Beosound 5 CD Ripper Problem
Not Answered This post has 0 verified answers | 7 Replies | 3 Followers
bigdeniz
bigdeniz posted on Sat, Nov 5 2016 12:08 PM
I have a problem with my Beosound 5 / Beomaster 5 and a CD Ripping Device:
I have connected a normal CD USB Drive (not the original B&O drive) to my Beomaster 5 via USB. Everything works fine, i can rip a CD, can play the CD if i press CD on my Beo4.
But I can't see the CD entry in the Mode Menu, where i can see all the sources (N.MUSIC, N.RADIO, Spotify and A.AUX). So i can only start playing the CD inside the drive by pressing CD on Beo4. I have tested three different non B&O drives but nothing changed.
It can be possible that B&O make this restriction for all non B&O CD ripping drives?
I have the latest Firmware (7.04.01.1945) and to test every possibility i made a recovery. Nothing worked.
Is there anybody who has the same problem and can help me or has a solution?
Razlaw
ONLINE
I have never used a ripping device with my Beosounf 5 si I am sorry I do not have any suggestions.
riverstyx
Exeter, Devon, UK
A third party USB CD drive will work for ripping, but not, as you have discovered, for CD playback.
I actually wasn't aware that you could trigger it to play using the remote - my BS5 is actually in audiomaster=no as I have a BS9000 as audiomaster in the same setup, so this wouldn't work for me anyway but is useful to know.
I suspect the software looks for the specific USB ID / string of the official CD ripper but I don't know for certain.
Martin.
bigdeniz
Is there anybody who knows the manufacturer of the original B&O drive? Maybe an Teac?
koning
holland
LG
bigdeniz
Which Model Number?
LG-GS40N
LG-GS23N
LG-GS31N
GA32N
GA10N
bigdeniz
Is there anyone who has an info?
gerard
Luxembourg
My pre-owned BS5-BM5+RD is ob its way , I should get it next week.
So if I could be of any help.
Is it possible to get into windowsXP on the BM5 ?
If yes, I could reed the properties and name of the RD in windows explorer and you could perhaps change yours to the same name
Page 1 of 1 (8 items) | RSS
