Hi all.
i know this information is here somewhere I just can't find it. My B&O addiction started with beolit 15 then A9 now I have finally pullled the trigger on beolab 18s. I got them on eBay so I really have no idea how to set them up/what is the best set up. I have an Apple TV (4th gen) running to my brand new LG tv. I'd like to run all my music/movies from Apple TV to speakers. Wired or wirelesss, whatever sounds best and I'd like to keep additional costs around 500 usd if that's even possible. Please help! Would be so appreciative for links to any of this info. Just looking for BEST setup within $$ means.
Wamsankas:Hi all. i know this information is here somewhere I just can't find it. My B&O addiction started with beolit 15 then A9 now I have finally pullled the trigger on beolab 18s. I got them on eBay so I really have no idea how to set them up/what is the best set up. I have an Apple TV (4th gen) running to my brand new LG tv. I'd like to run all my music/movies from Apple TV to speakers. Wired or wirelesss, whatever sounds best and I'd like to keep additional costs around 500 usd if that's even possible. Please help! Would be so appreciative for links to any of this info. Just looking for BEST setup within $$ means.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Have not read anywere that LG has WISA capable TVs.
Think the Transmitter 1 is a good option. You can then run an optic cable from AppleTV to the transmitter, and control the volume using your remote. Think price is around 350 Eur.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
Hiort: Have not read anywere that LG has WISA capable TVs. Think the Transmitter 1 is a good option. You can then run an optic cable from AppleTV to the transmitter, and control the volume using your remote. Think price is around 350 Eur.
LG is a member of the WiSA organization.
http://www.digitaltrends.com/home-theater/wisa-ces-lg-sharp-enclave-wireless-home-theater/
To my knowledge there are no WiSA compatible LG devices on the market (yet).
Yeah i feel like this will be my best option but new apple tv does not have optic out so i guess i could just run that from the LG tv? (no wisa in tv) but i have been seeing places that i then couldn't control the volume or something?
Wamsankas:Yeah i feel like this will be my best option but new apple tv does not have optic out so i guess i could just run that from the LG tv? (no wisa in tv) but i have been seeing places that i then couldn't control the volume or something?
Hiort:You can take the sound from the TV. You most likely have opto out on your LG.
I have actually a very similar set up as you, an LG OLED and a AppleTV. Not sure the exact model of TV you have but on my LG OLED the optical out does not have volume control - so everything outputted will be full volume! This is desired if connecting to a DAC or some other end device to control volume.
It is possible to control the volume on AppleTV but there's chances it could be set to full, say via AirPlay moreover your other possible sources connected to the TV via HDMI will probably not have such provision. So forget that.
My Advice is to get an external DAC preamp which is connected via Toslink to the LG tv output. Connect the Beolab 18s via its RCA pre outs and be done. That's what I did and works just fine, prices for these vary from a few hundred to several thousand.
Transmitter1 is basically the same price as a decent DAC anyway with less connections. Plus the wireless aspect is sort of overrated imho, they still need to be mains powered so running an extra wire is not that more of a hassle.
davidr: I have actually a very similar set up as you, an LG OLED and a AppleTV. Not sure the exact model of TV you have but on my LG OLED the optical out does not have volume control - so everything outputted will be full volume! This is desired if connecting to a DAC or some other end device to control volume. It is possible to control the volume on AppleTV but there's chances it could be set to full, say via AirPlay moreover your other possible sources connected to the TV via HDMI will probably not have such provision. So forget that. My Advice is to get an external DAC preamp which is connected via Toslink to the LG tv output. Connect the Beolab 18s via its RCA pre outs and be done. That's what I did and works just fine, prices for these vary from a few hundred to several thousand. Transmitter1 is basically the same price as a decent DAC anyway with less connections. Plus the wireless aspect is sort of overrated imho, they still need to be mains powered so running an extra wire is not that more of a hassle.
Great info. thanks so much. yeah was concerned about the lack of controlling volume everyone has been speaking about. ill look into this setup. thanks!
davidr: Transmitter1 is basically the same price as a decent DAC anyway with less connections. Plus the wireless aspect is sort of overrated imho, they still need to be mains powered so running an extra wire is not that more of a hassle.
Duels: davidr: Transmitter1 is basically the same price as a decent DAC anyway with less connections. Plus the wireless aspect is sort of overrated imho, they still need to be mains powered so running an extra wire is not that more of a hassle. I'm surprised you say that. I find the wireless capability extremely useful if I want to change the position of the BL18s which I have done from time to time. I have power sockets all over the place so it is easy to just pick them up and plug them in somewhere else. Running speaker cables to different parts of my open plan living space bearing in mind doors, full length windows, stairs etc would be a pain, especially just to try them somewhere different.
So what is your exact setup? when do you have running into the transmitter and how to you control volume?
davidr:Transmitter1 is basically the same price as a decent DAC anyway with less connections. Plus the wireless aspect is sort of overrated imho, they still need to be mains powered so running an extra wire is not that more of a hassle.
Transmitter 1 is not a DAC, it's actually just the opposite, since you can feed it analog audio via the RCA cables, and it will digitize the analog audio and then transmit it digitally and wirelessly to Beolab 18. It can also take in digital signals, with them no analog/digital conversion is needed of course. It's just a remote input box for the speakers.
Since Beolab 18 has integrated DSP, I've understood that if you input them analog audio with RCA cables straight from the source, and use no Transmitter 1, a similar conversion from analog to digital happens inside the speakers as would happen within Transmitter 1. One can feed the speakers digital audio with TOSLINK directly, but the volume control needs to happen somewhere on the line.
Using a Transmitter 1 would not solve the volume control need, as the installation guide of Transmitter 1 says about TOSLINK: "Connect 3rd party products to the BeoLab Transmitter 1 using a TOSLINK cable. The volume of the signal must be adjusted from the audio system." (page 9 in the pdf available at https://beocincinnati.zendesk.com/hc/en-us/articles/204227053-DOCUMENTATION-BeoLab-Transmitter-1-Installation-Guide )
I'm also in search of a reasonably priced AV preamp solution that would allow to choose between multiple sources (HDMI, TOSLINK, analog audio), would decode audio to volume controlled TOSLINK output and would pass on the video signal with HDMI to the tv (HDCP and all). Not sure if one really has to go analog in between a digital source (say, the most recent Apple TV with HDMI only) and the digital input of the speakers, just to control volume.
It's true that your solution is probably the most cost effective with good quality sound. The conversion from analog in the speakers should be top notch anyway, so I would not worry about the partly analog path too much.
