Beomaster 1900 help!!
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Lewis T
Hampshire, UK
Lewis T posted on Fri, Dec 30 2016 7:17 PM
Hi all,
Just wondering if anyone can help me please I have a lovely beomaster 1900, all of a sudden its having an issue with Preset 4 on fm if you go to lightly tap it it wont work but if you push it really hard it will work. Just wondering if anyone can help me at all? Otherwise the set is working just fine.
Kind Regards,
Lewis
Dillen
Copenhagen / Denmark
Dillen replied on Fri, Dec 30 2016 8:20 PM
Check the tension of the bronze fork that grips the pin on the circuitboard.
Also check that it actually grips the pin.
Clean the pin off oxidation etc.
Still no luck, replace the transistor associated with the P4 touchpad.
Lewis T
Hampshire, UK
Hi Martin,
Thank you so much for your fast reply, have followed the steps above and its all sorted now.
Kind Regards,
Lewis
Page 1 of 1 (3 items) | RSS
