Does anyone know what kind of speaker it could be?
https://www.certipedia.com/companies/174322/product_certificates?locale=en
https://fccid.io/MSIP-RMM-BOA-BeoplayM5
Brigantinus:My dealer is not very happy with the sound, he even didn't want to give a demonstration. And after a demonstration i can understand him. You can compare the sound with a radio clock (i think it is designed for that kind of use in the bedroom). If you have the space A6 ist much better.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
chguillarme: Since a few days it begins to make bad cracks on each bass like if it was used full power foreurs since 5 years ! That's not a good sigb if it even can't endorse its default bass settings ! Christophe
Christophe
Does it stand on a firm underground?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Took the plunge and added a M5 to my setup.
Use it on my bedside table. No other multiroom capable B& device matched the interior in the bedroom.
Sound is good for the TuneIN and NAS music collection I mostly play. Have it set as "corner position" to have the bass reduced a bit. Will try timer and wakeup to some music in the weekend
Control require some practice. E.g double "tap" to switch source, but I´m sure I will get used to it.
/C
Hiort: Took the plunge and added a M5 to my setup. Have it set as "corner position" to have the bass reduced a bit. Will try timer and wakeup to some music in the weekend /C
Carefull with the wake-up volume, or you wake up in a "trampoline"
Welcome to the owners family.
Chris:Carefull with the wake-up volume, or you wake up in a "trampoline" Welcome to the owners family.
Depends on how high you want to jump up and down.
No serious, I found it a wonderful speaker,, what colour did you buy? I have the natural.
it will take your standard sound-level, hiort
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Chris: Depends on how high you want to jump up and down. No serious, I found it a wonderful speaker,, what colour did you buy? I have the natural.
Got the "black". Fits well with the bedroom interior.
Hiort: Chris: Depends on how high you want to jump up and down. No serious, I found it a wonderful speaker,, what colour did you buy? I have the natural. Got the "black". Fits well with the bedroom interior.
Just borrowed one from my dealer, just to check it out and see how it performs. It is for my bedroom. I must say, it sounds great, however I really really really would like to be able to change treble/bass manually, it has way to much bass, even in the corner mode.
And one thing, is it not possible to change the sound setting after it has been set up ? It is just greyed out in my beoplay app.
/Weebyx
Yes :( Maybe a bad product. It happens sometimes. Not a big issue I will bring it back but if someone from B&O reads this thread : please, let us lower the bass....
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
Still on the lookout, and hopefully for the next SW update:
First priority: Would be very happy if I could pair the Essence remote again with the M5...
Second priority: Sound settings...
Alexa could connect to the M5.
Since my BS 9000 is connected with a BLGW to NL i can control music with Alexa in my main room.
On my my last party it was impressing all the guests :-)
Ralf
Chris:First priority: Would be very happy if I could pair the Essence remote again with the M5...
After the end of March SW update, it looks B&O added again the possibility to pair a remote.
But as the app says its experimental:
"Please be aware that the remote support is currently experimental and you may experience issues especially in environments with lots of wireless systems and wireless alarms. If you experience issues you may need to reboot your product."
Anyone have tried to pair an Essence remote?
Chris: Chris:First priority: Would be very happy if I could pair the Essence remote again with the M5... After the end of March SW update, it looks B&O added again the possibility to pair a remote. But as the app says its experimental: "Please be aware that the remote support is currently experimental and you may experience issues especially in environments with lots of wireless systems and wireless alarms. If you experience issues you may need to reboot your product." Anyone have tried to pair an Essence remote?
Would be nice to add an Essence remote. I find it a bit fiddly to e.g "double tap" , and also switching on and of laying in bed
