconsistencies.
I opened a ticket with Twonky to start with and B&O is already aware about the sorting issue.
PS: Twonky 8.5 running on QNAP or OSX translates the date TAG value to another for the same albums.
For all the betatesters out there:
Warning! With the latest software released on friday 22th, my Moment lost almost all it's functionality. You will not be able to manually enter the setup menu.
I don't know if I'm the only one, But after downgrading, my Moment works again. I've done this sequence twice (upgrading/downgrading etc) with the same result.
Unless confirmed by B&O otherwise, I would wait with upgrading your software.
hmmm, didn't have any troubles with the update. Everything is working as before and i am able to enter the setup menu.
Didnt have and Problems to. Everything works fine.
Glad to notice.
Mine worked flawless under the previous 2.2 beta in combination with Deezer HiFi, the ultimate musicsystem for me.
Will see what happens next. I'm convinced that it will be sorted out.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
I couldn't unterstand, why B&O discontinued the wonderful BS Moment. The device was a disaster the last 2 years, but after Lyle wrote the software complete new, it is one of the best devices for playing music, B&O ever made!
I am very sad, that I will see no new feature anymore.
I hope there's soon a final software version...
It has been confirmed today. My Moment has a hardware faillure.
So, the softwareupdate wasn't the culprit, but an unlucky coincidence.
Beobuddy: For all the betatesters out there: Warning! With the latest software released on friday 22th, my Moment lost almost all it's functionality. You will not be able to manually enter the setup menu. I don't know if I'm the only one, But after downgrading, my Moment works again. I've done this sequence twice (upgrading/downgrading etc) with the same result. Unless confirmed by B&O otherwise, I would wait with upgrading your software.
Can any other confirm whether the current beta works with Twonky Server v8.5 or not? Asking since I've currentl running with the latest beta being pushed out where they just added some additional log facilities and while upgrading the system to this level I'd also upgrade my Twonky Server installation the QNAP which it seems now that the Moment doesn't support.
Another issue that I currently also have with the current beta is that I can't get into the Settings/Configuration meny by removing the socket cover on the Moment Hub. Tried factory reset and setup the system again with both TuneIn and Deezer (HIFI) and the system seems (I can access Deezer and TuneIn) to work, beside the DLNA-issue and Setting/Configuration issue.
kimhav:Can any other confirm whether the current beta works with Twonky Server v8.5 or not?
mbolo01:Yes it works
Ok, thanks! I've tried to downgrade Twonky Server to version 8.4.1 to see if this would make any difference which it didn't, so back again to version 8.5. So for now I can only wait for B&O to get back to my based on the beta feedback I've provided.
Hi how can I become a beta tester?
I have sent an Email to the address provided in this thread but so far, I have not received a response.
I subscribe to Deezer HIFI and would very much like to have that service enabled on my Beosound Moment.
Did they solve the problem with compilation albums being ignored by the Moodwheel yet? Only Various Artists (album artists) are shown. Not the performing artist. I've been complaining about this bug for almost 2 years, and still no solution. Also, when can we expect gapless playback? Or can we playback WAV files without a loud ticking noise at the end of each track?
Shame on you B&O! I'm really done with the brand after being a loyal customer for more than 30 years. Their products keep getting worse every year!
i4ict:Did they solve the problem with compilation albums being ignored by the Moodwheel yet?
Igadiz:Hi how can I become a beta tester?
StUrrock:Some might say that once you buy a new B&O product these days you are automatically on the pre-beta program
Sources: 2x Beosound Moment • 4x Beosound Essence Mk IISpeakers: 3x Beolab 8000 • 1x Beolab 6000 • 1x Beolab 3 • 3x Beolab 2 • 4x BeoPlay M5 • 1x BeoPlay A6Control: 9x Essence Remote • 1x Beoremote Halo
MircoHH:No, it isn’t solved. I am in touch with B&O too, because most of my albums are compilations.
the moment could use this as its screen???
This device is a cross between a moment and a device Sony did a fair few years ago
https://www.engadget.com/2018/01/08/lenovo-smart-display-hands-on/#gallery=819527&slide=7204473&index=7
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
