Flash your B&O - new thread!
This post has 5,290 Replies | 60 Followers
AnalogPlanet
Vienna, Austria
Posts 569
ONLINE
seethroughyou:
Moment (2018) blends in well with black and aluminium of Beogram 7000 and CD7000 (1996)
seethroughyou this is really beautiful! <3 I had a similar thought looking today at Beo5 remote sitting next to my Moment.
Peter Visser
Leeuwarden
Posts 11
Trackbeo, the Coffee Table is a vintage one designed by Knut Hesterberg for Ronald Schmitt
trackbeo
Posts 311
trackbeo replied on Thu, May 23 2019 8:13 AM
Thank you!  "Snake", that model was called.  I had never heard of this designer before, nor seen any of his work.  But google shows at least 4 other models.  I'll have to see one in person; apparently they were originally polished aluminum, which has developed a patina over the ¡five! decades since its manufacture...  Again thanks.
mariuszf1
Spain
Posts 12
mariuszf1 replied on Wed, May 29 2019 9:27 PM
Hi mr anders, i have just found this thread and already ordered the new backlight :)))) can you just explain how you changed it? was it complicated? does it change the glow in the buttons too? i am a bit scared of breaking it, even if soldering is not a problem. thanks in advance for your comment!
Mariusz
matador43
Posts 805
The system is finally complete: Beocord 1200, Beogram 3000, Beomaster 1001 and Beovox 1001.
All working, but unfortunately, not as good as they look, but that's another thread…
And of course with reprinted User and Service Manuals Big Smile
beocool
Alankomaat
Posts 6,129
beocool replied on Sat, Jun 1 2019 11:38 AM
matador43:
Good to see you got the whole system complete. Yes - thumbs up How long did it take to get all items, if you don't mind me asking?
Vähintään yhdeksänkymmentä prosenttia suomalainen!
matador43
Posts 805
matador43 replied on Sat, Jun 1 2019 12:09 PM
That was not that long after all. I got the Beocord like two or three month ago. I started to hunt the complement shortly after and I found the Beomaster with the Beovox two weeks ago. When I collected it, the guy had the beograms too so i bought them along. All put together with the furnitures two days ago and manuals printed yesterday!
beocool
Alankomaat
Posts 6,129
beocool replied on Sat, Jun 1 2019 12:19 PM
matador43:
Thank you. It sure looks lovely. Hope you get lots of enjoyment out of it. Smile
matador43
Posts 805
matador43 replied on Sat, Jun 1 2019 12:30 PM
I do! Thank you Beocool.
bidstonhall
Thailand 5560 miles from Struer
Posts 363
Looks magnificent
BEOVOX141
Denmark, West
Posts 702
Silver Member
BEOVOX141 replied on Sun, Jun 2 2019 11:15 AM
Hi Matador
I really like all the little details you have added to the setup
Why not place the Beomaster in a vertical position so its visible?, I am sure the tapes could go elsewhere.
matador43
Posts 805
Thank you Beovox141,
I really like and want the Beocord in vertical position.
So, I found that:
- two components in vertical position would be too much,
- and I'm also try to avoid too much holes in the wall!
The 11kg of the Beocord (along with the reels underneath) also acts as counterweight for the 6kg of the Beomaster on the shelf.
That said for the photo, I've forget to raise the little feet under the Beomaster which tilt it forward giving a little more access to controls.
Kromer
Randers, Denmark
Posts 129
Kromer replied on Sun, Jun 2 2019 11:48 AM
Very nice setup matador, thanks for sharing Yes - thumbs up tastefully done
DMacri
United States
Posts 849
DMacri replied on Fri, Jun 7 2019 11:54 AM
My new friend and traveling companion.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
the_o_master
Posts 830
matador43:
Really beautiful matador, thanks for sharing the pictures of your setup.
Just a question: the record player on the pic looks like 1202, not the 3000?
Theomaster
Vintage Bang & Olufsen
Jeff
USA
Posts 3,716
Silver Member
Jeff replied on Fri, Jun 7 2019 4:04 PM
Gorgeous setup in all white matador. Beautiful and perfectly restored vintage B&O always makes me smile! Smile
Jeff
matador43
Posts 805
Thank you the_o_master and Jeff,
the_o_master:
Yes, very fine observation! I was sold a beogram 3000 (medium condition) and a beogram 1203 (bad condition).
I was looking for the peg platter look, god knows why.
But the BG3000 appears to be more functional at first so I kept it swapped the platters.
In the end, the 3000 had a very loud 50hz hum i dont know how to get rid of.
Since this morning I tried the 1203 which has no hum (but is a very little bit slow) and ends up replacing the 3000.
In the process, each turntable get his respective platter back!
So now it's look like as I like and ALSO as it should!
Fansastic
The Netherlands
Posts 455
Happy they sound as good as they look
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
beolion
Posts 399
beolion replied on Fri, Jul 26 2019 6:51 PM
Our Avant 55 MK1 replaced our old BV8-32 in the bedroom. Connected with an ATV we have all the media entertainment we need ;-)
And with a 55” I do not need my glasses anymore when I go to bed Stick out tongue
Because the tv is so close to the walls I had to disconnect the stand for now.
BEOVOX141
Denmark, West
Posts 702
Silver Member
BEOVOX141 replied on Fri, Aug 2 2019 11:34 PM
Leave me alone, I am watching TV! Big Smile
Beozip
Posts 207
This is the new showcase for my BR 1 Collection Big Smile
closed
Beozip
Posts 207
Steffen
Denmark
Posts 1,363
Steffen replied on Sun, Aug 11 2019 5:48 PM
Nice collection Yes - thumbs up
I noticed that on the black remote (left) there is a button marked "21°C"... What is this button for?
PaulGiles
Posts 174
PaulGiles replied on Sun, Aug 11 2019 7:34 PM
Noice! I like the 90 one
Millemissen
Flensborg, Denmark
Posts 13,045
Steffen:
That - I suppose - is a hotel version or made for a yacht....costum made.
Beozip
Posts 207
Yes, the casing ist custom made from B&O Lincoln in 2016
https://forum.beoworld.org/forums/p/21762/190577.aspx#190577
and the keybord is original B&O for Hotels
trackbeo
Posts 311
trackbeo replied on Mon, Aug 12 2019 11:30 PM
Just because nobody answered @Steffen's question literally:
It turns on the heat (or air conditioning), when the hotel guest first enters or returns to their room, after its HVAC has gone into "standby", triggered either by a time-out or by housekeeping room-entry.  21 degrees Celsius is "comfortable", at least in heating mode.  (In A/C mode, you have to be an American to like 21°C.:-)
bramble
Posts 397
bramble replied on Fri, Aug 30 2019 5:43 PM
Decided to give my bl4's .....a wee lift, seen they chrome bases £2 each....it's different
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Aussie Michael
Melbourne, AU
Posts 3,427
New stands for the BL3s
Thank you Danish AV
1990
Posts 348
My parents are putting their house up for sale. Featuring Avant NG 55” and BeoSound 9000 + BeoLab 8000 in the rear.
1990
Posts 348
And no. 2.
1990
Posts 348
BEOVOX141
Denmark, West
Posts 702
Silver Member
BEOVOX141 replied on Sat, Aug 31 2019 10:57 AM
1990:
Help me out,- Where. I see the Avant, but the rest ?
1990
Posts 348
Hidden right in the back. Here’s a non-prof snapshot.
Mikipidia
Posts 1,235
ONLINE
Mikipidia replied on Sat, Aug 31 2019 3:30 PM
Nice place, very light!
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Aussie Michael
Melbourne, AU
Posts 3,427
Johan
Bolsward, NL
Posts 172
Johan replied on Sun, Sep 1 2019 7:49 AM
1990:
Hi 1990, is this in the Netherlands? I like the dutch design classics a lot! (Lotek, Pastoe, Montis...)
Johan
1990
Posts 348
1990 replied on Sun, Sep 1 2019 4:16 PM
Johan:
Johan
Yes! And soon on Funda.nl
mbolo01
Annecy - France
Posts 1,364
mbolo01 replied on Wed, Sep 18 2019 12:22 PM
New joiner BG 4002 :-)
Razlaw
Posts 3,881
Razlaw replied on Sun, Sep 22 2019 10:12 PM
I have had an Essence remote sitting on my desk for years. Today I decided to see what I could do using the desk’s grommet and an STB adapter I was no longer using. Here is the result. Maybe somewhat silly but I like it.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Page 127 of 133 (5291 items) « First ... < Previous 125 126 127 128 129 Next > ... Last » | RSS
