Why was Google Cast not added to the smaller Beoplay speakers?
Not Answered This post has 0 verified answers | 10 Replies | 0 Followers
daneshpastry
Toronto
daneshpastry posted on Mon, Nov 21 2016 4:34 PM
The only thing holding me back from investing in some of the smaller Beoplay speakers (ie - the Beolit 15) is the lack of Google Cast implementation.
Can anyone tell me if there is a technical reason why the larger, all-in-one speakers got it, and the smaller ones did not? I realize I can add a Google Cast Audio dongle, but I use the 3.5mm aux input for my computer.
Qualification - I don't mind using bluetooth, but I feel like wi-fi streaming is better (gets source directly from internet, no phone battery drain, less compression, etc. etc.)
BeoMegaMan
The easy answer is they are Bluetooth only. All WiFi enabled BeoPlay products received the update for Chromecast.
Ah, you know... A little B&O here, a little there
leosgonewild
Helsinki, Finland
Silver Member
I like using the CA with my Beoplay speakers. I am constantly streaming to all of them. I just turn on the speaker when I enter a room.
But I see your point.
daneshpastry
Toronto
Pardon my ignorance, what is CA?
Millemissen
Flensborg, Denmark
ONLINE
CA = Chromecast Audio
https://www.google.com/chromecast/audio/
daneshpastry
Toronto
Gotcha, I thought they changed the name to Google Cast.
daneshpastry
Toronto
steve1977
BeoMegaMan:
what about the beolit 12?
leosgonewild
Helsinki, Finland
Silver Member
That *** unit is not getting any updates ever again.
Irvine
Irvine replied on Sat, Mar 25 2017 10:51 PM
 So, if I understand you correctly, you can use Google cast with the Beolit 15? You just need to buy the Google chrome cast audio dongle and plug it in to the 3.5 mm Jack? Is that how it works? How good is the sound quality? Since it is going through a 3.5 mm Jack, is it reduced?
Millemissen
Flensborg, Denmark
ONLINE
You'll be fine using a decent cable.
Never heard any complaint there.
Page 1 of 1 (11 items) | RSS
