BeoVision 7 MK2 Mutliple HD Sources
Not Answered This post has 0 verified answers | 23 Replies | 3 Followers
Beo_Vision
Beo_Vision posted on Wed, Dec 28 2016 1:15 PM
Hi Guys
We have a BeoVision 7 MK2 which has only one DVI input connected to a SKY HD box via a DVI to HDMI cable and a scart for teh audio. The issue i have is that i would like to connect up either an Apple TV or alternate HD box.
Is there a device available  (B&O or third party) that will allow me to connect multiple HD boxes to the TV?
BeoIce
Recklinghausen, Germany
BeoIce replied on Thu, Dec 29 2016 7:28 AM
Beo_Vision:
It depends on the software level of your BV7. If it's 7.94 and upwards you get the ability to use the HDMI expander function, which let's you assign HDMI-1/2/3/4 to the DVI port. Now you can use either a Gefen HDMI expander (the most expensive solution) or a simple HDMI switcher like this with automatic switching function between the HDMI inputs.
On lower software levels than 7.94 you only have the possibilty to connect a hd box via YPBPR connection and an apple tv via DVI.
Updating the software will be around 100-300€ depending on your B&O dealer.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
BeoIce
BeoIce replied on Thu, Dec 29 2016 7:30 AM
Oh, welcome to Beoworld Beo_Vision Smile
leosgonewild
You can hdmi->dvi+rca converter.
And connect a hdmi expander before the converter.
Beo_Vision
Thanks Guys, how do i check which version of the software we are running?
BeoIce
BeoIce replied on Thu, Dec 29 2016 7:30 PM
On your remote press MENU 0 0 GO then Monitor Information.
StUrrock
http://www.hdfury2.eu/hdfury-2.html
would this work to the component inputs?
Beo_Vision
I checked today and the panel is running 7.84, obviously I want the best possible solution that will give me the most options and flexibility. Do you recommend I get the software updated and then purchase an expander? Are there anyone benefits going with gefen expander instead of a basic hdmi switcher?
leosgonewild
The gefen switch can be controlled via puc with beo4.
I did it with mine when I had it, and it was a lot of money out the window just to be able to use the remote.
How many hdmi sources are you connecting?
Get a switch with auto-switch.
Beo_Vision
At the minute 3, out if interest how much is the gefen ?
Beo_Vision
If I go for an hdmi switch how will the sound be transferred to the tv as currently I have a scart connected to my sky box for audio but with Apple TV the only option is hdmi.
Beo_Vision
Will I also require a software update to use the hdmi switch?
Beo_Vision
Sorry for all the questions guys, if I wanted to only connect two HD devices then could I use the bellow convertor for my sky box and would I still be able to view video @ 1080??
http://www.maplin.co.uk/p/rgb-and-stereo-phono-audio-to-hdmi-converter-n51qk
I could then connect the Apple TV via hdmi>dvi as mentioned above, only thing is im not sure how I would hear the audio?
Beo_Vision
https://www.hdfury.eu/en/home/6-gamer2-component.html
Beo_Vision
Any thoughts Guys??
Page 1 of 2 (24 items) 1 2 Next > | RSS
